View Full Version : Prelude
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
  1. punk'd boss's ride
  2. Top speed thread closed?????
  3. 95 vtec head on a 00 block
  4. 96 H22a into 93 prelude body
  5. Engine swap problem
  6. good deal for turbo??
  7. serios problem, need some help please
  8. where to buy ludes?
  9. h22 in a 89 lude?
  10. tail lights ??????
  11. h22a idle problem
  12. engine
  13. cant decide
  14. throttle body cleaning?
  15. 1991 Honda Prelude Si 2.1 engine has a problem
  16. 89 Prelude Rough Idle, engine dies
  17. Low Fuel Indicator Lamp
  18. How Can I Get My 98 Lude Lighter
  19. Sold My Prelude This Morning, Good bye
  20. totaled 92 lude
  21. Prelude mods?
  22. exhaust
  23. Tein suspension
  24. h23 dropped in accord - newbie question
  25. approaching timing belt change time
  26. approaching timing belt change time
  27. regarding buying a prelude..help
  28. this is gonna sound dumb...
  29. 92 prelude problems
  30. ABS light
  31. Speedo off??
  32. 91 prelude Si RPM is running high
  33. h22 or K20 swap????
  34. if i should buy this prelude?
  35. Whats next for an F22a?
  36. are h22 parts interchangable with h23 parts
  37. P13 ECU and H22 Valve cover
  38. 94 prelude vtec vs 91 300zx 2+2
  39. diagnostic plug location/knock sensor
  40. Sup, I'm a brand spanking newbie
  41. Tachometer installation?
  42. 88' prelude relay/fuse layout?
  43. tranny, fuel pump or fuel filter clogged? help!
  44. Serpentine belt schematics?
  45. 92 prelude Brake light problem, pls help
  46. Slotted Rotor direction
  47. surging
  48. 98 JDM F20B on a 01 H22a4
  49. 1987 prelude si performance
  50. What Clutch Is Best
  51. Belts for JDM
  52. Help Me!
  53. Insane NA HP.
  54. 4th gen Si PWNS LAPD
  55. I need your 2 cents
  56. Engine!!!
  57. PReLUde HiGHeSt Possible Horsepower???
  58. Turbo PReLude .. H22+H23 ?
  59. gf can't reach clutch
  60. p13
  61. I need help diagnosing a problem
  62. Factory suspension question~
  63. Radio and clock
  64. OBD question
  65. help
  66. 95' prelude swap?
  67. Fog Lights...again
  68. Rifled Throttle Body Spacers?
  69. help please
  70. superchargers
  71. Linkage or Tranny?????
  72. Header Changing Color
  73. Distributor Seal...?
  74. stalling in the rain
  75. How do I race?
  76. Wierd knock in wheel well.
  77. Turbo-ing Model S
  78. Fully built h22 head 480 miles, crower everything
  79. brake lamp light wont go out
  80. TorqMaster Sparks
  81. Need a driver side door
  82. h22a4 in a 92 si need help
  83. leaking fluid from tranny
  84. Electrical problem in dash
  85. Turbo 90 si?
  86. Please HELP someone must know rhis?
  87. anyone know about the 3rd gen trans
  88. ouuucchhhhhhhhhh !!!!!
  89. skunk 2 cam gears, need help
  90. Car won't start/crank
  91. ***92 Prelude Engine LOUD SCREECHING NOISE Coming from distributor area***
  92. 3 inch exhaust
  93. Tachometer is spastic
  94. 88 Lude Shifter cable
  95. 2nd Gen parts 91 prelude I NEED
  96. little bit of white smoke
  97. Clogged fuel sytem?? Help
  98. Wont Start
  99. engine buildup questions
  100. 02 sensor
  101. Prelude starting problem
  102. proper way to store the prelude?
  103. My headlights aren't working right *need help*
  104. Broken sway bar
  105. The Ludeness of it all
  106. problems when it rains
  107. vtec controllor?
  108. 92 with 166k
  109. Ebay Coilovers for $20!?
  110. Neutral Dropping?
  111. Instrument panel and all dash lights going out
  112. Major oil leak
  113. steering wheel shimmy
  114. Having trouble with the door panels..
  115. Vtec?
  116. 1982 Prelude bumper specs?
  117. R33 Skyline Conversion
  118. 1989 prelude headlights stuck in up position
  119. Alpha Werks?
  120. Which Exhaust?
  121. Fuel Efficiency Optimization Mission
  122. 2G Tire Size Question
  123. Need Head
  124. 4th gen prelude ..Whats the differences in year and trim models?
  125. 93 prelude problem
  126. ECU - Air Conditioned
  127. Heated brakes
  128. misfires, stalling, stellar handling!
  129. wheel berrings
  130. 95 prelude si h23
  131. A Problem help!!!!
  132. Fog Light Covers
  133. Fan trouble '85 Prelude
  134. 89 honda prelude
  135. Blue Lights at night
  136. Fender Liner
  137. Exhaust time
  138. 95 prelude h23a idle problem
  139. Update On 90 Prelude Starting Problem
  140. The Rights of Automotive Hobbyists - NO MORE UNLAWFUL VEHICLE INSPECTIONS -petition-
  141. 86 lude going down !!
  142. Replacing Oxygen Sensors
  143. Alittle Help
  144. Cruise Control Problem!!
  145. Aem Short Ram
  146. 2nd Gen Ignition Mods?
  147. Short ram
  148. Has anyone actually replaced their own clutch and/or timing belt?
  149. anyone at all
  150. she's smokin
  151. what's your top speed?
  152. What Should I Do? Please Help!
  153. door panel etc.
  154. dead battery!?!?!?!?!
  155. need a H23 motor!!
  156. ABS Brakes
  157. who has ebay intakes?
  158. My Prelude Is to Loud
  159. more help, clock went out!
  160. ATTS leak when under pressure
  161. 92 prelude need major help
  162. some advice from the expert please
  163. 1989 lude motor swaps!!!!!!??????!!!??!?!?!?!?
  164. screwed up tranny??????????????????
  165. Help! ABS light and master cylinder problem Help!
  166. Where is AcesHigh?
  167. question about brake caliper piston?
  168. slow
  169. Starting problems
  170. looking for gear heads near akron ohio
  171. Recall "SeatBelts 92-94 Ludes"
  172. Lude Vs. Celica
  173. Engines
  174. Am I hurting my LUDE
  175. Help me decide what rims to get
  176. Whats causing this?
  177. Ok whats going on here!!
  178. What RPM
  179. engine light problem
  180. Srs??
  181. Lude speakers
  182. 93 prelude VTEC owners?
  183. Vtec from a 97 Lude into my 92 Si
  184. Single Or Dual
  185. No VTEC?
  186. Tsudo Cat back
  187. slightly confused
  188. JDM Power folding mirrior instal?
  189. buying 92 prelude w/ blown engine, after searching still h22a q's
  190. my lude is trippin
  191. preludehead change q
  192. 97-01 Blackhousing headlight idea
  193. Whaddya think?
  194. for sale
  195. 93 prelude si
  196. locked radio
  197. easy radiator question
  198. power door lock and window problems...help
  199. how to activate SRS
  200. vtec rotors vs. si rotors
  201. Questions Questions and more Questions
  202. Good Deal?
  203. fast cars just arent as cool anymore
  204. i need help with my swap
  205. Motegi MR7?!?!
  206. Radio/Clock/Key Less Entry
  207. true jdm h23a
  208. weird problem
  209. exhaust, header, intake what brands will give me the most HP?
  210. jdm headers
  211. carb problem?
  212. Just got a Prelude
  213. Prelude Eyes
  214. Trouble finding 89 prelude compressor control unit, please help
  215. Trouble finding compressor control unit, please help
  216. Having trouble finding 89 prelude a/c control unit
  217. exhaust fiting h22
  218. Exhaust Gasket
  219. Clutch has alot of freeplay
  220. Prelude Si staring issues
  221. h23 crank in my h22?
  222. help w check engine light
  223. sunroof question
  224. radiator difference?
  225. 96lude speedomeder don't work please help
  226. h23 JE Pistons
  227. H22 Eagled sleeved block
  228. What does this mean?
  229. H23 IACV Help!!!
  230. DIfferent Trims
  231. knock sensor probs
  232. Possibly buying a new prelude
  233. idle h22a jdm prob
  234. i need help with my 86 prelude!!
  235. Handling
  236. 92 Civic shox in a 92 Lude?
  237. 89 HOnda prelude a/c compressor wont kick in please help
  238. Question about rotors...
  239. problems with swap
  240. Which internals for BOOST
  241. Possible hydro lock
  242. 89 prelude 2.0si 4pd a/c condesnor won't kick in please help!
  243. Are Bendix Pads Good for a Lude?
  244. 93 Prelude SI blown head gasket
  245. fuel pressure reg setting {psi}
  246. ABS code 1-2
  247. hi-flow cat
  248. Driver side Mirror Help
  249. Need JDM Mirror wiring Diagram
  250. 92 Lude Girgles Noise
