View Full Version : Windstar
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
  1. Toque Converter shudder is driving me crazy!!!
  2. 95 w'star tune up
  3. Repair Manual
  4. OBD II Problem
  5. Cruise control still not working - defective pressure switch
  6. Double Trouble: Air and start problems
  7. Windstar won't run properly
  8. How do you know whether your seat belt is working?
  9. Going to replace Transmission
  10. 98 3.8 stalls when put in gear
  11. 2001 Windstar SEL Rear Brakes Thumping
  12. 2002 Winstar..is it a negative or positive ground system?
  13. Overdrive switch not working
  14. Air conditioning problem in 98 Windstar
  15. Intake Air Temperature Circuit High Input
  16. Value Cover Repacement ?
  17. Crankshaft Position Sensor
  18. Half axle replacement how to?
  19. Radiator life span?
  20. Removal? - Quick disconnect coolant hose by thermostat
  21. Misfire on cylinder 1 and 5
  22. HELP (98 windstar) TCC won't lockup at hot???
  23. 97 Windstar Missing
  24. oil inside the air thortle rubber bellows
  25. Oxygen Sensor Green
  26. ABS kicking in, Dry road, not skidding
  27. AC bad smell
  28. Light miss/ shudder under light load
  29. Great News Tranny going I think..
  30. Traction Control Message
  31. airbag error
  32. Shop Manuals
  33. Access to transmission internals
  34. 98 winstar a/c
  35. Windstar Tranny Rebuild and Power Steering
  36. 2002 Tranny problem
  37. 95 w'star 3.8l dpfe
  38. Changing high-mount break light
  39. Uh oh! Coolant in oil.
  40. need help new windstar owner(couple issues)
  41. Codes 171 and 174
  42. Oil light and slight knock after 30min of driving
  43. Removing the transmission on windstar 1995 3.8L
  44. trans problem
  45. Is it an Axle (CV Joint), a Wheel Bearing or Tranny issue?
  46. Trans range sensor
  47. Horrible cooling system design flaw (rant)
  48. 97 Windstar 3.8 - not running - no pulse at injector
  49. 99 Windstar - Worth Fixing?
  50. 96 windstar turns over but will not stay started!!
  51. why the thing wont start again
  52. 2k Ford Windstar/auto door/won't idle
  53. Air Conditioning
  54. About the Intake Manifold Runner Control (IMRC)
  55. What transmission fluid to use for '98 3.8L?
  56. burning smell going uphill
  57. 99 fuel pump/fuel gauge
  58. Module on back of transmission?
  59. 97 Windstar Air Conditioning Unit is not spinning
  60. isolator bolt fix without the valve cover
  61. Wheels Seem to be Grabbing
  62. 1999 ford windstar lx
  63. 1999 windstar door locks
  64. 1999 ford windstar lx engine cuts out 4000rpm
  65. head gasket replacement cost??
  66. 01 Windstar No Left Low Beam
  67. update 2003 windstar
  68. 2001 Windstar ABS and Brake warning lights come on
  69. 95 ford windstar windows and locks won't work
  70. A/C Issues
  71. 2003 ford windstar
  72. 98 Windstar Brake Problem
  73. 2033 winstar wont do any thing
  74. 2001 Windstar 2001 EGR
  75. Windstar Towing Upgrade
  76. cam position sensor
  77. Door Adjar Switch Location Picture
  78. 1999 Windstar Lx Front Bumper
  79. transmission help
  80. Trany Problems 95' Windstar
  81. Tie rod lube?
  82. 96 Windstar...code 0351 issues....
  83. 95 windstar dpfe signal voltage
  84. ABS sensor location
  85. Fuel injector question 96 3.8
  86. transmission leak
  87. Urgent Question: accidentally pour brake fluid into crank case
  88. Air Conditioning Problem
  89. 1999 transmission leak
  90. Rear drum brakes
  91. 98 Windstar blowing hot air in rear a/c
  92. 2001 Ford Windstar Brake Leak
  93. Ecm I need help 99 windstar
  94. Ford Windstar
  95. looking for dash lights
  96. aftermarket radio
  97. excessive coolant usage-- '98, 3.8.
  98. flickering lights
  99. 99 windstar will not turn over
  100. 98 Windstar will not start
  101. Torque Coverter Clutch Stuck Code
  102. Having a bizarre problem
  103. front windshield washer pump quit OR how to rebuild cluster switch
  104. tough one
  105. 96 windstar transmission slippage
  106. 97 windstar a/c pronlem
  107. no headlights
  108. power steering total failure
  109. possible head gasket problem
  110. Relay and fuse help
  111. Is MERCON and MERCON V Compatible?
  112. Shutting off while driving......not cool
  113. 2000 WIndstar armrest
  114. Hot relay & draining battery
  115. A/C can't turn off?
  116. 96 Windstar - Code P1538
  117. 2000 Windstar SEL interior lights flickering
  118. 2000 Windstart Trac Action
  119. Changing Thermostat in 99 WS
  120. Is my tranny bad???
  121. Reverse sensing system acting up!
  122. ABS question
  123. Speedometer jumps between high and low states
  124. Power Window Motor Replacement
  125. 98 Windstar Transmission Quit while driving
  126. 99 Windstar LX Radiator ?
  127. 98 3.8ltr plastic against metal slapping sound / serpentine belt broke
  128. where to get OEM transmission pan gasket '98 3.0L
  129. Could this be the problem?
  130. 1999 3.8 Windstar CMP housing setting
  131. dont know what to do!!
  132. sale. 15x7 5 spokes w/225-60 tires
  133. 2000 Windstar Surging?
  134. Shudder, Shudder, what words to utter!!!
  135. 2001 windstar side speaker problem
  136. A/C Vent Contro;
  137. '03 windstar, trans bucks, lurches
  138. My vans not feeling right!!!?
  139. '02 Windstar compressor shot- compressor?
  140. 2001 windstar bumper cover repair?
  141. Fuel Pump Life
  142. wheres the guy w/fans running all the time?
  143. Berryman chemtool fuel system question
  144. Visteon VCR
  145. excessive wear on the driver side front brake pads
  146. Strut rod bushings
  147. torque converter switch
  148. 98 Windstar 3.0
  149. '99 Windstar Back-Up Sensors
  150. How to change solenoid?
  151. Is my tranny fluid low?
  152. 96'Ford Windstar Pump...Where?
  153. 98 3.8L Periodic Shudder
  154. Curious: Change from 3000 to 1500RPM for IMRC?
  155. Transmission leak
  156. 2001 Windstar Power Window problem
  157. Progress Thread for Repairing the Lower Intake Manifold Gaskets and related items
  158. headlights
  159. Ford windstar Squeaks then stalls
  160. Location of torque converter clutch solenoid?
  161. What else to do while doing the lower intake manifold gaskets?
  162. WS jerks real bad when put in gear
  163. 2000 Winstar Electrical Schematics? (Still fuse #6)
  164. Windstar Coolant Change
  165. Symptoms of torque converter failure?
  166. 1999 Windstar 3.8 Shutters .....
  167. It's not a processor....it's the transmission...HELP!
  168. Anyone know the name of this processor?
  169. DIY Accident Damage Repair
  170. How do I remove the A/C Clutch
  171. Strange Transmission problem
  172. Door Locks Relay
  173. Needing Help
  174. 2002 Windstar New Trasmission Failed
  175. Power Steering Issue!
  176. Water Pump question 2000 Windstar
  177. 98 3.8 Windstar bucking and rough idle
  178. More on 95 surging problem
  179. '96 Windstar stalling when put in reverse or drive
  180. OBD-II Scan Tool Communication Error
  181. computer flash?
  182. 99 windstar 3.8 tranny issues - again
  183. tuch up pait kit
  184. HVAC problem
  185. 03 power steering
  186. where to jack the front end using hydraulic jack?
  187. DEADLY Antilock Brake Operation: 2000 Windstar
  188. white smoke/flickering oil light/little heat through vents
  189. 1999 WS 3.8L white smoke
  190. 2001 battery light on, won't start in hot weather
  191. 2001 Windstar trans leak -- what should I look for?
  192. 97 Windstar - ABS problem?
  193. How do I find TDC on a 3.8 L 95 windstar?
  194. 2001 Windstar "Bucking" between 45-60 mph
  195. 2000 Winstar keeps blowing fuse #6
  196. Outside Temp displays ERR
  197. 2000 3.8 ABS Light at it again
  198. Ford Rattling from bottom
  199. 2000 Windstar fuse location info?
  200. 2001 Windstar - no cold air in front
  201. Went over a bump, now no radio or power sliding door
  202. 2001 Windstar CV Joints
  203. 96 sliding door
  204. Airbag
  205. Ford CDs request >>-need help-<<
  206. Clunking noise when coming to a stop
  207. 96 3.0 with code P0430
  208. Rear light issues
  209. 97 Windstar Power Window Problem
  210. DIY power steering system flush !@#$
  211. Trans trouble
  212. VSS vehicle speed sensor P0500 code
  213. P0500
  214. p1309
  215. Windstar Manuals
  216. Where to buy the Iso Bolts & Ports Gaskets
  217. Help
  218. WindStar Not Starting Up Unless
  219. 2001 Windstar Transmission Line Removal
  220. 2001 SE Fuel Mileage Drop
  221. 99 ford winstar light problem
  222. Cruise control & Abs
  223. winstar alternator?
  224. Loud electric lock buzz on sliding door
  225. Wrong fluid cause hard shift?
  226. 2001 Windstar hesitation
  227. Power steering fluid replacement '97 Wind 3.8L
  228. 2002 Windstar Door Key Lock Repair
  229. help sisters car taillights come on and stay on
  230. reverse alert, need help!!!
  231. clunk from park to drive or reverse
  232. Cylinder head replacement
  233. 2000 Windstar - Mass Airflow Sensor code & rough running
  234. Engine bogging down and trying to stall on startup
  235. Changing Front wheel bearing
  236. remote start...
  237. 95 Windstar transmission just stopped working
  238. Warning light on & no manual
  239. Dash door open indicator staying on
  240. 2000 Windstar Chugging at Idle
  241. About Neutral Safet Switch (TRS)
  242. Broken Bolt Extraction
  243. 3.8 engine compatability question
  244. Trying to find out what a part is called for a 99 Ford Windstar
  245. 1995 transmission flush
  246. Heating problems
  247. 95 3.8 occasional surging
  248. overheating when idling
  249. 96 Windstar Squeals
  250. P0171- did TSB - now misfire on 1 and knock
