97 Contour Vaccum Line Layout
deaz
09-02-2005, 07:38 PM
Could someone please post a layout of the vacuum lines for a 6cyl 97 Contour? The car was in an accident, and they ended up pulling a hood off a 4cyl, so, not sure if they are the same...
Only reason I'm asking is because I keep hearing this low hissing noise coming from the passenger side of the engine compartment, but not quite sure what vacuum lines go to that side, since most of them seem to run right directly behind the engine, and to the drivers side. Which is as far as I can tell.
pre98zetec
09-02-2005, 08:59 PM
what's does pulling a hood off a Zetec contour have to do with Vacuum lines? I have a hood off a Duratec contour on my Zetec.
deaz
09-03-2005, 05:22 PM
Well, the vacuum layout on the hood MAY be different than the duratech... THAT'S why
beyondloadedSE
09-03-2005, 08:46 PM
the only hoses on the hood are the windshield washer hoses.
deaz
09-03-2005, 09:52 PM
Jesus christ... I'm talking about the STICKER that is on the HOOD that tells you the paths the VACUUM hoses take for the fucking engine. I am not talking about any hoses attached to the hood.
For someone that has a turbo in their car, you sure have no clue....
hallboy
09-04-2005, 06:58 AM
deaz. i don't have a V6 but you may try "if you haven't already" using a section of extra hose, with the engine running, hold one end to your ear and the other poke around under the hood till you find the air leak location. Carefull ofcourse not to get into the belts. It helped me find my leak. Good luck.
pre98zetec
09-04-2005, 11:41 AM
ive never seen a sticker on the hood for vacuum lines
badasstour
10-12-2005, 06:39 PM
go to a ford dealer ship they can give you a diagram
