View Full Version : Cougar
Pages : 1 [2] 3 4 5 6
  1. 3 questions
  2. 99 cougar 2.5l 5spd mount question..please help
  3. 1999 Cougar: head light lens blind
  4. 1999 mercury cougar blower motor replacement
  5. 96 COUGAR xr7 sport
  6. 96 Cougar 4.6 Vs 96 Mustang 4.6
  7. how to set the key fob on my 96 xr7 cougar
  8. 1999 Cougar loosing electrical power and all dash ok when restart.
  9. Unknown Short 94 Cougar
  10. This is where the PCV valve on the 2000 cougar is located.
  11. looking for 87-88 Cougar for sales
  12. 1997 Cougar 3.8L A/C recharging
  13. 2000 Cougar eating tires and loosing power
  14. Oil leaking out of top pulley
  15. 99 cougar clutch replacment???
  16. 90' cougar electrical???????????
  17. Idle Air Temperature Sensor
  18. 94 cougar wont start
  19. 2k: oil leaking out bottom
  20. Lights problem
  21. 93' Cougar - Loud Knock?
  22. fast idle
  23. 1996 Third Brake Light Bulb Replace
  24. swap
  25. 1999 Cougar Auto Transmission hums loud when shifts gears
  26. 99 crusie control probelms.
  27. I need help!!!! please
  28. 93 Cougar-radiator problem??
  29. wheel 91 Cougar
  30. 1997 cougar died and wont start
  31. 2000 Cougar loses power
  32. 1992 Cougar, HELP!!
  33. 1987 cougar leaks
  34. 2002 Cougar PVC valve location?
  35. 1997 3.8L Cougar Coolant Leak
  36. 99 Mercury Cougar heating/ac not working!?
  37. 99 cougar stereo system
  38. '99 Mercury Cougar Alarm
  39. smog pump locked up
  40. 1990 Mercury Cougar Brake Problem
  41. mystery problem in 92 cougar
  42. 1992 Cougar
  43. 94 couger won't start
  44. 2 problems
  45. 2000 Mercury Cougar Owner In Search Of Answers
  46. 86 cougar starting problem
  47. 92 Cougar leaky heater core
  48. 99 Cougar won't run in cold weather
  49. my 99 cougar is sick, please help
  50. my 99 cougar wont start up???
  51. 1996 Mercury Cougar: Head & Rear Lights Problem
  52. 97 3.8 Xr7 Wont Start!
  53. 90 cougar ls no air
  54. strange noise
  55. 79 Cougar XR7 Starting Problem
  56. 90 cougar signal lights
  57. I Need Tail Lights For My '85
  58. Rims, Idle, Fuel System
  59. 3.8L engine - serious oil leak
  60. 1996 cougar, electronic flasher
  61. PFE sensor 1989 Cougar LS
  62. Remote starter on a 99 Cougar.
  63. 2.3 trubo swap for 302 fuel injection
  64. 1997 Caliente (Super Charged) Cougar XR7 Electrical Problem
  65. 2002 Mercury Cougar 35th Anniversary Edition
  66. 1987 Cougar. Need help.
  67. 94 Mercury Cougar Xr7 Undercarriage Promblem Help Please
  68. Gas Leak $$$$$
  69. Checking CEL
  70. Alternator Exciter Problem
  71. 2000 Mercury Cougar - Please Help!!!!??!?!
  72. Cougar Not Running Right, Need Advice
  73. 2001 Cougar V6 - CEL: P0302, Hesitation
  74. 1991 Cougar - How to Re-Seat Serpentine Belt Idler Pulley
  75. 1994 Cougar XR7 SPEEDOMETER DOESN'T WORK.
  76. 91 Cougar - Is it Safe to Use Hand Torch on Seized Hex Bolt?
  77. help
  78. My '67 cougar
  79. My '78 is a christine...
  80. Good car?
  81. 94 cougar xr7 with 4.7 running problems
  82. K&N Air Filter
  83. Cougar Problems
  84. 99 Cougar V6, Parts or whole car for sale!!!
  85. oil filter housing replace
  86. oil filter housing replace
  87. Acceleration and Idle problem
  88. mount locations 99 Cougar 2.5L
  89. 98 - 04 Cougar Body Parts: Help please.
  90. Cougar - Strange Electrical Problem
  91. No Heat or Air Conditioning
  92. 2000 2.5L Windshield Washer
  93. 91 Cougar idle/coasting a little fast
  94. cassett player
  95. 1969 Cougar
  96. 1994 cougar charging problems
  97. 2002 brake pedal surge
  98. timing order
  99. problems with '97 xr-7
  100. 99 cougar steering
  101. Injection Pump Solenoid test, 91 LS 3.8
  102. floor mats
  103. 99 cougar wheels
  104. Shocks or struts
  105. A/C Not cold on 2001 Cougar
  106. 2002 Cougar 2.5L engine BLOWN
  107. 95 Cougar
  108. Brake Problems
  109. Battery/power steering...what gives.
  110. 2001 2.5 with a p0303
  111. 90 differential
  112. 89 cougar leaks when it rains
  113. 4.6 swap
  114. 68 XR7 Cougar Rear Bumper!!!!! Need
  115. bad trans leak 86 3.8
  116. Need help on driver's door hinge R&R
  117. 99 cougar alarm system problem/need help
  118. 2000 Cougar Trans problem!
  119. 1997 Cougar XR-7 Front Strut Replacement
  120. engine 8g or 9g?
  121. Help! Keyless Entry programing for 99 Cougar
  122. How to know if my 1999 mercury cougar comes with keyless remote
  123. Cougar just dies but will restart after setting
  124. Removing back inside panel
  125. Locking Mechanism Issue
  126. 95 engine knocking after going through bad puddle
  127. this is very bad...
  128. 97 cougar no cold air
  129. 95 rx7 ? hum starts and then wont ?
  130. 2001 Mercury Cougar 4cyl 5 spd missing
  131. 2001 Mercury Cougar upgrades
  132. 89 cougar digital dash
  133. heater core removal????
  134. 99 Mercury Cougar Drivers Side Window
  135. cold air intake
  136. 99 Engine Mount replacement
  137. 1994 3.8L Cougar Won't Start
  138. AC fan and Defroster Stoped working..
  139. New blower motor
  140. building power
  141. Spoiler Help
  142. ahh..blower resistor replaced
  143. clunking noise
  144. 95 cougar 4.6 bogs down
  145. 1994 XR7 Electronic Transmission Prob
  146. 1994 XR7 Electronic Transmission Prob
  147. Owners manuel
  148. ac/heater stopped working
  149. how do i make my 1997 cougar lighter?
  150. 99 Cougar Transaxle Light
  151. No Battery Power
  152. 91 cougar trans?
  153. no vaccum
  154. 95 Cougar crankshaft position sensor
  155. Question about my gas gauge!
  156. 1993 sputtering??
  157. 1979 CLuster Gauge
  158. 94 Cougar Xr7 Fuel Problem
  159. 99 cougar V6 Break switch
  160. Instrument cluster LED...or...fuse?
  161. Excessive EGR code
  162. 1990 digital dash Problem!
  163. 91' Cougar, Losing Anti-Freeze
  164. 96 Cougar, EGR valve?
  165. 3.0L Duratec Boring and Stroking
  166. Attenuator
  167. V6 5spd '02 Cougar -- Best Course for Power Upgrades
  168. 94 Cougar console
  169. 94 Cougar fuel filter
  170. 94 Couger
  171. Charging problems
  172. grille
  173. 2001 COugar Lightbulb Replacement
  174. stater swap?
  175. 99 Cougar headlights dimming
  176. 89 wont start, fuel gauge says CO
  177. 99 Cougar Brake Lights
  178. 1999 Cougar Wont run in cold weather
  179. '99 cougar-heat not blowing very hot air
  180. '96 Cougar XR-7 odometer stopped working
  181. 93 cougar engine swap
  182. Rear Spoiler
  183. Odometer display out
  184. 96 Cougar original battery!!!
  185. oil change counter
  186. 90 cougar dash/radio
  187. '99 Cougar Speedometer
  188. 8.5 inch 4.11 posi?
  189. lug nuts
  190. check engine light
  191. 95 cougar stalling
  192. Alarm?
  193. what year cougar should i get
  194. having problem with my check engine light
  195. 99 Cougar 2.5 v6 5 speed will not crank
  196. 99 cougar changing alt
  197. "Lost years" Cougar needs help
  198. see ya!! my cougar is gone!!! yea
  199. see ya!! my cougar is gone!!! yea
  200. 1994 Cougar XR7 3.8 V-6 exhaust leaks, easiest way to fix?
  201. Help!..Blower Motor Controller!
  202. HELP! Mystery Cyl #1 & #5 Misfire...
  203. 99 2.0L engine
  204. How to know???
  205. Heater problems with '01 Cougar
  206. 99 Cougar brakes growl in reverse.
  207. I need help with my 90 cougar
  208. 96 mercury cougar
  209. 99 cougar 2.0 won't start
  210. 1993 XR7 NOX high
  211. one more problem
  212. 96 cai?
  213. 97' cougar shaking...
  214. 1993 Mercury Cougar not starting.
  215. More power to my 1981 Cougar XR7
  216. HELP with odometer problem 94 cougar 4.6
  217. dfarr
  218. electiccl problem
  219. FREE somebody please take these parts off my hands 77-79 cougar FREE
  220. New owner
  221. What is wrong?????
  222. Transmission Range Sensor P0708
  223. overdrive problem
  224. Idle Problem
  225. 1992 cougar/tranny won't shift
  226. 99 Mercury cougar starting problem
  227. 94 cougar v8 smoke? gas smell? shaking? loss of power?
  228. 67 Cougar
  229. Oil smell
  230. 99 cougar idle problem
  231. 96 Cougar help
  232. 95 cougar electrical problem
  233. 1990 Cougar V6 3.8 running problem
  234. 1995 cougar stereo installation Help!
  235. 1986 cougar xr7 2.3L turbo wheel/rim offset
  236. 1999 cougar stuck in gear
  237. Has anyone replaced a heat/ac switch in their Cougar?
  238. back lights don't work.....
  239. 1994 Mercury Cougar Fuse box diagram
  240. oil filter problems
  241. 97cougar whines in first gear
  242. 2001 Cougar Stereo Wiring
  243. 2001 cougar???
  244. 99 Cougar Brake Job
  245. Wining sound while driving my 2000 Cougar
  246. Trans finally shifts around 7,000 rpm
  247. 1997 Mounts above raditao?
  248. 1992 Cougar Idle Question
  249. Bezel Help??
  250. 00 Cougar odometer problems
