View Full Version : Park Avenue
Pages :
1 2 3 [ 4]
5 6 7 8 9 10 11 12 13 14
- '96 Park Avenue - What is this?
- ignition module and coil pack.
- '95 Park Ave OBDI port location?
- 94 Park Ave.
- Cam Sensor Replace
- airco does not work?
- Park Avenue won't start
- 98 Ultra Rear Caliper Removal
- Spark plug wires?
- Auto Rx any good?
- '96 Park Avenue - Cranks but won't start
- installing new multi function lever on 1993 P.A.
- 91 PA fuel line help
- 1999 pa BCM ????
- 1995 Bizzare PA electrical problems
- starts, runs, dies, starts and runs again...help
- Lean Exhaust Code-Mechanic Can't Resolve-Please Help!
- transmission whine
- 2000 park ave 3800 throttle body
- What's this part called?
- 91 PA parking lock
- ABS engages...
- changing transmission filter (91)
- Best deal on AC Delo O2 Sensor?
- Intake Manifold Repair Question???
- 99' Park Avenue 3.8L Coolant leak
- 1999 Ultra - Sticky Accelerator
- cruise control and trip odometer
- Car set all winter,condensation thur whole car
- Transmission issue 91 Park Ave
- 98 PA Battery dead Ignition key alarm
- Ignition Lock Cylinder
- 1989 Park Avenue Auto Level failure
- headlight assembly
- 97 PA Electrical Issues
- leaking vapor canister
- 95 Park Avenue - Upon Start cuts out
- 99 Park Ave park assist setting
- Help-I killed my friend's 94Buick PA Ultra SC
- 94 Park Ave
- lighting upgrade
- sidemarkers
- '97 Park Avenue Ultra Seat Switch
- '97 Park Avenue Ultra Door Lock
- High idle
- Uncooperative factory radio unit
- 94 park av ultra p1640 QDM error
- Replacing Gauge Cluster 1985-1990 Electra Park Ave
- Red book price of 99 Park Ave
- 1995 park avenue transmission
- 94 Buick PA-Battery, Starter or Alternator
- 86 park avenue bucks like a bronco when cold
- automatic climate control
- tuning 91 PA
- changing front brake pads
- Leather seat re-dye
- Re: code 45 - Redux
- 1991 Park Avenue Column Smoke
- 2001 Park Avenue Message
- PassKey Problem, 92 Park Ave.
- Rattling sound
- help on park ave
- 96 Park Avenue
- Turn Signals now have gone bonkers
- Starter?
- Power Door Locks
- Replace bulbs in radio & HVAC head
- Rear shocks
- Chrome Bumper Trim
- 1997 Park Avenue Starter replacement
- poor mpg 91 PA
- 2000 PA base, MF switch issue // recommendations
- 00 P.A. Low spark on #6 coil
- Thinking about buying a PA
- 1989 park ave probloms with ATC power module
- low oil pressurs light
- heater and a/cgoing crazy
- 91 Heat works on occasion
- Interior color/code?
- '89 vin C code 21 and 22 and 26
- Water standing in rear floor board
- Re: Displaying HVAC diagnostic '97
- 98 park ave coolant bypass elbow
- Grinding noise in my 96' PA
- 1996 PA power steering issues and endlink question
- external temperature
- Tie Rod replacement?
- Re: 1997 Park Ave Drivers Side Door Handle II
- 1991 park avenue electric motor keeps running
- horsepower
- wiper blade inserts
- 98 PA Ultra transmission issue
- 97 PA soft ride suspension?
- lower door seals
- 2000 Buick Park Avenue Leaking from Oil Level Sensor
- oil plug washer.
- ways to check codes on older cars.
- Turn/Stop wiring
- 96 park ave climate control flashing
- 96 buick park ave ... driving me up the wall... dies when put in gear
- 98 PAU Multi function switch removal?
- Time to replace my tires
- How to program keyless entry for 1998 Buick Park Ave
- 1990 Park Avenue Turn Signals Not Flashing
- rear window defogger
- Stalling when I let up on gas pedal
- 93 Park Ave Ultra no heat
- 00 Park Avenue 6x9's Removing
- Park Avenue Problems
- Buick Park Avenue or a Cadillac DTS
- 96 Ultra Rear air struts
- 2001 PA Turn Signal problem
- crankshaft position sensor
- Disconnect Theft Alarm ? Can I do it?
- RPMs Studder in 1800-2500 Range
- 1997 Park Avenue - Oil pressure at 129psi - sending unit
- car battery terminals.
- Radiator - Hairline Crack
- horn pad replacement
- Supercharged vs Non-Supercharged
- Molded carpet for 97-04 PA's?
- 01..replacing license plate bulbs...
- How big is my tank?
- 1986 Buick Park Ave Wont Start
- electrical problem?
- 1991 PAU (non-SC) LIM Heater Core Pipe Question
- a few concerns.
- Replacing timing chain assembly
- DC 12v power source
- Remote Programming For 1995/96 Park Avenue
- 1992 PA - headlights and warning dash
- Car won't go into gear until it warms up
- 99 PA Ultra misfire at acceleration
- Automatic Locks when you put car in gear - wiring question
- Temp control issues
- 93' Buick Park Ave Ultra Injector problem
- Water leaking onto carpet - solution
- 97 PA Lights/Electrical Problem
- oil cap
- 96 PA climate control issue
- 97 Park Ave Ultra power surge on ignition
- totally removing vats on a 91 park ave
- what to look out for
- 94 Buick park ave Trans Problem
- Noisy Fuel Pump
- Front wheel bearing assembly
- heater air from front air ducts
- 95 PA ride leveling system??
- Ultra conversion?
- Fluctuating gas gage
- Brakes - Dealer Vs. Muffler and Brake Stores
- Bosch O2 Sensor
- HELLLP! Need your Advice!
- Heater Hose Routing
- 91 Park Ave Brake Headache
- Air Pockets In Cooling System??
- Re: 2000 Park Avenue Ultra - Rear Defogger
- 1997 PA Power Steering
- Cold Air Intake and MPG???
- 95 won't start
- Re: 1992 PA Theft Deterrent Problems - Trunk
- Battery Condition, Cold Crank Amps vs Drain Test
- O2 Sensors - 1999 Park Avenue Ultra
- 1999 Park Avenue Ultra - Magnasteer
- Just picked up a 96 PA
- 95 Park Ave Rear Air Strut Replacement
- 98 Park Ave. Procedure for Changing Alternator
- Gas Mileage 02 Sensors and Spark Plugs - Once Again
- 98 PA valve cover gaskets
- power seats
- 94 buick pa radio and climate control
- Rear spring compatibility
- crazy automatic climate control problems (1992 PA)
- Re: park avenue interior lights
- 1991 Performance
- 90 PA heater stuck on hot and in foot mode
- 88 PA opera lamps
- 1990 fails to shift out of first gear. Fuse Issue?
- Gas Mileage O2 Sensors and Spark Plugs
- warning lights
- 93 buick park ave passkey bypass
- power locks.
- 1991 Buick P.A. ignition coil assembly! How to Check?
- Fusible Link?
- 97 Park Avenue check vehicle soon light
- Is this from the trunk pull down?
- strut and shock recomendations?
- 95 park avenue engine or tranny
- Bad ignition sw. ? 99 PA Ultra
- 98PA water pump
- rumbling noise from speakers
- Look to buy a 96' base model PA
- And the cause of my hard start / low speed stall condition was.....
- light bulb under the hood
- Re: Water noise when it rains 11
- button under the hood
- overdrive problems
- oil under plenum
- 95 Buick Park ave brake line blow out
- grand touring suspension and valve adjustment
- cruise control problem
- Transmission going out???
- 91 PA won't start
- Sunroof not closing properly
- 98 PA Noisy water pump
- 1999 Park Avenue Ultra Transmission Screech
- 1995 Park Ave Belt tensioner
- supercharger oil
- having some electical issues, I think my bcm might be going out?
- hard idle, no power on acc. 1992 PA
- airfilter question
- 1995 will crank but not start
- Engine Hesitation after quick stop
- Car jolts into gear, from park
- 98 ultra passenger door will not unlock
- Rusted brake line replacement
- 94 Park Avenue transmission issues
- odd radio time reset
- 95 Park ave a few different problems
- Where is purge canister solenoid - 97 Park Ave ultra?
- 1998 Buick Park Avenue Ultra shudder under hard acceleration
- Can a crank sensor be replaced on a '92 without the special alignment tool?
- Brake ?
- 99 Park Avenue Ultra SC belt replacement
- Live data scan tool for '92 or '93 PA's
- HELP! Buick Park Avenue Bushings...
- Harmonic Balancer
- Best Oil?
- Would anyone recommend a 2002 Park Ave?
- ignition??
- 1999 Park Avenue Ultra Security Indicator
- PAU can't idle below 950 rpm
- 2001 Not Starting
- 95 PA water Pump
- Am I Dreaming?
- PA Door Drain Holes?
- Fuse Diagram for 1995 Buick Park Avenue?
- 1999 Park Avenue Ultra Difficult and Gritty Steering
- 1999 Park Avenue Ultra Steering/Starting/Stopping Noise (Metal to Metal)
- 92 Park A Ult. No Overdrive...
- 95 BUICK PARK AVE not running HELP symptoms inside
- 2002 self-leveling
- '92 PAU Charcoal Canister
- 1995 Buick Park Avenue Just Dies - No Warning
- 94 Park Avenue door lock problem
- Oil Leak Question
- 1992 Buick Park Avenue won't start - funny noise
- Harmonic Balance 1993 Park Ave
- No Start!!!
- 2000 Park Avenue Ultra
