View Full Version : Stratus
- distributor
- 2000 dodge stratus
- Brake lights
- CV half shaft problems
- 97 cirrus 2.5 vs code 1495
- Ignition key not turning
- ignition fuse keep blowing. dodge stratus 2.4..
- '98 Stratus misfire
- Steps for Performance & Elimination of Rough Idle
- '97 Dodge Stratus Overheating
- gauge cluster and no power
- transmission
- cirrus 2.5 big problems, help plz
- 02 Stratus - replaceable odometer bulb?
- i can put the dodge stratus pistons 2.4 in the mitsubishi ecipse rods?? 2.0
- 98 stratus problem still !!!!!!!!!!!
- Brake Light / Stop Light Switch
- 2001 R/T w/Tranni problems
- HELP! can't find power lock/unlock wire in 1997 dodge stratus
- 97 Stratus - weird noise...suspension problem
- 2001 Stratus R/T dies
- 2003 Stratus dash peeling up
- 98 Stratus How do I get the windows crank off?
- 98 Stratus Oil smells like gas and is thin
- new cam
- Bent in wheel?
- Horn Problems
- 1996 dodge stratus/stuttering
- 98 Stratus Oil Seaping down back of engine
- 96 Stratus Starts,runs 5 sec dies, headlamp flash
- 97 , pcm asd fuse no start
- 98 stratus
- 2002 SE Heating Problems
- can someone tell me how to defog my headlights
- Trans problem
- 2002 Dodge Stratus 2.4L AOD hard downshifting while slowing for stop.
- 97 stratus 2.5 no 3rd p700,720,733
- can someone give me some performance websites
- hey im new to this site and i was wondering where can i fin euro tailights for my 95
- Please check VIN on Carfax !!
- 2000 Stratus: Cylinder 1 misfire
- car wont start
- Highbeams not working on 2001 Dodge Stratus R/T
- Can any one help me find body kits for 95-2000 stratus
- I just got my strat and doing perfomance to it
- 2001 ABS LIGHT on
- 04 stratus power steering
- Clunking Steering on turns and bumps
- Loud Knock
- 1999 Stratus Misfiring I think?
- Rear Wheel Bearings
- 2000 Stratus Tranny
- 96 Strat. Just shuts off while driving (2.4)
- 2005 stratus sxt misfire
- 2.4 low compression
- Anyone have A/C problems that were not fixed by recharging?
- 03 Stratus SXT Crank Sensor
- 95 stratus NO SPARK
- Hard start/misfire help
- 2001 stratus 4cyl
- 96 Stratus-No fire
- 2001 dead radio
- A couple of problems with my stratus 2002 SE Coupe
- 1998 stratus with 46000 wont run right
- How do I disable the factory alarm
- 2006 SXT Headlamp Bulb Replacement
- Creaking Sound while turning wheels...sounds like old, rusted door
- Horn blows upon acceleration
- son's 96 stratus ran it low on radiator fluid died and will turn over but not start?
- 06 2.7 mpg
- bumping noise when turning
- Rear Brakes on 2000 Stratus SE
- 2000 Stratus with a P0441 code
- 04 Stratus Tranny Problems
- starter location?
- Changing Timing Belt 02 2.4L
- 2000 dodge stratus es
- 2001 Stratus Transmission Not Shifting
- starting problem
- Steering Wheel Vibration
- 2002 - Coincidence or JiffyLube's f*ck up???
- 02 R/T 2dr Coupe...Question about hood covers?
- Help my funky idle....
- 2000 Stratus SE Wiring Diagrams?
- 95 Stratus 2.5L Oil Light
- ASD fuse blowing
- eratic rev
- Two issues - Engine whine and speed related humming
- 442/455 EVAP codes: 2000 Stratus
- Help!! My stratus is dead
- shocks or struts
- Coil Pack for 2002 Dodge Stratus
- Pcm
- Car won't start with key
- EVAP module reset
- 1998 Stratus R/T Turbo Problem
- Rattling noise when A/C is on in idle
- just currious?
- Steering Wheel Shaking
- 1999 dodge stratus check engine light
- Fluid under front passenger seat
- 2005 Dodge Stratus Satellite Radio
- 2001 Stratus gauges fluctuating
- 2005 Air vents
- 2.7L V-6 Oil Weight
- How to properly bleed brakes
- 04 dodge stratus sxt
- replacing catalytic converter
- supercharger for 02 dodge stratus sxt
- 2001 stratus r/t
- A small problem causing big headaches!
- Radiator reservoir boils
- 97 Stratus, Overall problems
- 2.4 same as neon?
- '01 Stratus 2.4 engine pcv location
- Help Replacing Passenger Side Mirror on 02 Stratus
- 98 Stratus ES Engine Codes
- 1.5 Dim Stereo to a 2 Dim
- 2000 Dodge Stratus
- Oil pan HELP
- Oil pan HELP
- 2001 Stratus Timing
- 97 Dodge Stratus Runs Great But Engine smokes
- 95 Stratus Gauges not functioning
- Brake light not working
- Moderator, attachments question?
- someone please help
- 1996 dodge stratus question
- oil change
- engine problems
- Stumped
- Noise in engine
- help me please !!!
- Help
- 2001 Dodge Stratus R/T 3.0 liter won't stay running.
- 1995 stratus battery light issues
- Passenger side mirror broke
- Question about weather stripping for Door
- changing plugs on 2.4L 4-cyl 2004
- 2005 Key needed
- 2005 Key needed
- 2005 Stratus Shake/Shudder
- P1787; 2-1 Downshift Error
- Overheating w/bubbling noise
- Sluggish Steering
- PCM/ASD fuse
- 96 stratus intermittent downshift
- 96 Dodge Stratus
- Stratus timing belt tensioner info - 2.4L
- 97 stratus questions
- any suggestions??
- 1995 stratus 2.4 Auto Trans fluid flush
- !995 Stratus - Rear window defrost switch / relay
- Need Air Ride Suspension Stratus 1999
- Need to sell, taking all offers!
- 2004 won't start on all 4 cylinders-help!
- Antifreeze/Coolant reservoir and head gasket questions
- 1996 Dodge Stratus "no bus" code instrument panel blank
- car is squeaking
- Chugging going up hill
- Can I install factory fogs on my 97 stratus?
- 01 stratus radiator
- 98 stratus brake light behaviour
- 2002 Stratus radio wiring diagram needed
- ECU question
- Brakes
- Can You Change the CD Player in 2005 Stratus SXT?
- Timeing Belt went out HELP!
- 95 stratus wont start
- 01 key/ignition switch
- blower fan only works on high
- 96' Stratus Transmission issue. plz help
- 97 stratus electrical draw
- How do I change Stratus Headlight bulbs?
- Nursing student needs help with fuse prob.
- '00 Stratus radio wiring issues
- No Heat in 2001 Stratus RT
- 99 Dodge Stratus: Battery light Comes On
- Dodge Stratus Tune Up???
- Stratus Brake Problem, Help Needed
- Cai
- Air bag light is on, Fire almost started from steering column. No FAN.
- 97 stratus battery problems
- Looking for a tranny for a '99 Dodge Stratus
- 1995 Dodge Stratus licens plate light
- 4000 RPM bog
- '97 Stratus - Owner's Manual
- Battery Help
- Programming Remote
- 96 Stratus poor braking
- Instrument lights don't work
- Body Trouble Codes/Cruise COntrol
- Car Power Outlet
- Programming Keys
- 2004 Dodge Stratus Idle Issues
- frankenstein the beast?
- 98 stratus car wont start.
- 2000 Stratus Steering doesn't 'return'...
- 99 Stratus/Breeze door speaker
- 98 Stratus Gas Gauge ??
- 97 stratus died again
- Code P0111
- hesitate to accelerate
- Check engine light...again
- 2004 cam shaft sensor
- Trans Wiring.
- Car won't completely turnover
- air conditioner
- 96 stratus...popcorn machine?
- performance chips
- emblems off the trunk lid
- 2004 Stratus R/t Seatbelt Chime
- Car is stalling while driving
- Pray your water pump doesnt go bad
- disable the 15 mph auto locks on my 99 dodge stratus HOW???
- 2004 Dodge Stratus SE
- Advice for buying an R/T?
- 99 DIY collision Repair?
- 97 Stratus starter died - but in a weird way
- Koni front and rear struts for sell on ebay, Dodge Stratus and Chrysler Cirrus
- engine missing
- Leak Detection Pump or Hustle? 1999 Stratus
- 200 Stratus Sedan Steering Knuckles
- 2000 Stratus won't start
- brake lights? 2000 cirrus
- Engine Code
- check engine code?
- 1996 Stratus. Locating Oxygen Sensor (front)
- 2001 Dodge stratus fuel pump problem
- Dodge Stratus 97 Speed Detection Wire?
- Performance without voiding warrenty
- Amp wiring through the firewall
- Pulling crankshaft balancer
- Tie rods
- 95 stratus - map sensor
- 2.0 Timing Torque specs
- Power Steering Lines
- 1997 stratus es
- Anyone have a wiring diagram for a 96 cirrus
- '01 stratus R/T idles loud
- speedomoeter stopped, tranny acts funny
- 2000 Stratus oil light
- 97 stratus, tach dies and odometer too
- Ready for a sledge hammer
- 96-97 v6 overheating. check engine light says cooling.
- Intermittent Turn Signal
- o2 sensor
