Chevrolet
> Aveo
View Full Version :
Aveo
Pages :
1
2
Aveo/Kalos T200 (20025) Light issue
That damn check engine light ...
Door Locking Issues and Dealer Lies
05 Chevy Aveo Chk Eng Light comes on
2005 Aveo Valve Cover Gasket
"Service Engine Soon" Lights Up
Coolant reservoir problem
Abs system fail -life risk
Air Conditioner in 2005 Chev Aveo
2005 Chevrolet Aveo - Timing Belt broke down
reverse and driving problem
Braking issue
Cat converter or not? 2010
2004 Aveo very high idle
2004 flooding after adding fuel
Key won't turn in ignition
Serpentine Belt Tensioner
The auxiliary port in my 2009 Chevy Aveo stopped working
2006 Aveo (Screw Size) Headlight Casing
2004 Aveo serpentine tensioner pully removal
check engine light on, no acceleration
Replacing Head Gasket
04 Aveo died on run, won't even try to start
Aveo coolant problems - Help! Anyone else had this happen?
radio swap
2011 chevy aveo LT 1.6L
Blew my Timing Belt at 33K!
After Head swap I have a Electrical connector I can not locate the home to
2008 Aveo ....Problems
Airbag Light
Chevy Aveo Rear Tire Locked Up (Brake melted??)
Won't Shift Out of Park
Low compression
The Garage I took my Aveo to for power steering fluid issue...
HELP; My Power Steering Fluid in my Aveo is White
2005 Aveo indash clock
Ignition key stuck in.
Horn won't work
2009 Aveo
2007 Ignition Key - Transponder?
Check Timing Belt
Chev Aveo Lock Stopped Chirping
You guys are awful damned slow
2005 Aveo Timing Belt Question
2004 Chevy Aveo right rear wheel locks up in reverse
2005 Aveo won't remain running
Question about 04 Aveo SES light
2005 Aveo with P0300 code
04 Aveo emission failure high co
2004 aveo power steering
Hub Caps for 2004
wind noise
Timing belt question
Oil Changes
Aveo keyless remote battery? RK700NR
2006 aveo looses throttle power
water pump replacement
Aveo problems
Mutiple Issues (Noises, Lights)
coded keys
Chevrolets that not represented in USA
alarm install
04 suspension creaks and groans
Aveo oil change
'08 Aveo Airbag Warning Light
Timing belt change or else.
Brake Problem
chip
curious....
Rabbit troubles (the furry kind)
Passenger Compartment Air Filter
CEL and radio help
Water Pump leak
key remote
'04 Door check replacement
Replacement Wiper Blade Fitment Problem
rear side marker
Bad turn signal switch?
replacement struts?
2004 Chevy Aveo AM Radio Buzz
Trans shifting issue
2004 Aveo road noise issue
it died on the highway and it doesn't make sense!
adding coolant
What metal is the engine made from?
Differences between '05 and '06 1.6 Engines?
Chevy Aveo timing belt TSB
Power Steering Fluid Leak
2005 aveo brake problem
Head Scratcher
Aveos invited for Economy Run event
Removal of cylinder head
Dirty Aveo motor
Engine Rebuild
Water leak
Battery Polarity Reversed
ATF fluid
Air Filter. Recommendations?
Chevrolet Aveo U-VA Mileage Feedbacks?
'05 Aveo alarm disable?
Misfires!?
Problem with the steering wheel
P0300
Help to change the spark plugs, 06 model
On line repair information
Aveo rear speaker install
Aveo Spoiler 2005
04 Aveo radio issue
4 quart oil change?
aveo seat comfort
Leaking lubricant???
Problems in the cold...
Radio Malfunction
Headlight Adjustment
How do I install new speakers?
wtb 04 - 06 aveo headlights
2007 aveo floor mats for sale $50 bucks
Motor swap/ Make in to a tunner !
Aveo?
Aveo Manual Stuck in Reverse (After Wreck)
2004 Aveo serpentine belt removal
Hold light came on began flashing and check engine light
06 Aveo Battery Fuse Question
Weird engine rpm drop when coasting
'09 aveo5 vs yaris ?
`09 Aveo5 cosmetices ?
'09 aveo timing belt or chain ?
oil change problem HELP!!.
Aveo5 bad hatch latch and the fix
Lock tumbler fell inside
Aveo strut bar...???
changing clutch
motor shaking at idle
Interior fan quits or won't start, but comes back
some problems (radio + time Display)
Helping decision
Aveo Air Conditioning Question
04 aveo awesome little car
Aveo Aftermarket Parts
'04-'06 OEM Aveo Steel Wheels
Timing belt replacement tools
Daytime running lights not working
Key issue with 07
06 Aveo Wiring Harness Power hardwired?
Changing headlights
Car lock doesnt chirp anymore, HELP!
2007 Aveo Hatchback latch & electrical
What is the torque spec for 2004 front axle nut?
The Aveo Shudder and Shake
Would like to start a Chevy Aveo Owners Club in the Northern KY area.
Aveo Radio
How Important Is It?
Broken Passenger side turn signal..
Aveo passenger airbag light
2005 Spare Tire Size?
Check Engine Light On
05 auto trans fluid
Spark plug question
2005 Aveo Clutch going out
New car !!
Stereo wiring for 2006 Aveo
parts
radio problems - no sound
2004 auto trans fluid level how to check it?
Front turn signal
turbo
2007 airbag light on
ignition key locked and won't come out?
Jumper cables hooked up backwards/Aveo screwed up.
Help wth radio fuse removal
Oil leak
Audio upgrade
07 LT MP3 CDs not working...
Swappably Delicious
2004 Aveo Car Alarm Going Off Randomly
Squeaky Rear Suspension??
Engine Shuts off when stopping - idle speed 750 RPM
Aveo + New Tires == speeding ticket
Can you install keyless entry in 08 Aveo hatchback?
Beware Aveo's plastic T-stat housing
warranty question
Aveo auto trans FYI.
Hi
Upgraded Timing Belt
Stupid question time
My 2007 Aveo vs. the competition
04 aveo
2004 aveo radio code
Penniless Aveo Owners Responsible for Pathetic Aftermarket
Sticking Clutch Pedal
Aux Input for MP3 Radio
Problems after head remake.
How do you remove taillight assembly on 05 Aveo
unhappy
2007 SVM Power locks help
no more DRLs
Aveo power steering noise
2007 Aveo Sedan's Quality
What is the difference between [ALL] and [DIR] on '04-'05 MP3 head unit?
Aveo Performance
headlights dim
ok, so i made a...
Aveo tail lights
Will a 04-05 Aveo MP3 radio work in a Toyota?
Need some advice on 04-06 CD/mp3 stereo
Installing remote starter
installing a remote starter
Aftermarket cruise control installation
Convert Your Boring Aveo To A Kalos Sport!
05 Door Locks!!
2006 Chevy aveo radio install
aveo meet 10/13/07
Aveo+autocross
Rare Kalos Conversion Parts Back on eBay
spark plug gap?
Braking question on 07 Aveo
Radiator Plug -- Drain Coolant
Aveo sedan 3 questions
Passenger Airbag Light
p0300 code
Questions On Jacks & Jack Stands
Kalos Bumper, Headlights & Ground Effects on eBay!
Oil Change Help Emergency!!!
Tune-up info
Short Shifter
Who Wants New Engine/Tranny Mounts?
Adding A/C to 07 aveo hatch
Flashing "Hold" light
check out this forum
2004 chevy aveo
Temporarily Disabling car
service manual
2004 Automatic Aveo Knob Removal
Aveo5 Attempted Robbery :(
Cruise Control
dead
anyone selling their aveo oem stereo set
'04 Coolant Smell
Chevy Aveo 2007, smell Gas fumes at higher elevations
sedan vs. hatchback
Help!!!!guages!!!!!
Wheel bearings
Where is the Fuse box
aveo transmission
where can i find the color code?
resonators
anyone selling a factory rim?
Factory Wheels and Power Door Locks!
HELP! Radio code
