View Full Version : Windstar
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
  1. Long crank before engine starts
  2. Headliner removal
  3. Need a 16" steel wheel
  4. changed front brake pads 95 windstar
  5. changed front brake pads 95 windstar
  6. Intermittent miss/stumble 02 Windstar
  7. Power steering pump replacement issues
  8. Transmission Fluid??
  9. 2002 Running Rough at start-up and idle
  10. Bad wheel Bearing.
  11. y2000 Windstar 3.0 and 3.8 fuel consumption
  12. 2000 windstar 3.8 transmission oil level high when cold
  13. Rear Jack/Lift point for placing jackstands
  14. 2002 Windstar 3.8L replaced front ABS sensor
  15. Towing a Nissan Maxima with my Winnie: Opinions
  16. Clock spring on a 98 windstr 3.8 lit with cruise control
  17. Cooling Fan Relay Question....
  18. P0174 and coolant loss
  19. Difficulty of Exhaust Isolator Replacement
  20. 2002 Windstar 3.8L hood release stuck open
  21. 2002 Windstar 3.8L code P0302 (coil)
  22. Changed Spark Plugs 2002 Windstar 3.8L
  23. steering wheel replacement?
  24. 2002 Windstar Limited Heat Issues
  25. po 1516, 1518
  26. 1999 Windstar SEL- Possible Jump Start Damage
  27. No horn
  28. Anybody ever install a voltmeter in a Windstar?
  29. aside from shocks in the rear end...(suspension question)
  30. 1998 Ford windstar - Pulsing and hissing sound on acceleration only.
  31. Cooling Fan Problem
  32. wow, this site is quiet.. could it be??
  33. Transmission goes to nuetral
  34. Engine Pinging Again
  35. how to get air out of power steering with out vacume pump
  36. 2001 Windstar high idle at start
  37. 2001 p0304
  38. 2000 Windstar Help...PLEASE
  39. Windstar end of the road? - need fuel tank
  40. 2001 windstar po171/174 code
  41. I'll be danged
  42. anybody replaced the driver's CV joint?
  43. Windstar 2000 (3.8L) will not go in reverse
  44. Transmission Failure
  45. evaporator status monitor won't set (no code)
  46. 1998 Windstar shut down
  47. Sticky Brake Mystery
  48. 2000 ford windstar power steering leak
  49. Replace Dipstick on Ford 2000 Windstar
  50. Dash info lights dims when gasing - 03 windstar
  51. 2001 Windstar Stalling Out
  52. Driver side window motor regulator replacement
  53. 02 Windstar running rough between idle to about 3,500 RPM
  54. 98 windstar rough idle then dies
  55. coolant hose at intake manifold
  56. more windstar discussion
  57. Seat Cover for 1999 Wind SEL w/ High Seat, Arm Rests
  58. Parked 4mon on grass, now 50% speedometer & low charge volt
  59. A new noise coming from engine compartment
  60. 2000 Windstar's Instrument Panel Erratic
  61. 2000 Windstar starts, then stops
  62. 98 winstar - Fuse #25 keeps blowing
  63. Ever Seen These?
  64. 96 Windstar Injectors
  65. Hello, all! newbie question for a '98
  66. chirp from front wheel bearing?
  67. IAC replacement experiences on 2003 3.8L
  68. Windstar Is sifting too loose
  69. AIRLOCK causing coolant to shoot out of Radiator Cap?
  70. Clunking noise coming from brake pads
  71. Where to get the Winshield Washer Hose/Tubing
  72. '95 trans into '99?
  73. power steering winning
  74. 2002 windstar blower motor intermittent
  75. Emergency brake light
  76. 2000 Ford Windstar
  77. Another air conditioning question
  78. Rough Idle Only When In Gear
  79. 2000 Windstar shifting issues
  80. Fuel Vapors
  81. Rear heat and A/C not switching
  82. Proper Spark Plugs
  83. Hydraulic Control Module - Leaking?
  84. Fuel pump questions???
  85. 2003 Windstar LX Blowing Fuse #11 (Inside Car)
  86. 2000 winstar
  87. 2003 engine stutters and or stalls on hwy.
  88. Possible Half Shaft Problem???
  89. Source for Driver Side Steering Knuckle 95 3.8L GL
  90. 98 windstar 3.8 liter
  91. 95 windstar engine harness
  92. Tachometer Bouncing all Over
  93. Instrument cluster crazy
  94. tranny erratic shift down / info
  95. Questions about pulling off intake manifold - 2002 Windstar 3.8
  96. Ford windstar 2000 stalling
  97. 2000 coolant flush and refill
  98. Change The Ignition Wires?
  99. 2002 Windstar Transmission Remove and Replace
  100. Front sway bar???? Do we have one on our Winnies?
  101. 1999 Windstar Brake light works, tail light doesn't
  102. 2002 windstar
  103. Compressor cycling on and off
  104. At what point do you give up on your Windstar?
  105. Getting at the Dashboard Lights
  106. Cleaning Air Intake Plenum/Manifold on 1998 windstar
  107. 2003 engine stutters and or stalls
  108. Rough Idle when windstar is warmed up or very cold
  109. 1998 Windstar w/3.8 - Freeze plug leaking
  110. 2 new problems...hi speedo reading and low TC lockup speed
  111. 401 CEL on Ford Windstar 2000
  112. Rear Subframe Insulators/Cushions/Mounts STUCK - 2002 3.8L with reinforcement bracket
  113. Cruise not working...'99 Windstar...wiswind??
  114. CV Joint Boot.
  115. Power Steering - Air in system !!
  116. Rear brakes pulsating after replacement
  117. Runs Rough on Cold Start-Up
  118. how do i find out what brake drum size do i have 9 or 10?
  119. How to remove a rusted in hitch ?
  120. Windstar general upkeep
  121. wind star wont start
  122. 2001 Ford Windstar Codes 0171/0174 & 0302
  123. Tranny problem
  124. Front and rear struts/shocks replacement and AC noise
  125. Help with a transmission leak
  126. need help to identify a exterior body part and where to purchase
  127. 2001 Ford Windstar /having some problem?
  128. 2000 3.8L at 19MPH changing from 2 shift to 3 shift, downshift to 1.
  129. A/C Clutch Cycling On/Off With Defrost Settings
  130. Vacuum in Fuel Tank - 98 ford windstar 3.8 liter
  131. No Brake lights-Wont go in gear
  132. Rear shocks blown and firmer coil springs
  133. sensor question...
  134. 2001 - Idle jumps if I turn the wheel while stopped
  135. How am I supposed to reach this clamp?
  136. Power door drive assembly actuator
  137. Good Canadian Online Auto Parts Store
  138. Cat to flex exhaust pipe, best way to reconnect?
  139. 2002 Windstar Remove Injectors w/o removeing manifold
  140. 98 3.0 code P0446
  141. 2000 Windstar Signal Lights no longer flash after locking car
  142. Anyone know of a 2000 VSS speed sensor adapter to 1998 computer?
  143. '01 Windstar coolant leak, bad radiator?
  144. 2001 Windstar and P0155 and P1151 Codes
  145. Dumb Alternator Question
  146. suspension - what else is there?
  147. stabilizer bar size
  148. 2000 3.8 A/C Evap Replacement
  149. Code C1185
  150. AC Compressor
  151. 2000 windstar 3.8 L.
  152. 1995 Windstar AX4S Transmission Rebuild
  153. How do you Delete Posts and Thread here
  154. 98 Windstar 3.8L - Upper intake hose question
  155. 0340P code came up, replaced sensor with no results
  156. 2003 Windstar, no Driver's side front brake
  157. 2000 Windstar P0715
  158. 2003 ABS Light comes on when I accelerate
  159. Loose shift lever windstar 2000
  160. Fuel Additive Question
  161. 02 Windstar SEL batt Drain
  162. 2002 ford windstar- refuses to start after suspicious activity??
  163. Vvehicle surges forward when applying brakes?
  164. strarting, rough idle and stall problems
  165. EGR Valves Dirty
  166. Help diagnosing P0171/P0174 codes please
  167. what brand of cooling pressure tester
  168. What changes did Ford make to the upper intake in July 2002?
  169. 2000 Windstar Motor Vibrating. Need Help!
  170. Oil burning continues....
  171. Timing Off on Windstar, Where are Timing Marks?
  172. 03 Ford Winstar SEL RPM high
  173. In car re-ring/new heads, or swap in engine from recycler?
  174. Possible windstar Valve problem
  175. No Power To Fuel Pump, 2000 Windstar
  176. 1998 Windstar starts *only* in cold weather
  177. Valve Problem Possible on Windstar 2000
  178. Emergency-Plenum making tapping lod pop
  179. 98 Intermittent P0305 - Lots of troubleshooting
  180. 2003 Windstar Transaxle Problem
  181. vacuum to EGR
  182. "Grinding" rear brake drums ...
  183. Change Transmission Filter: How Important?
  184. Elusive P0174 code on '99 3.8l
  185. 2003 windstar alarm went off
  186. '98 Ford Windstar, 3.8L, battery? alternator?
  187. Possible head machining
  188. Suspension Noise
  189. Power sliding door
  190. Power door lock motor problem
  191. Walmart Replacement Ignition Key
  192. Overturned and snapped a strut tower bolt...
  193. Interesting vacuum gauge results?
  194. Idler Pulley won't come off - 2003 Windstar
  195. Black plastic box attached to rear view mirror stem?
  196. Has anyone tried these repair manual cds being sold on Ebay for $11
  197. Oil in Coolant: Pulling it all together
  198. Add changing blend door acuator to repotrois
  199. New Mystery
  200. Fuel To Injectors, Still Not Running
  201. No Fuel To Injectors
  202. 98 Glass run problem
  203. 2000 ford windstar airbag code 36
  204. Windstar Deep Roarin sound
  205. Exhaust: Stupid Studs instead of Bolts?
  206. Ford windstar 2000 Center Power Door Adjustment
  207. Power steering pump, Lower manifol gasket, Missing
  208. 90 km/hr vibration
  209. Sugar/Antifreeze in My Windstar 2000 Gas Tank
  210. rpm surging at idle, new IAC didn't help
  211. 2000 Windstar transmission slams into lower gear
  212. Any tips on lower intake removal? Injector rails and heater hose connections 1999-03
  213. Power door lock won't open reliably
  214. heater hose compression fitting at block leaking
  215. Amsoil -v- RoyalPurple -v- Mercon V
  216. Transmission Fluid Change Using a Fluid Extractor
  217. Transmission Acting Up and Terrible City MPG
  218. Won't start- PATS shutdown?
  219. Windstar Misfiring when hot
  220. Sugar in Gas Tank
  221. Idle control valve
  222. Power sliding door inop
  223. How to locate a short in electrical system?
  224. Interior and hood lighting blinking on and off as if controlled by Demons
  225. clunking noise
  226. 2000 Ford Windstar - no heat - actuator
  227. No crank condition - not found in search of thread
  228. Door lock confirmation
  229. Fuel pump replaced
  230. Windstar trans help?
  231. 02 windstar dash lights
  232. 02 windstar No Crank! HELP!
  233. Killed 171 and 174 codes, now have P0304
  234. Under front hood whistle
  235. Smelling antifreeze
  236. Windstar losing coolant
  237. 01 Windstar rear brakes
  238. Air Re-circulation Setting: Where Is It?
  239. rythmic engine pulsing (slight) at idle 2001 windstar
  240. po306 and po161
  241. Elusive Motorcraft Double Platinums
  242. message center dead?
  243. headreat dvds
  244. Ford Nav units
  245. Sea Foam And The Windstar
  246. 95 Windstar Ignition Problem
  247. 2002 windstar engine pinging??????
  248. 2001 ford windstar stalling
  249. 95 Windstar Rear Brakes
  250. broken lug stud has got me thinkin..
