View Full Version : Contour
- 2000 Contour dashboard coming unglued
- Idle issue. Underhood wiring
- 97 Contour Vaccum Line Layout
- Oxygen sensor - which one?
- 98 Ford Contour 2.0L 4 cyl
- 98 contour se timing specs???
- Replaced PCV valve, now won't start
- 95 for contor wont start.
- Battery, air bag, parking brake, and ABS lights.
- missing belt
- Help Needed
- 1999 Contour SE turning over
- trany problem
- 98 contour 2.0 zetec need help please
- 1996 Contour Clutch problem
- 98 Se Tranny
- running hot
- 1995 Ford Contour
- Highway Hesitation or Jerk
- run hot when AC is on
- Buy Used Fuel Pump 00 V6 Contour
- please help
- 99 contour trans prob
- 2.0 DOHC motor timing belt/crank problem
- contour makes weird rattling noise...HELP
- reasonable price for a 1999 ford contour
- Can't get door panel off!
- water in oil ?
- adc turbo
- 1999 contour trans/speedo problem
- lookin for a supercharger for a 1995 contour 2.5L V6
- sparkplug gap
- Over heating Contour, any ideas...???
- overheating
- stalling car....HELP!!!!!
- 96 contour problems
- 98 Fuse for Courtesy lights
- leaking oil pan
- 99 Contour stalls
- '98 4dr Speedo & Fuel Gauge Quit At Same Time?
- Variable cam timing overretarded bank #1
- '95 - no cruise control, jumping gears, chk engn lt
- I4 timing belt
- 98 ford contour gl 2.0lt
- Fog light relay
- computer
- dies @ stoplight, idles rough
- New engine and mounts?
- Wheel bearings
- Thermostat
- ford contour overheating
- AC recharging
- where is the flasher on my contour located?
- Code P1518
- A/C Compressor Replaced
- 1998 Ford Contour Fuse Diagram
- 98 Ford Contour engine mounts?
- heater fan only works on high
- a/c - blowing only through the defrost vents
- running hot
- please help
- 98 Contour ventilation problem when it rains
- Air Bag light Problems
- Weird 98 ATX Problems
- 2 Problems Here, Getting Hot and hearing 5 beeps
- Timing Belt
- Transmission screwed??
- Transmission Filter Installation - 95 Contour GL
- 1998 contour overheating
- Multiple water pump replacements - 95 Contour
- '97 2.0 running hot
- Heat/AC only works on "High" setting '99
- contour 95 clutch change
- 98 Contour 02 Sensors
- 98 Contour won't turn over
- Fuel Tank problem
- Brake light problem
- door panel problems
- What do you think is faster??
- Help Please Alternator Horror
- no more 96 contour
- 2000 engine in 95 Contour?
- Oxygen Sensor
- 95 Contour SE Odd Trouble Codes
- another coutour running hot
- 98 Contour Lights "pulsating"
- Is the 5spd mtx trans any good?
- 98 contour running hot
- Fuel tank cover
- A/C & Heater fan function
- staling on start
- 95 Contour won't start all of a sudden
- slipping clutch or fuel filter?
- Used Contour
- dropped in an engine and no start
- 96 Contour. Detailed explanation.
- 95 contour help
- CD Player
- HELP!! Whirling Noise!!!
- '95 Contour LX power questions.
- 96 contour 2.0L, Bad idle in drive,like everyone else, any answers yet?
- what is better?
- Screeching
- contour w/codes p1131 & p171
- speakers
- battery won't hold charge
- Contour motor/vin number
- Contour temp unsteady
- Exhaust/Cold air or anyother suggestions?!
- 96 with check engine light
- 99 contour problems
- tachometer hook up?
- keyless entry programing
- losing power when going 65mph
- help
- where is the engine oil dip stick located in a 2000 contour 2.0L
- Water Pump Leaking
- Want to buy a contour
- transmision
- 98 ford contour
- 98 Contour hard shift 1st to 2nd.
- Newbie Here...
- check engine light code po136
- Stalling
- Head bolt torque.
- dead car
- Need to know how to wire a fan
- 96 Conour 'knocking'
- Changing head gasket and timing question
- stalling problem
- good bye
- 98 contour se getting code P1151
- 1998 Contour SE Air Bag Light Blinking
- Code P0708
- 95 contour, please help!
- temp gauge
- question
- Tire Rub or Suspension?
- Brake prob
- Dying car
- Check Engin Code P0401
- 95 contour
- What all do you need for a system
- maybe buying 1998 svt
- Bleeding brakes
- please help with this issue.
- System
- something is draining battery 1998 contour
- Timing Belt
- Buying SVT
- How to bleed cooling system, 96 Contour
- Svt
- Tires
- Lights
- 2000 Contour
- 1995 Ford Contour Won't Start
- 1995 alternator??
- Grinding Noise
- p0430
- Check engine light
- Wtf
- PCV Valve help
- 1996 contour need help
- 95 contour cruise control inop
- PLease help with 96 contour
- 98 countour won't start HELP
- 98 Contour grinding noise from engine
- Couple of Questions...
- wont start after installing new head gasket
- Rear Dash Pad Removal
- radiator fan install?
- Loud Fan Noise
- VCT Solenoid problem ??
- Newbie w/ Contour Issues
- 1997 Contour Idle
- '96 Contour battery problem
- 98 Contour GL possible transmission problem
- radiator
- Transmission Replacement
- '95 Intermitent Problem
- Recall information link
- 95' Contour Speed Sensor Code HELP!
- 1995 contour will not start
- 98 contour SE auto transmission problem?
- engine mounts
- HELP! my contour won't start
- 2000 2.0 contour engine
- i need easy power
- projector headlamps???
- 99 contour se 6cyl.
- 95 contour issues
- Reset Check Engine Light
- Engine ID 2000 contour need help
- Confused
- parts
- 96 Contour won't start
- in need of help
- what should I buy?
- 1999 Contour Lights / electrical problem
- Duratech
- Contour Problems
- Flasher Relay Clicking
- ?!?! Moosing sounds ?!?!
- 95 ford contour 2.0 for sale.
- 96 contour, changing plugs
- fixing vibrations in doors
- Gas Mileage
- how do i install headlights?
- No Brake Lights
- 95 Contour SE Engine Light
- tranny problems
- Sudden Loss of Power
- Alarm Wiring
- break lights
- installing power cable through firewall for amp
- My 98 Contour is garbage!!!
- 98 Contour Starting Problems
- intalling speakers
- air bag light blinking
- right directional not working
- Major Problems Please Help
- 2.0L Rough Idle Bad Throttle response
- Registration for Spring Zing 05 (May 19-22) is open!
- Ignition problems, please help
- 96 Overheating Problem
- weird heating problem
- New Engine help
- aftermarket upgrades
- '95 Contour 2.5L, Starter Replacement
- 1998 ford contour/transmission
- O2 sensors
- Front end issues!
- Rattling noise in front engine
- Rear Brakes
- rattling noise in rear-- suspension? struts?
- air bag deployed. car won't start now... like out of gas. Reset fuel pump? How?
- spark plugs
- 98 Ford Contour - ABS light on, No heater blower
- stereo installation(no acc on ignition)
- NO HEAT, LOW IDLE, CAR SHAKES, wINDSHIELD WASHER MOTOR NOT WORKING
- 1996 ford contour. courtesy lights flash on and off when turning wheel
- water pump difficulty level? 95, 4 cylinder.
- heater switch
- parking break light wont go off/lccks
- Starter 96?
