View Full Version : Intrigue
Pages :
1 2 [ 3]
4 5 6 7 8 9 10
- Front right turn signal light not working ('02 intrigue)
- Time for New Wheels and Tires
- Blower motor stays on even after car is shut off.
- really stiff gas pedal?
- power steering hose
- Anti-Freeze Odors
- Cracked front bumper & headlamp assembly
- Intrigue Starting Problems '00 w/3.5L
- Replacing the coolant crossover pipe
- Hello. I'm new to this forum.
- Washer Fluid Pump
- replacing the rear valve cover gasket.
- Tranny fluid? Dexron III/ Or ATF4? 2002 Intrigue
- 98 intrigue..winter vs summer fuel consumption
- No Code, I/M EGR and Evap not ready.
- 1998 Oldsmobile Intrigue A/C
- 1998 Oldsmobile Intrigue HO2 Not Ready
- 98 Intrigue - Hard shift into reverse
- coolant sensor problems
- 3.5L Evaporative Emissions Canister Location?
- Alternator Replacement '00 Intrigue - here's how
- 3800 misfire @ idle HELP PLEASE!
- 3.5l Engine Replacement Advice
- Rough idle at first then smooths
- RF module?
- Clicking noise
- Help Me!!
- 2000 Intrigue--Service Vehicle, PCS, Trac Off Lights
- passlock or ignition switch
- Turn Signal Problem
- 1999 Intrigue 3.5 with a engine from a 2000
- 98 intrigue cd player says e20 ?
- Strut Tower Templates
- Heater Control Valve location
- Power Steering Gone
- No crank, P0340 code.
- High Mileage Lubricants Opinion
- 99 3.5L Intrigue MAJOR ISSUE
- Lambchop is not Intrigued
- Wipers just started stopping in upright position
- 2000 3.5 Intrigue running cool/poor heat
- Daytime Running Lights
- Adding Sirius to my Intrigue
- 98 intrigue intake manifold blew up. Any Help
- Blower Motor Not Working...
- 98 olds check engine light flashing & engine sputter
- 99 Intrigue stuck in park...
- coolant leak, water pump?
- Secondary Air Injection System
- Two Issues - Turn Signals and Dying on Corners
- giving up on the olds
- I'm ready for a road trip. '98 3.8.
- po101 code
- cyclinder 3 misfire
- 2001 Intrique
- 99 Intrigue power steering return line
- Wheel hubs / Tie rods
- Replacing Waterpump
- Window Issues
- Upgraded to 12 inch Brakes installed on car
- Block heater recommendation?
- Front sway bar replacement
- Replacing Your Cabin Air Filter (Or How To Install One...)
- 2000 Intrigue V6 Twin Cami
- Replacing Themostat and Thermostat Housing
- 99 Intrigue 3.5l, Hard Starting
- windsheild washers loose prime
- 98 acting odd (electrical)
- Cam and Crank sensors
- Wipers wont respond
- Running hot, cooling prob
- ANTI-LOCK ABS Light ON checked all wires
- Blower only works on High
- Low Coolant
- Wheel Hub or ECU?
- hot and cold air at the same time
- Won't start unless I pump gas
- MAF sensor output voltage?
- GMPP Handling kit drilling templates needed
- service engine, anti lock, trac light on
- Need new battery. Any suggestions?
- Bad High Beam Switch
- Changing Spark Plugs
- p0341 DTC on 02' alero
- Transmission whining after fluid change
- 99 Intrigue Starts then Dies
- 99 Olds Intrigue GLS 3.5, Random No Start, Ignition Switch?
- P0189 code
- Spark Plug Boots
- Taking out back seat 1998 intrigue
- Fuel Pressure Regulator (dealer or not)
- Ignition Switch Question
- Flushing cooling system without draining engine block?
- Battery dying after amp wiring install?
- EGR Valve Replacement
- 98 Intrigue Hard Starting - when warm
- 1999 Intrigue 3.8 Crankshaft Part #
- A cool gizmo and pics for eng monitoring
- White Smoke
- 99 Intrigue not running like it should
- Torque Converter acting up
- Bose Radio?
- '01 Intrigue: Gas Guage Not Working....
- P0446: Evaporative emission control system malfunction
- Radio Issue, please help !!!
- Cruise Control Issue
- Preignition pinging?
- Keyless entry on ALL 99's...are you sure???
- Transmisson fluid lube guard additive
- Which coolant? Green, Dex, Universal?
- Pics of cleaning the ignition switch security light gone
- 99 Intrigue - 4 struts replaced. Notes from the job
- heater not blowing
- 2001 Intrigue - Air Pump ?
- bad fourth gear
- Advice on replacing Rear Struts
- trans tune seafoam question
- Long term fuel trim is incorrect
- 99 Intrige won't start - acting stange
- My shifter button broke how do I change it
- Help with draining the antifreeze
- Window switch
- Is my climate control syst working correctly?
- sometimes sluggish somtimes not
- Pics of my tranny woes... YIKES!
- Disabling Passlock?
- Didn't see this coming, BLOWER INOP!
- 1998 V6 car shakes when shifting to Reverse
- New guy with a few questions...
- 98 Olds Power Steering Issue
- 2000 3.5L Intrigue running cool
- Power Steering Fluid needs to be changed
- fuse keeps blowing out
- AC only comes out of the driver side
- Thermostat project update....and then some.
- Need advice on a few things with my '98 3.8L
- 2002 Intrigue GX -- couple of problems..
- Coolant flush?
- Tranny Update--metal in pan! 02 49,000 miles
- feel my pain
- Getting Dealer only parts online in Canada
- blower resistor replacement
- Serpentine Belt Info Needed
- 02 GLS New to me @ 48000 miles-Thoughts.
- This is Nuts. I am on my 3rd Heater Core
- 2002 intrigue
- 3.5L possible major engine failure
- Brake Problem
- Orfice tube location!!
- Buying an Intrigue with issues
- A/C blows warm air
- Front wheel hubs & trust yr mechanic
- Which W-body cars had stiff suspensions?
- transmission - how do you know it needs service
- Problem with brakes
- Whats Limp Mode how's it work
- window issues - driver's side is the only control that works
- Paint chipping
- OIL leak
- GMPP trailing arms rattle
- Hydraulic Lifter Rattle
- whining noise with increased RPM's / Acceleration
- blower
- Installing fuel pressure regulator 3.5 engine
- Remote Trunk Lock Failure
- ABS Motor / Power Steering Issue
- Low coolant sensor
- AC cooling issue.. Cooling fans not coming on
- 1998 Intrigue
- After Market Stereo Problems - Wiring.
- leak when rains
- Coolant Leak
- Window Switch gone batty
- AC drain?
- Hot air/Cold air
- many problems, probably one source
- Polyurethane bushings
- No start event/Theft Deterrent Re-Learn procedure
- Airbag module
- 3.5L K&N Air Filter
- Squid treatment for my oil burner motor
- Tripod joint question
- ABS Sensor issues
- Secondary Air Injection Pump Problem
- AC Compresor not coming on
- Oil smoking When checking oil after running
- 1999 OLDSMOBILE 3.5 INTRIGUE Replacing the V-Groove Belt
- 98 intrique ac switch ?
- 98 intrique w/ rattle in passenger rear
- Wipers completely powered down
- What all do I need when replacing struts?
- 99 Intrigue 3.5L motor mounts?
- 99 Intrigue 3.5L. Loud bang noise now car won't start
- wipers wont shut off
- Just passed emissions 00 gx but have ?'s
- Climate Control Reads wrong on Outside Temp
- Intrigue Mileage
- Service Vehicle Soon and Trac Off lights.
- windows problems
- 1998 Intrigue Ac Blower
- Weird Stuff Happening 2000 Intrigue
- quick help needed
- In the middle of UIM & LIM gasket replacement, couple Q's
- emissions failure/check engine light. please help!
- Another starting problem
- 3.5L Intake Manifold Gasket? Coolant use, occasional stalling
- Doors unlock, but won't lock...
- 2000 3.5L sometimes won't start
- SES light, O2 Sensor(s)?
- Changing Blower Motor Resistor
- 3 vehicles with bad PCS!
- blinker problem
- Strange noise!!
- Crankshaft and camshaft sensor failure after replacement?
- Cleaning the Ignition Switch: I really screwed it up
- Front sway bar broken?
- 99-3.8, Engine stumbles at Times
- Directional bulb keeps malfunctioning.
- obd scanner recommendations
- antifreeze loss?
- Can anyone explain these codes?
- Metal Brake Lines
- Replacing the Bose Head Unit
- '98 3.8 upper & lower intake manifold gasket & plenum replacement help (kinda windy)
- Is the 3.5 Intrigue worth it in the long run?
- how to silence noisy brakes
- Trouble starting when warm; occasional shut down when driving
- 2000 Intrigue No Overdrive
- 99 Intrigue - troubling starting when car is warm - begins to idle rough
- Iridium IX Plug #TR55IX
- 98 Intrigue, burning oil now?
- 98 3800 wont start
- 2000 GLS 3.5L - recommended power steering fluid
- 1998 cluster replacement
- new hubs = noise..DAMN
- 2001 Intrigue; has power, won't crank or start
- factory stereo wire info
- 98 Olds Intigue.Code P0102 MAF/VAF What does it mean?
- Steering Gear Failure
- Olds Intrigue 99 Sunvisors Both Sides
- Bumping under front end of car
- What's going on with my car?
- trans problems
- 2000 intrigue 3.5 not starting after running out of gas.
- 2000 Intrigue - Turn Signal Problem
- 2000 Intrigue rear strut replacement
- Remove sun visor
- starter location 99 intrigue 3.5
- Third Brake Light Flasher
- Air dam
