View Full Version : Lumina APV
- 1995 3.1 TBI fuel pump
- What is this hose? Chevy Lumina APV, 3400 Engine, 1996
- If Catalytic Converter Is Removed, What Should I Do with the O2 Sensor?
- Replacing Wheel Stud
- Bleeding Replacement Master Cylinder
- Where is Adjustment for Parking Brake 1996 Lumina?
- Seat risers still needed
- Lift Gate Actuator Wanted!
- repairing rusted broken rear front sub-frame mount metals?
- Seat Risers Wanted
- front seat belt retractors, stuck. all way out. fix?
- Lumina Parts for Sale
- '95 Lumina APV Seats
- actuator clicking in door
- wheels differences? W-body?
- A/C Compressor seized...or not?
- Have 1994 Chevy Lumina APV. Need parts advice!
- This is really different!
- A/C Compressor
- No Spark and no injector pulse
- 95 Lumina - fast idle
- The desired size of fastening of transmission
- fixing an oil leak 3.8
- looking for a few parts or sources for them
- 93 minivan apv
- 1994 APV antilock service light on
- AC compressor
- Blender Door Location?
- Blower Motor & Stuff
- Replacing axle shafts
- Hard to start when cold
- 93 with 3.1 stumbling
- '95 Lumina APV 3.8 pulley noises
- 94 Lumina APV
- how to replace lock/handle rear hatch 1990 APV
- Pusher Fan doesn't come on
- No air from heater vents, random problem
- how to pull codes
- New Here. '94 3800. Bucking. Misfires?
- 95 Chevy Lumina APV stalling problem
- radiator hoses
- Lumina APV Wont Start. Good Battery
- exhaust manifold getting to hot melting tps
- 1994 lumina apv tps melting
- Some electrical problems on 91 APV
- Engine won't shut off
- 94 Air in brakes ??
- APV end of life prep
- 95 APV 3.1 paint in my trans
- Rough idle for less then 1 min, then stalls
- Chime dinging with headlights on and car running
- Blower Motor - Only high
- Rear Blower Fan, 1991 Lumina APV
- Changing Oil Pressure Sensor, 1991 Lumina APV
- Relays behind right headlight. 91 Lumina APV
- OBD1 Code Retrieval
- Transmission question (I'm So Stupid!)
- 93'3800 engine-no power. need help
- Blower motor and Sway bar Bushings
- Blower Motor
- Transmission shot
- 1994 APV fuel injectors wont spray
- APV 3.8 TPS sensor
- rear wheel bearing & abs issue, also Hi, I'm new here !
- Replace door glass - 95 Lumina APV
- ABS,acting up. how to troubleshoot
- Rear control arm bushing(rattled)!
- 96 tranny shiftin problems
- 91 3.1 starts and stalls
- Ignition Cylinder Replacement
- 93 APV 3.8 ECM Failures - HELP!
- hard start when hot & stalling
- 95 Chevy Lumina APV 3.8 Stalling Problems
- lost the high setting on the front blower motor
- 3.1 fast idle
- I can not believe my rotten luck!!!!
- Outside Door handle again
- 92 3.8L apv tcc solenoid location
- New APVer in it for the long haul...
- 93 APV lost gages
- Power Sliding Door Electric Lock Mechanism
- Wont stay in overdrive
- 1995 Lumina 3.8L spark plugs
- Suddenly lost speedo and temp gauge
- 91 APV Van instrument cluster
- No heater controls
- Help!! Electrical Problem 1995 chevy apv
- Please Help 1990 Chevy Lumina Apv Smoking Antifreeze problem
- Wheels for Lumina APV
- Help: hard brake occasionally
- 94 Lumina apv 3.8 will not accelerate then stalls.
- stubborn balancer hub
- running good now but.............
- wiring problem
- pug gap???35 or 45??? 4 a 95 lumina apv with a 3.1
- Rattling noise in AC compressor
- Strange issue with Engine and Brakes
- 1995 Lumina APV 3.1 No lights!
- electrical problem
- 96 Lumina APV 3.4L crank no start...
- Need Vacuum diagram for '95 3.1L (or other year)
- Ball Joint Torque Specifications
- trans upshift problem
- No reverse
- A/C relay clicks rapid fire compressor wont run
- firing order
- 95 Lumina APV coolant fan problem
- front brake sticking and overheating...need advice
- '95 APV 3.1L, help with the valve job.
- Tachometer not reading correctly
- 1996 Lumina APV 3.4 Reverse just quit
- 93 lumina van how 2 frnt caliper seal kit
- 93-3.1 Steering issues
- F.Y.I. stalling, stumbling & not starting
- Locks & lights circuit
- Rear door latch replacement on 93
- emmissions
- 92 Chev Lumina APV-Stalling in reverse??
- 93 3.1 to 3.8 swap
- 1996 Lumina APV Code 0441
- heating issues 91'APV
- 1996 Chevy Lumina APV heating problem
- 96 Lumina APV heating issue
- 94 APV 3.8-No heat, no air...nothin'-HELP
- Towing with my 95 Lumina APV 3.1L
- Low blower relay location
- 1995 Lumina APV 3.8 Power steering
- New APV Owner !!!
- 1995 chevy lumina minivan
- 94 apv on fire
- 95 apv, speedometer doesn't work
- 1990 Lumina APV dash...OMG it's all curled up!
- Driver side window will not go down - 1990 Lumina APV
- Passenger side door will not open from the outside
- My First Post----Tail Pipe Resonator???????
- Weight Capacity 91 Lumina APV
- Coolant Mixing with oil 73K miles
- 94, when key out, everything off - .24 amps draw- is that ok?
- 92 APV leaking coolant
- 1994 Lumina APV 3.8l -lacks power
- Now What Wrong
- Help Me Please......
- Front Brakes
- no power to the fuel tank
- HeadLights, Side Markers
- 93 APV eats blower relays
- 94 chevy lumina noise
- 93 apv start problem
- Intermittent stalling after starting 3.1 TBI
- transmission problems
- 94 apv - what is the stat for interchange of a/c compressors
- Lumina Van '94 Check Engine Light- How to
- 1994 APV won't shift out of 1st
- AC works randomly
- Lumina APV Blower, No High
- 3.1L Cylinder Heads
- Ignition switch
- Gear selector
- help trying to fix ourselves
- Sure a lot of glass!
- Carfax Account
- power windo motor
- Power sliding door
- few problems with APV, maybe you can help
- Engine swap...
- 1994 3.1 lumina ac leak
- Blower Motor
- Intake Manifold
- 95 Lumina blinkers stopped working
- 95 APV ignition rod/switch help
- Tbi 3.1
- Scanner Software For Lumina Apv
- Bind In 3rd Gear
- Rear blower motor
- Fuel Gauge not reading right
- Problem with cooling water...
- Problem with brakes...
- Dot 4 in Lumina?
- 1994 Chevy Lumina APV, Cranks but no spark
- 1996 APV Fuse/Electrical Question
- 95 APV Window?
- I need some help!!!
- ? about power at road speed with 3.1 APV
- plug wire orientation on distributor 3.1
- 91 Lumina 3.1 no power above idle
- door trouble
- 95 shuddering while idle
- Crack in tailgate
- Audio Question
- 94 lumana apv heater hose
- 1993 chevy lumina mini van problems
- 4x4 lumina apv
- rear heat issue
- 1999 Kia Sportage Warranty problems
- Blower Fuse Location?
- Won't stay started
- 91 APV stalls when put into gear ?
- will not start
- 1994 lumina apv minivan transmission trbls
- Flashing head lights
- ignition module
- transmission question
- Super Charged 3.8
- 1994 Chevy Lumina APV Problems
- water temp sensor and fan
- thermal flasher?
- lost keys uina apv 90 3.1
- Low vacuum 1996 3.4l
- 3800 cuts off
- 1990 APV dies going into any gear
- '93 APV loosing power
- 92 Lumina
- 93 Chevy Lumina APV A/C not working good.
- Tranny can't decide on a gear
- Water leak !!! 93 APV
- repair a frount strut tower?
- 95 APV high idle
- '90 Lumina APV stalls when braking
- '93 APV loosing power while driving
- 94 Lumina APV blows Ignition Fuse
- 1995 lumina apv
- steering column repair
- 92 APV fuel injector causing engine to die
- 96 Van - Head Gasket
- 95 3.1 timing?
- 95 Lumina APV 3800 Overheating Issues
- Absolute Worst 3.1 Engine Oil Leak Possible!!!
- 1993 APV no sparks
- 1996 3.4l apv "using" coolant??
- 1996 lumina APV
- Weird distributer o-ring oil leak problem
- 91 Lumina wont start
- 94 APV No high end power
- 91 Lumina, Too much fuel?
- 3.8L lumina APV driving me crazy...
- OEM Delco Radio
- motor swap
- Dash lights and heater control light weird problem?
- 95, 3.8 liter tranny problems and CEL
- Can the A/C be bypassed on my van?
- My car runs perfect... when it runs.
- lumina apv no power
- New Suspension problem
- Engine noise
- Water Pump
- Need to identify the part - pic attached
- '95, where is A/C low port?
- update to elec short?
- Elec short? 92APV
- Lumina Problems :( been a week now!
