Ford
> Explorer | Explorer Sport Trac
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
O/d off light flashing 1995 explorer
95 explorer o/d light
95 Explorer Headlight Assembly Removal
heat quit working
99 XL Center Console
1996 explorer code-but which sensor?
03 Explorer 4.0 L P2270 Code
02' explorer - inop. Power windows
'99 Explorer keeps eating coil. HELP!
97 Explorer Sport alarm bypass
99 Explorer XLS
99' Frd Expl 4.0l - Pass Upper Ball Joint
no comunication with data link
Horn
Help with remote starter / alarm installation
Sealed Explorer transmission oil?
Fuel Filter Tool Question -- 97 Explorer 5.0
Bleeding Master Cylinder/ABS System
Compressor cycles too often when using the heater
replaced alternator and battery
2004 Explorer horn goes off when key removed
'97 5.0 V8 will not start, no fuel at the rail
door ajar light
98 explorer missing uphills
Tranny won't shift into reverse! 2003 Explorer
explorer timing
need big time help with parts name..............
P0409
2000 explorer sport seat problem
HELP!! 4X4 Problems 2001 Explorer Sport 4.0 V6
99 Explorer Sport No Ac No Blower Motor
2002 explorer differential rebuild
1996 Explorer code reader
98 explorer blinker problems
1998 Explorer Sport Upper ball joint (drivers side)
need blueprints for 98 transmission
93 explorer brake problem
Cruise Control Issue
outside mirror light replacement 2002
chrome strip coming loose
01 Explorer sport ABS problem at low speeds
1998 explorer sport starts the stalls
Vacuum leak
2002 Explorer: Scraping noise in rear tire
98 explorer loss of power stering and over heating at same time
1994 explorer lights stay on
02 Explorer power window regulator
99 ford explorer won't start
oil pressure gauge fluttering / tapping noise
Trailer lights......
Mirror
thermostat housing/water outlet
Explorer 2007 Trans oil change
need some info think you
will a 1992 ford explorer xlt 4x4 trans bolt up to a 1994 ford explorer 4x4??
95 Explorer starting issues
'03 Wheels start leading to the side when hot
wheel noise 05 sporttrac 2wd
Why won't the A/C take a charge? Is it clogged?
Trans not shifting!!
Airbag/A/C problems..??
99 explorer ac problem
A/C clutch engages and disengages
1997 5.0 ODBII Question -- Expected Calculated Engine Load Reading at Idle
98 explorer air conditioning problem
Engine stalls
2001 Roof Rack Peeling Paint
1994 ford explorer 4x4 module
1997 5.0 Rough Idle, No Codes, Brief ODB Data Linked -- Help Interpret?
2004 Ford Explorer 4.0 Rough Idle VIN K
Misfire on Cylinder 3
91' Explorer 4x4 inop no power on switch
4x4 light stuck on
alternator prob!!! HELP PLEASE
Explorer and the CFC Program
Replace an alternator ?
FORD vs CHEVY vs JEEP? HELP ME OUT
Sport Trac Climate control
2005 sport trac soft brake pedal
2003 Rear End Noise
can you help? 2004 explorer - crack on front
tow with 02 V6 A/T 2wd???
Blown Ignition fuse
1993 Explorer XLT problems starting
PCM power relay
black plastic surrounding rear window fadding fast
2002 Ford Explorer Power Seats blowing FUSE
factory color touch up paint.
00 explorer sport..rh turn signals inop Lh work?
1998 Explorer Sport Head Gasket
2000 Explorer 4x4
Radiator Install - Banging head in wall!!!
Need help with radio/fuses/dome light
97 5.0 explorer intake elbow
no pressure in brake lines.
Annoying,False "O/D Off" Light Flashing
Starting issues sometime
Glowing altenator
ABS light on (01 ford sport trac 4x4)
92 explorer wont start. fuel problems?
97 explorer abs no communication
99 model 4.0 explorer died...runs fine today
Cold air kit question
adjust shifter linkage on 02 explorer
2002 Explorer XLT A/C issue
A/C and Alternator Problems
'91 4.0 code 14
3 trans rebuilds in the last 3 mths is it every going to work again
Upper ball joint replacement 1996 Explorer
trans fluid fill question
transmission question
Standard Transmission Question
2002 ford explorer brake control plug for trailer
02 explorer transfer case not shifting?
02 explorer o/d rpms?
2002 ford explorer front end noise
Hub and Bearing Axle Nut Torque Number???
93 Explorer runs rough when warm
power seat problem
wont stay running in "D" or "R"
What years are compatible???
2000 Explorer,windows Won't Work
'97 Explorer interiior light comes on & off randomonly
96 Explorer Interior Lights Won't Go Off !
I need help bad!!
Slow speed shudder
Help!! removing shifter from top of tranny
2002 O/D flashing 2 Diag. done both different diag.
96 Exp. electrical issues
New Transmission Fluid cause slippage
96 explorer need shocks?
AAAH anti-freeze in engine HELP!!!
96 fuel problem
exhaust bolts to engine
bang on drum
camshaft position sensor
fuel line disconnect????
depressurize fuel lines!!!
brake lights not working when in gear 2002 Explorer
Transmission problem
2002 Explorer 4.0 light problems
98 explorer AWD Thunk on Acceleration
what is that part behind the engine.
1997 A/C only Hot
2005 Ford Explorer, Problem with Brakes
1996 explorer trans problems
head gasket
2003 Explorer 4WD suspension
1994 Explorer trans leaking into oil
HARD Vibration...please help
Torque spec's
04 Explorer SRS light
Proper fuel pressure for 95 explorer??
02 explorer break lights stay on
2000 ford explorer front end shakes when i hit 70 and apply brakes
1995 Eddid Bauer won't take an AC charge
Explorer 4.0L Power steering issue
Radio Removal 2003 Explorer
Antifreeze Disappearing From Overflow Tank
switch from US to European position light/turn signal
doors wont open from inside on 2002 sport trac
1992 High idle in park and rough idle in gears
98 4.0 into a 2000 w/4.0 explorer
06 Expl Heater Fan stuck full blast/can't stop!
93 explorer vibration noises
P0305 Cylinder 5 Misfire
'97 Fog Lights
98 explorer making sound (like a blender)
check gauge light
2004 rack and pinion failure
01 Sport Trac Door Code???
4x4 light flashing
96 Explorer Running Rough when hot
01 Explorer Sport Trac, Several Issues...HELP
2000 XLS ball joints
right hand timing chain lubrication
2005 SportsTrac-Belt squeaking
92 Explorer hard cranking
2000 Ford Explorer Bubbles in coolant reservoir when running
Remove Automatic Transmission
starting to hate my new car...
stock speakers?
97 no heat control
diagnostic mode
2000 4.0 Belt Tensioner
alarm going off on 05 Explorer
2000 explorer v6 plug change
1997 Explorer
97 Explorer Cold start issues and diagnostic
93 Explorer codes
Heated Mirrors smoking the inside.
2003 Ford Explorer vibration/noise from front end tires?
2004 Explorer fuel in oil pan???
Rear wiper inoperative,and door ajar light.
ford '01 sport trak door wiring
Dirt in the Radiator
power steering flush?
Carfax
97 sport trac no heat
ambient air sensor on a '04 location
05 Fuel Filter location
Greetings & a Question
what to do
98-01 Used Explorer -What to watch for?
transfer case clanking
Push button 4x4
01 ford explorer sport trac lf wheel noise
Ford Explorer: Push Brakes and it Accelerates!!
Anyone flush a tranny b4?
My 1st Suv!
Emmissions Prob
98' 4.0 sohc wiring problem
95 Ford Explorer - Can you disable ABS Light
Replacing Rear View Mirror
CEL Codes
A/C Low Port
Power windows dont work on 03' explorer
98 Exp. Trans slipping
03 sport trac dies in reverse
2004 ford explorer won't accept gas !!!
body lift 2000 explorer xls
2000 ford explorer idling really rough
04 Explorer tire pressure sensors
99 explorer sport 2wd suspension problems
95 explorer problems
Door Key Pad
94 ford explorer with white smoke
2002 sport trac 4 wheel drive stop working
Overdrive Dashlight flashing on / off
2000 front seat question.
Tough decision between 2 Sport Trac
1997 Explorer Wipers
p071/p0174
Cold Air Coming in through Glove Box
2000 Explorer Sport 4.0 SOHC lacks power @ operating temperature
03 Explorer--starting trouble.
2000 explorer, no blinkers, no high beam HELP!!!!!!!!
98 Explorer wont start. Can't find solinoid (HELP!)
94 Explorer sometimes won't start or idles rough
02 explorer code P1506, manufacturer controlled idle speed
Explorer idles ok but stalls in gear
99 Explorer Sport Intake Manifold Gaskit Kit Install
remote starter
93 explorer clutch fluid leaks out of bottom of tranny mud guard
02 Sport Trac "hissing"
Two 2003 Explorer Questions
explorer sport front end "earthquake"
5-20W oil for 2004 Explorer?
2005 Wiper and sprayer problem.
