View Full Version : Rodeo | Passport | MU
- Rear Speakers 5" ???
- replacement shocks?
- Calmini Shocks F&R for sale - Rodeo
- CHECK ENGINE light on 2000 Rodeo
- Trouble starting Rodeo after driving for a bit.
- Changing shocks
- Valve cover gaskets
- Anybody heard of the Inhibitor Mode Switch?
- Fuel Sending Unit again
- Looking for parts
- Fuel Econ
- 1992 Isuzu Rodeo For Sale
- Rodeo Running Like a VW! AAAAHHHH!
- Engine whine 2000 Rodeo?
- broken rear glass/defroster AGAIN
- suspension question
- it's not the hood hinges
- new guy here needs direction
- Starting Problem - not consistent
- US/CND Warranty Issue
- no juice to fuel pump
- 94 rodeo 4x4 tranny ?'s
- white face gagues replacment?
- 4l30-e
- Brush guard recalled
- Deafening scream when started
- new spark plugs
- high idle
- 1/4 times
- 98 99 00 01 Isuzu Amigo Rodeo Altezza Tail Light
- This board is wonderful
- What is the smaller pan under the tranny on a 2001 Rodeo?
- 99 rodeo OBD II PO171 problem
- Need clip that hold headlight bulb secure - 95.5 rodeo
- p1627 pcm a/d conversion malfunction
- How to check transmission fluid 99 Isuzu Rodeo??
- 2000 Rodeo has no power
- squeeky
- 95 rodeo...ticking sound and low oil pressure
- hesitating when moving
- changed plugs now have check light
- Dressing it UP!!
- Vehicle Speed Sensor- (question!)
- t-belt tensioner diagnosis
- 95 rodeo having problems starting someone help!!
- take off
- 1994 Isuzu-Rodeo, V6, 5sp - Clutch is down to the floor.
- 2001 rodeo check trans and cruise set light
- 4 cyl gas mileage
- What is my Rodeo supposed to idle at?
- 1995 Diagnostic wire location hekp
- EGR valve
- Tunking Starter
- 96 Rodeo ECM
- Need help looknig for a particular kind of brush/grill guard...
- Anyone has fender flares on their 99-01 rodeo?
- Heard that we have a Chevy engine...is that true?
- Gear ratios for 91 to 97
- Isuzu Rodeo 1994 Plug wire loose and moving...
- 2000 rodeo stalls when idle, check engine confused
- dealer repair rates, too high?
- slow to get up to speed
- isuzu off road stores
- tranny flare
- Exhaust Leak?
- problems and i'm in a big hurry
- '92 Shuddering Power Loss...
- Modifying Differential Breathers????
- rattle in front between wheels and or dash
- A/T Oil Temp (light) and my 1996 Rodeo
- rim bolt pattern and offset
- Oil around spark plugs???
- Knocking Noise/Lifters?
- Major thumping when shifting
- Fuel Sender Replacement - need calibration?
- Rodeo 2000 Bumper
- High Idle Problem - V6
- Who's got the best prices?
- Need help with fuel pressure problem
- 97 knock when turning
- Ignition Interrupt - 96 Rodeo
- will roedo parts work on my pickup??
- 1995.5 Rodeo Temp Guage
- rear tire high pitched noise
- passenger side window only opens three inches
- Need some brake parts
- Brake lights fuse blown
- How much Tranny Fluid normally comes out on a drain/fill job????
- clutch down near floor
- 1999 Rodeo - ABS motor keeps runing (even with the key off)
- rear transmission seal
- Error codes P0171-P0175
- lift kits
- Tranny wiring diagram
- 1995.5 burning lots of oil
- wheel fiting
- Puff O smoke after starting
- Back-up lights won't work
- brake and battery dash lights are on
- A/T , Power drive and Winter Drive Lights flashing on accel. Engine losing power
- What LDS additive did you guys use with Gear oil (GL5) for the diffy?
- Wind Noise
- Tips on filling tranny fluids.
- Feeling Knocking in Clutch Pedal
- Trans
- 6vd1 engine rebuild....kit or motor needed
- 2000 center caps
- '95 3.2L V6 Timing Belt
- Torsion
- clutch fluid for 92 Rodeo
- 4l30e tranny question
- PLEASE HELP!!!!!Cel, Rough Idle, and more
- 2001 noise
- 1992 Rodeo Turn Signal Probs
- 1993 Rodeo 4L30-e A/T problem, HELP
- brush/grill guard
- 00 Rodeo, better washer nozzles?
- I got a CEL with code 1404 after cleaning out the EGR Valve
- Dealer says fuel pump not covered, '00 Rodeo
- Bad Heater Core, 97 Rodeo
- Fuel Sending Unit -- Recall in 6-8wks
- random missfires
- ABS Light on
- Projector Beam Fog Lamp Light Kit Isuzu Rodeo Amigo
- Universal Code Reader, OBII, 39.99
- 92 Isuzi Rodeo Trans Problems
- help decide on 94 rodeo purchase
- timing belt push rod assembly
- rodeo 94 photos
- how do your get to the brake lights
- changed plugs, T belt next
- '96 rodeo starter problems/changeout
- 92 owner's manual pages missing
- 94 rodeo starting problems
- Bucking Engine, No Power, Spark Plug Questions
- What Should I Do with My Zu?
- window motors or the switch
- 1993 Rodeo Trans Shift out of Overdrive
- 93Rodeo
- Amigo-2K, What's a "Slip Yolk"....
- high oil consumption, CEL, hard start
- ABS problems??
- Valve cover time
- keyless entry
- tire sizes
- New engine mod
- improved ride
- 01 Rodeo Shutting Off Turning Corner, Bucking During Acceleration
- not to expensive mods
- 96 electrical prob's (cel, turn signal, rABS...)
- 92 rodeo back seat
- Help on changing rear differential oil.
- audio question
- Vehicle recall details
- Rear Defroster Help
- 6 CD changer died
- 2 questions - lighting & knock
- 97 Passport Oil Pressure
- cure for code 32
- Tensioner wabbling after T-belt R/R
- Isuzu Rodeo Two Rear Doors Will Not Open
- A question for those that have changed their timing belt.
- Loud Knocks at low speeds on driver side
- Serpentine Belt - Tensioner
- Warranty issue
- 99 Rodeo CEL error code P0171
- Timing positions 1997 Rodeo
- FAQ 98-04 Isuzu Rodeo
- 1996 2.6L 4-cyl in need of new thermostat
- T-Belt tensioner?
- 1995 Rodeo 220K 3.2 4x4
- 1997 keyless entry remote
- 99 rodeo -Bad gasmileage & Erratic fuel gauge
- Fuel Pump on 1999 rodeo pls help
- IsuzuTuner.com
- Drivers side window not working 95 Rodeo
- 1997 Rodeo Work
- cure for code 32
- Replacement Seats/Headrests?
- 2000 isuzu rodeo p0300 stalling, rough idle
- 2000 Rodeo 4WD LS transmission leak
- rodeo 100k+
- Att. 2eyefishclaw Re: 2000 Rodeo APP sensor
- 2000 - Did P0401 work, EGR valve bad?
- 97 rodeo parts for sale
- Smells like unburned gas and bad mileage?
- OBD II Scan Codes P1311 & P1312
- HELP !! Need 95 Rodeo 3.2L 4x4 Assist
- 97 Rodeo Steering
- Rear Wiper Control-Can I Bypass It????
- Timing chain on 4 cyl 95.5
- Auto Trans Temperature Gauge?????
- 99 Rodeo blown tranny
- 2000 V6 TPS adjustment
- PLEASE help quick !! '01 Rodeo Check engine light/$400!?!?!
- removing a '03 rodeo head unit
- wheel offset?
- Hard Starting
- Isuzu Dealer shutting down and clearing out
- '01 rodeo problems.......HELP!
- window regulator gone bad
- Problem starting my 98 V-6 Rodeo
- rear brake calipers
- shudder and noise in rearend 1991 rodeo
- 1999 Rodeo Wont Start Previously Drove Through a Puddle
- 1992 3.1 stalling
- O2 Light
- rodeo 2000 turn signal problem
- 93 rodeo knocking
- hard starting
- IMG Failure?
- Passport Stalling
- clutch
- 93 Rodeo Fuel Pump
- left turn signal speeds up with acceleration
- CEL and bad fumes
- added photos to my gallary
- Any "BULLETIN" or recalls on the 2001 Passport?
- Any "BULLETIN" or recalls on a 2001 Rodeo/Passport?
- Would like to put in 87 octane, but car seems to ping. Any suggestions?
- Anyone installed a open "cone" air filter on their 98+ rodeo/passport?
- Rodeo won't start - advice requested
- Is Your Oddometer/Speedometer Right?
- Check Trans and Engine light (code P1870)
- 3.2L Rodeo squeal on startup
- check engine light
- Truck wouldn't turn over but does after push
- 97 Rodeo: no back up lights
- 2000 Rodeo Idles Rough, Stalls, and CEL
- need help finding parts
- 98 Isuzu Rodeo 2.2L Sludged Engine
- anyone know where to get black fender flares for rodeo isuzu?
- 1992 isuzu rodeo 3.1 ecu connector location?
- Brake Light Replacement
- Electrical problems
- Check Engine and Trans light
- gas mileage for 98 rodeo
- 1993 Purchase: Specific problems to look for??
- 2002 w/ Overheating prob
- 4l30e transmission problems
- Help on changing Tranny Fluid...please...???
- door locks?????odd
- Left rear end chatter
- 97' Rodeo with only 13mpg?
- Are there any other good Rodeo forums?
- Were is a good place to get a 01 Rodeo Brush Gaurd?
- !! 93 Rodeo Belts and Hoses !!
- 1997 isuzu rodeo over heating
- Rodeo Tire Sizes??
- bluing on spindles, slight chatter marks on bearing races
