Front end noise
pete44
07-12-2005, 07:04 AM
Just put on new tires on my '94 Cherokee Sport.(130,000 miles) I thought this noise was coming from old tires..(have not had it very long)...It is a "thumping" noise from front end until I apply brakes...The thumping speeds up and down with speed of vehicle...It is a 2WD...Could it be a brake/rotor/caliper problem?......Thanks,Pete44
mrbill3
07-12-2005, 10:39 PM
It sounds like either a warped rotor or maybe a bad wheel bering.
Bruce200
07-13-2005, 01:30 PM
I've got the same problem, but I just replaced the wheel bearings
and it still didn't help, $100 later, Any other Ideas?
Bruce200
07-13-2005, 01:39 PM
I've got front end noise, replaced-rotor,Wheel hub assembly.But is the front axle housing supposed to be packed with grease and sealed with a little rubber boot, cause mine ain't. Any Ideas?
mrbill3
07-13-2005, 10:46 PM
They don't have CV joints (rubber boot packed with grease). Since you replaced your bering/hub, is the noise/vibration gone?
pete44
07-14-2005, 09:52 AM
Took my Jeep to top-line tires and they had to replace rotors and did rear brake job...FIXED my problem!...no more noise and it stops on a dime...$205.....(ouch)save you $90 in labor if you do it yourself...Hope this helps....Pete44
4x4grey88
07-14-2005, 03:45 PM
One way to check if it is a bad bearing is to jack up the front (tire off the ground) and try to move the wheel both side to side, as well as up and down. If it move abnormally its a bad bearing.
If not, its probably a bad (warped) rotor. You can only remove so much metal from the rotors, so I recommend that you find one of those 'life time guaranty' brake shops and replace the brakes. If you do some home work you can find a good sale on these repairs.
You can probably do this your self, but if something goes wrong in the future you stuck doing it YOURSELF all over again. The 'lifetime' thing makes them do the work for little to no cost for you.
