View Full Version : Lumina
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25
  1. Chime does not shut off
  2. Air coming through vents not sufficient to heat or cool 1992 Lumina
  3. who is right about the location of the pcv valve
  4. 93 Lumina No Go What da heck do I do next?
  5. Changing the spark plugs in 90 lumina
  6. losing tranny fluid, but where? + noises!
  7. Luminca Overheating.
  8. Lumina Engine
  9. Stalls at stop after Disconnecting battery
  10. Coolant Problem
  11. Didn't know it could do that
  12. performance parts
  13. timing belt of chain
  14. 1992 Lumina APv
  15. 93 lumina 3.1 v-6 hard starting
  16. Rear suspension noise?
  17. problem w/ electrical.says the code?
  18. 99 LTZ with 131k...sell or keep?
  19. 95 lumina whining and a little slow
  20. Sideview mirrors
  21. 91 Chevy Lumina stalls - DITTO
  22. 1997 Lumina Power window problem
  23. 96 lumina 3.1 radiator for sale
  24. 1992 Lumina Speed Sensor
  25. Tail light keeps blowing out in the rain
  26. Better way to hold door panel on?
  27. Clean headlight lens?
  28. Brake Pads
  29. '91 Euro Cooling fan prob
  30. 97 Lumina Security light
  31. 97 Lumina Won't Start
  32. 93 Lumina coolant leak
  33. 98 Lumina continuous chime problem
  34. '95 APV cooling fan won't turn on...
  35. How reliable are the mid 90's Luminas
  36. Weak ventilation air flow
  37. 91 lumina euro headlights
  38. Rich and the parts monkey...
  39. 94 Lumina fuel problem
  40. torque specs
  41. ABS problem
  42. Question about 1997 Lumina AC
  43. A Very well built car!!!
  44. lumina fuel pump relay
  45. fuse box diagram
  46. flush
  47. lumina 99 3.1 ...wheel noise on reverse
  48. loosing oil
  49. cruise?
  50. '99 Transmission shift trouble + coolant issue
  51. 95 3.4 DOHC idle surges
  52. 95 lumina heat and radiator problem
  53. 93 lum euro 3.4 fast cold idle
  54. 1991 Lumina Project
  55. `91 Lum 3.1 crank sens died on hwy, cyl 4 plug smashed, now no comp in cyl 4!
  56. 98 lumina vibration problem
  57. Cooling Fan Probs
  58. signal light
  59. 92 Z34 for sale
  60. 93 Lumina 3.1, I am becoming an expert
  61. 1992 chevy lumina z34
  62. 97 Lumina Water Pump
  63. 93 lumina euro 3.1 auto
  64. 92 lumina dying out
  65. 97 Service Engine
  66. Service Engine Light
  67. 93 Lumina Fuel Pump Control Modual???
  68. 1996 chevy lumina apv keyless remote program
  69. 97 Coolant
  70. low coolant light
  71. 98 lumina problem
  72. Location of PCV valve
  73. electrical system main harness
  74. 93 Lumina fuel filter--from trunk
  75. 1991 Lumina Z-34 Car, Will not Start, NO Power
  76. help with parts
  77. A tire review, if anybody cares...
  78. I need to rasie my Lumina
  79. '94 Lumina - whining noise
  80. 94 Lumina - dash warpage
  81. 94 Lumina - replacing bulb for HVAC controls
  82. 97 Lumina Radio
  83. 97 Lumina Coolant change
  84. 1997 Lumina Engine Light
  85. "Cheap OBDII Scanner" Is it worth it?
  86. brake pads and caliper ?
  87. New brakes in lumina...again..and again...
  88. Car refuses to start
  89. 1994 Lumina APV Headaches!
  90. 93 Lumina 3.1 "shuddering"
  91. Wire Harnesses?
  92. Extremly High Idleing During winter starts -- 93 Lumina 3.1 -- Throttle Position Sens
  93. Oil gasket replacement
  94. Heater core leak
  95. 94 Lumina Z34 problems?
  96. 1990 2dr chevy lumina so mang problems help single mother please
  97. Lumina Instrument cluster swap
  98. tranny swap?
  99. Drl......
  100. 94 lumina apv rough running
  101. where can i find website to decipher codes
  102. Swap a 3.1 for a 4 cylinder in a 1992 Lumina?
  103. 1990 Transmission goes to nuetral over 2k rpm
  104. lumina starting
  105. Lumina Sound System
  106. 96 Lumina APV transmission overdrive
  107. Lumina Z34 engine
  108. 91 Lumina stalls- even tried a psychic :-)
  109. Mass Air Flow (MAF) Sensor??????
  110. 91 Oil leak on backside of 3.1 Euro
  111. 94 Lumina shudders in between 3rd and 4th
  112. 93 3.1 Intermitantly runs rough
  113. 92 Lumina APV tranny rebuilt but wont move at all!
  114. 1991 chevy lumina
  115. `93 Lumina APV 3.1 sputters and runs rough
  116. just got a lumina... is there a distributer in the thing?
  117. 96 lumina, heres a strange one!
  118. P 102 Error On My 99 Lumina
  119. R.I.P.arts
  120. 1993z34 Not starting,pukeing fuel
  121. Fuel Filter Location for 2000 Lumina Sedan
  122. chevy man needs help in windy city
  123. catalytic converter removal
  124. 1990 Euro Dashboard Brake Light intermittently on
  125. Replaced the alternator, NOW IT WONT IDLE!
  126. 96 Lumina chugging/stalling/no start
  127. 97 weirdest noise ever !
  128. Adjusting the Idle on a 1990 Lumina
  129. Need Help! Transmission Price
  130. when in drive....
  131. door panel
  132. Heater blower motor power
  133. 94 Lumina, Battery acting like it's dying.
  134. Cruise control motor out. Help with replace.
  135. Replay asap if you know the answer pls
  136. I have a 1990 Chevvy Lumina, What kind of Coolant do i need?
  137. manifold bushing???
  138. 95 lumina ecm question
  139. fuel gauge doesnt work
  140. 2001 Lumina Hypertech Performance Chip
  141. stalling 1990 lumina
  142. 96 lumina
  143. 2000 Lumina transmisson problem
  144. 93 Lumina APV 3.1 Trans Problem
  145. 93 Chevy Lumina Euro For Sale CHEAP!
  146. I CUT MY LUMINA IN TWO!!! SERIOUSLY!!! It was fun.
  147. Just Won't Start
  148. Dash Board Wiring
  149. 91 Lumina stalling probem
  150. 91 3.1 spark plug connection
  151. 95 Lumina-2 related problems?
  152. Does my 2001 Lumina have a factory amplifier?
  153. Does anyone know any sites for wiring diagrams for a 1990 Chevy Lumina Euro 3.1 Car.
  154. Fuses
  155. Starter 1995 lumina
  156. 96 chevy lumina van something electrical
  157. 2001 Chevrolet Lumina and others factory delco CD player for sale
  158. EGR Valve
  159. Rumble
  160. cold air intake
  161. 90-94 silver lumina owners please help..
  162. '96 Lumina Radio Doesn't Work...HELP!!!
  163. Running Bad
  164. Kooterskkar question
  165. Parting Engine
  166. 93 Lumina - rough starting, please help!
  167. 1996 lumina fuse box
  168. Dash Lights
  169. EGR misfire
  170. '97 Lumina APV
  171. Dash covering
  172. Cranks but wont fire
  173. Changing front brake pads
  174. Power Steering '98 Chevy Lumina 3100
  175. 91 lumina...rain leaking into passenger side
  176. stalling 1993 Lumina sedan
  177. Help Lumina idle/miss w/Haynes codes
  178. 1990 chevy lumina starting problem
  179. 95 Dash Cover replacement
  180. 93 lumina help needed - please!
  181. New performance mufflers or cat back systems
  182. Fan slows and radio volume goes up when I go up hills
  183. Lumina Ignition Module??? Is this the issue
  184. Iac
  185. Headlight lens
  186. '93 chevy lumina 3.1 MFI idle/running problems
  187. 97 lumina won't start (please help)
  188. here ya go
  189. battery change
  190. Ignition lock cylinder
  191. Tranny Shift solenoids - 96 Lumina - Has anybody replaced em?
  192. 98' chevy lumina A/C
  193. Is it time to let go?
  194. 1996 Lumina codes
  195. Help the new bee. Oil light stays on
  196. conversion
  197. 1995 Lumina 3.1 spark plug wire connections
  198. Water dripping from muffler
  199. 92 Lumina overheating problem (yes another one)!!!
  200. cold exhaust
  201. Passkey
  202. 2nd gear starts - tranny
  203. This has to be a faulty Wire!!! Has anyone got a suggestion which wire it could be?
  204. fuel pump wires?
  205. Why are my brakes so bad?????
  206. 90 lumina leaking gas from throttle body
  207. Idle/Shudder
  208. Pop ups
  209. Stalling when put into reverse
  210. 96 Lumina A/C problems
  211. a/c is only coming through the defrost!
  212. '92 Lumina z34 idle problems
  213. Occasional Tranny Problem
  214. struts
  215. 93 lumina tranny
  216. LuminaAPV-3.8-1993, gas gauge reading high
  217. 92 lumina apv location of tcc harness on trans.
  218. Buying a Lumina
  219. 92 Lumina Vacuum lines location????
  220. start problem (twice start)
  221. need recommended tire pressure
  222. 1990 Lumina clicking while car accelerates
  223. 1990 Lumina won't start hot
  224. Replacing Transmission on 96 Lumina
  225. 1996 Lumina Minivan Headlight Problem
  226. 97 Lumina Deceleration problem
  227. Remote Star For Luminas
  228. 2001 Chevrolet Lumina Interior Spray Paint
  229. hey guys, nothin wrong here
  230. 92 APV 3.1 - fan short
  231. 99 APV 3.2 - Tranny "trailering"?
  232. My stalling 1992 Lumina Euro 3.4
  233. 91 Lumina 3.1L - High Oil Pressure
  234. Dash and Radio lights go out when Headlights are on
  235. muffler shops
  236. Replaceing a Base Cluster(85mph dash) with a Guage Cluster(115mph dash)
  237. The time has come... parting the car out.
  238. Engines shuts down while driving
  239. Hey Mechanics! Car ain't accelerate-in
  240. lumina needs help? will you help me veronica
  241. can bad egr cause crank but no start?
  242. Remove 94 APV rotor removal (How to?)
  243. car stops accelerating
  244. 1992 Chevrolet Lumina 3.1 Euro
  245. Car is not accelerating
  246. Lumina APV 3.8, cruise control not working
  247. What coolent to put in a 93
  248. 4 Sale
  249. how to put a cd player in a 93 lumina
  250. standard or metric
