View Full Version : Cherokee
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22
  1. Slow cranking and stalling
  2. just dies?!
  3. Lift?
  4. Speedometer off due to large tires?
  5. Emissions Help
  6. overheating 91, 4 litre- complete battery discharge
  7. stumped,won't start
  8. 89 jeep cherokee
  9. is it the starter?
  10. Start
  11. Knocking Noise
  12. Jeep Patriot
  13. 1998 cherokk classic questions
  14. stroking tips
  15. 4.0 block 1988 cherokee jerkin
  16. Blower motor quits when running excessively
  17. Clutch pedal stuck up can't depress it
  18. Extra Temp Probe
  19. Neutral Safety Switch...Girl asking
  20. Does the following even exist?
  21. 93 XJ aftermarket/replacment bodyparts
  22. '93 Cherokee Sport 4.0 for sale
  23. 94 cherokee sport diagnostic codes
  24. 1997 cherokee sport 4.0 engine change
  25. Crankshaft Pulley Seperated
  26. engine overhaul kit????
  27. 1989 Jeep Cherokee egr vacuum solenoid operation and wiring
  28. 1990 cherokee; looking for transmission fluid filter
  29. Back pressure
  30. Engine Swap
  31. won't start when cold
  32. auto tranny not shifting
  33. 88 Jeep brake light switch connections
  34. check engine light
  35. 88 4.0 vacuum picture
  36. 96 Cherokee Radiator question
  37. 96 xl Seats any aftermarket seats ?
  38. 2000 Cherokee brake lights
  39. Newbie/ Headlights...
  40. this is kind of weird.
  41. 86 jeep electrical help
  42. compression test -results
  43. Bolt size for electric window regulator on 88 XJ?
  44. Need new seats for 1992 Laredo...ouch!
  45. Looking for a wiring diagram...
  46. best way to get best MPG?
  47. 88 Cherokee loses power, backfires, stalls
  48. 87 5speed tranny, which one is it?
  49. 91 cherokee horn
  50. 1998 Voyager, starts intermittantly
  51. Catalytic Converter support bracket
  52. 88 4.0 timing
  53. Dashboard Gauges work intermittenly
  54. No Spark 86 Cherokee
  55. Temp gauge & Hazard lights
  56. stuck water coolent temp sensor
  57. dropping the tranny pan
  58. 93 Jeep XJ
  59. just became a jeep owner
  60. 97 cherokee bad idle
  61. neutral safety switch
  62. Ran out of gas know won't start
  63. How I replace the fan clutch in 96 4.0L
  64. jeep takes forever to start...
  65. Jeep Radio
  66. Can Someone Help Me out With Some ECU Codes?
  67. reattach front diff vent hose
  68. 98 Cherokee Power Door Lock switches not working
  69. Roof Rack Mounting
  70. Knocking Noise 88 Cherokee
  71. Alternator replacement-97
  72. starting woes
  73. 1989 jeep cherokee limited edition
  74. 1990 cherokee won't stay running
  75. To Buy, or Not to Buy
  76. 2000 Jeep Cherokee - Check Gauge Light
  77. window gets stuck in down position
  78. A/C compressor noise
  79. '96 cherokee 2WD front bearing / hub replacement - need help
  80. Trans oil pan?
  81. 97 cherokee read check engine w/o scan tool?
  82. gas
  83. 2001 Jeep Cherokee Spark plugs
  84. 95 cherokee 4.0 no spark
  85. 2000 Cherokee Neutral Safety Switch
  86. 1989 Jeep Won't turn over
  87. steering column needs putting back togethor
  88. 4.0 block 1988 cherokee
  89. 85 v6 to 4.0
  90. Buying a 2000 Jeep Cherokee XJ
  91. Jeep Service Manual Question
  92. Cables and linkage
  93. Trans ID
  94. power window shot...
  95. Stumped with the wifes jeep
  96. 2000 Cherokee code P0740 torque converter
  97. Electric Fan Question
  98. Replacing Heater Core Jeep Cherokee '00
  99. A/C problem in 99 Jeep Cherokee.....
  100. Replacing Battery Cables
  101. 2000 Jeep Cherokee 4.0L overheating
  102. Aftermarket Camshaft
  103. Idle problem -- IAC motor
  104. need new seats for 88 jeep cherokee
  105. 88 cherokee,no spark
  106. reverse lights not coming on...
  107. stupid issues????
  108. trouble codes????
  109. overheating, found problem. now new one!
  110. 95 Jeep Grand Cherokee won't start
  111. Carpet Resources Anyone???
  112. sensor question
  113. 88' overheet jeep
  114. AC Fuse
  115. Jeep won't start with the key
  116. Temp gauge acting NUTS
  117. 1989 Cherokee runs like crap!
  118. 1999 Jeep Cherokee Turn Signal Problem
  119. 88' cherokee tranny
  120. wider wheels?
  121. Narrowed down noise still ??? PLS HELP
  122. Hood Release Cable Broke!
  123. Heater Hose Routing
  124. 89 model for 95 engine swap
  125. 96 not charging
  126. Engine Noise-Taping valves
  127. 92 running hot, loses power, codes 21, 52
  128. NoX not Good
  129. a/c turns on and off
  130. fender trimming
  131. cannot pass emissions any suggestions?
  132. Torque Converter Clicking?
  133. heater/ac
  134. Coolant Bottle/Tank burst! Why?
  135. 2.8L spewing oil
  136. Front Door Hinge---Pin worn out
  137. lost keys
  138. running rough 97 cherokee
  139. Fuel Smell/Leak - 95 Cherokee
  140. Install power lock on rear door
  141. 87 grand am se 3L starter problem? maybe?
  142. Now THAT's a Full Size Jeep!
  143. Jeep just dies!?!?
  144. Information needed on the two fans 1999 JGC
  145. 98 cherokee starting problems
  146. Front end noise
  147. 01 Cherokee Sport feedback please
  148. 92 4.0L Overheating like crazy
  149. 4WD high and low problems
  150. 89 cherokee dash and tail lights
  151. Crankshaft or Bearing noise?
  152. Fault Code
  153. Exhaust Headers
  154. Instrumental Cluster conversion
  155. Power windows and lock problem 97 Cherokee
  156. Even the dealer mechanics are puzzled
  157. 99 Cherokee "no bus" Error
  158. jeep problems again
  159. Cherokee no start
  160. Door Lock Stuck in Unlock Position
  161. power window help 99 cherokee
  162. Thermostat and hard starting
  163. Overhead Console Help
  164. Radiator Drain Plues
  165. 95 jeep won't start
  166. 2000 cherokee fan control
  167. electronic control module??
  168. engine knock
  169. 97 Jeep Cherokee Grand
  170. 89 cherokee with fan clutch
  171. Pt 4wd
  172. higher ratio rockers?
  173. fuse locations
  174. Help!!! Noise from rear!!!!
  175. Throttle Position Sensor - '92 4.0L 6 Cyl Auto Trans
  176. 87 Cherokee - air in radiator
  177. Spare parts available
  178. Tranny revs high
  179. Steering--won't go back to center
  180. blower motor
  181. 1986 Jeep Cherokee
  182. Engine miss at operating speed
  183. grinding brakes
  184. 1999 XJ Wheels (Compatibility?)
  185. Parting With '92 XJ
  186. xj problems
  187. 2000 Jeep Cherokee Sport - Engine Noise
  188. Ignition Switch, 88 & 89 Cherokees
  189. no fuse diagram for 2000 jepp cherokee classic
  190. Front hubs not disengaging?
  191. won't shift
  192. Violent shake from front end!!!!
  193. Headlamp
  194. Installing Shocks on 99 Cherokee Sport
  195. stuck power window
  196. Engine Problems in a 2001
  197. R12/R134 conversion
  198. 1996 Cherokee Sport for sale
  199. lift for an 89
  200. Fuel and starting problem
  201. A/C blows hot air only??
  202. Bleeder valve for 1991 Cherokee
  203. Ive got a coolant leak!
  204. 95 Jgc
  205. yet another A/C problem (with good reason)
  206. 1995 Cherokee fuse diagram
  207. 1994 Cherokee Country keeps blowing fuse #2
  208. Shock removal and air hammer
  209. check engine light
  210. AC problems
  211. won't start sometimes
  212. high oil pressure
  213. Trans/Power switch
  214. 89 cherokee won't crank
  215. 88 Cherokee Blower
  216. Turning the steering wheel = Noisy problems...
  217. oil in air filter fix
  218. exhaust/lift
  219. ac blows out of defrost only
  220. 96 Cherokee Won't Start
  221. Wing windows
  222. Coolant leak...1990 ???
  223. leaf springs
  224. headlights won't turn off
  225. Now THIS is an A/C problem
  226. Drivers door problem
  227. Experienced the Death Wobble this morning!
  228. A\c Works For 30 Mins
  229. Ignition locked up.
  230. 2.8l 2.5l question
  231. Motor Broke - Fix, Replace, or Dump Car?
  232. 2.8l cruising speed question
  233. remove key lock cylinder 92 charokee
  234. Transmission Issues
  235. Front end noise
  236. 89 Jeep Help
  237. Shocks for 93 Cherokee
  238. Jeep died while I was away ???
  239. Power Windows no stopping
  240. Cherokee A/C leak
  241. AEV 570 Hemi Jeep
  242. Looking for information
  243. '97 Cherokee Question
  244. cant locate radiator drainplug on my cherokee
  245. A cheap lift for '89 Cherokee
  246. brakes
  247. Fan Clutch/Running Hot
  248. Another tailgate question...
  249. installing window channel on 91 cherokee
  250. Tire size question
