Fuse Diagram for 1995 Buick Park Avenue?
LadySmith
09-19-2008, 08:30 PM
Does anyone have a diagram for the fuses in a 1995 Buick Park Avenue?
Mine doesn't have any labels, except the one in the fuse/relay center under the hood...the ones with the big fuses and relays.
I need a diagram for what goes to what for the fuses under the steering wheel and the ones behind the glove box passenger side kick panel area. (I think I had found out the fuel pump fuse is #6, but that's all I know) These are the little mini fuses.
Also, please let me know the correct amps it should be and all so I can check and make sure all fuses are working and in the correct slots.
thanks in advance
thanks in advance
C man
09-19-2008, 10:44 PM
Here's a pic from my owner's manuel. I have a 95' too.
The fuse panel under the glove department should have the fuse diagram on the opposite side of the fuse panel. One of them is kinda blurry.
http://i538.photobucket.com/albums/ff346/dee1538/0919082108.jpg
http://i538.photobucket.com/albums/ff346/dee1538/0919082109.jpg
C man
09-19-2008, 10:52 PM
For the right side the fuses are
1 Door Locks, Trunk Pull-Down, Fuel Door Release
2 Power Antenna, Lock Switch, Trunk Release
3 Horns
4 not used
5 Cruise Control, Misc. Engine Controls
6 Fuel Pump
7 Injectors
8 Powertrain Control Module, Pass-Key II
9 Not used
10 Not used
11 A/C programmer
12 Not used
The order for the fuses go up in down in columns. First row 1-4 etc.
3 Horns
4 not used
6 Fuel Pump
7 Injectors
9 Not used
10 Not used
11 A/C programmer
12 Not used
LadySmith
09-19-2008, 11:24 PM
Thanks, y'all! Y'all are the BEST! :wink:
The owner's manual I have with mine...part of the pages are torn out and missing, and I don't even think it goes with mine. I think it's a previous year Buick because the pictures in it for a few things...like the A/C and such are different.
LadySmith
09-19-2008, 11:28 PM
3 Horns
4 not used
6 Fuel Pump
7 Injectors
9 Not used
10 Not used
11 A/C programmer
12 Not used
What is the A/C programmer? What does that do?
3 Horns
4 not used
6 Fuel Pump
7 Injectors
9 Not used
10 Not used
11 A/C programmer
12 Not used
imidazol97
09-20-2008, 09:52 AM
The programmer is the computer box that changes the vacuum controls for the HVAC to change airflow directions and controls the two actuators that move vanes to control temp for driver and for passenger side.
It's held to the corner of the HVAC box under the dash with two screws. It's about the size of the old paperback dictionary.
