View Full Version : Explorer | Explorer Sport Trac
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. Alarm sounds when opening doors
  2. Rubber hose attached to top of rear axle:
  3. need help with new speakers
  4. 2001 Explorer driver door panel
  5. abs brakes 2001 ford explorer
  6. Center Console power Outlet Removal
  7. Starting Trouble. PLEASE HELP
  8. 95 explorer won't start in cold weather
  9. 1995 Explorer Coolant temp guage/sensor problem
  10. 2005 ford exploder starting issues
  11. big storm tomorrow!!4x4 trouble!!!
  12. 99 explorer 4.0l, turn signals and door locks
  13. Out of ideas Please Help
  14. '97 w/ 5.0 & Codes P0171 & P0304
  15. PLEASE HELP FAST - 2000 Explorer - Noise while driving (front pas. wheel)
  16. Want to hardwire Sirius in '05
  17. fuel pressures
  18. Two new tools out.
  19. Thinking about buying Explorer Sport
  20. How to disable door lock
  21. 1993 explorer abs light on...
  22. 1996 Explorer low beam issue...
  23. 1996 explorer makes noise when turning
  24. 2003 explorer sport tail light?
  25. 2002 ford explorer rear brake light problems
  26. back up lights fuse blowing
  27. Stuttering and dying
  28. codes p0133, p0340, p0300
  29. 2005 Tail light
  30. 2002 Ford Explorer?
  31. Abs Brake Question...
  32. Abs Brake Question...
  33. Reason for sudden antifreeze leak into oil pan?
  34. starter
  35. Stereo Wiring
  36. 95 fuel/running/idk probs
  37. 2000 Explorer SOHC No Start
  38. 91 explorer rough idle
  39. 01 Exlorer Won't Idle
  40. Hesitation at low rpm only
  41. P1812 code
  42. both oxygen sensors ??
  43. 2000 Explorer seat belt
  44. 2002 Explorer rear window hinge/ panel cracking
  45. Shock question
  46. 5r55e tranny manual
  47. 02 Explorer clicking
  48. Window Replacement Complexity re 2002 Ford Explorer Sport Drivers Side Window
  49. Explorer won't run unless I give it gas
  50. 94 Explorer Sport Front end noise
  51. 95 explorer with 2004 engine and trans HELP
  52. no heat
  53. Installing Amps Rear of 02 Explorer
  54. Explorer 4.0l PUSHROD egr location
  55. 2002 Ford Explorer V6 Rattle When Starting
  56. 2000 XLT Transmission problem
  57. front door short
  58. Advice on buying used 99 Eddie Bauer.
  59. 94explorer trans problem
  60. 2002 ford explorer remoter problems
  61. Trany extrange noise
  62. Crankcase Breather Filter
  63. 1999 Ford Explorer Eddie Bauer - Dash Lights may or maynot come on
  64. 2004 Eplorer ABS code
  65. 2001 Ford Explorer Sport 4wd Engages And Disengages while driving!!!!!!!
  66. 02 Explorer OBD P0401 Question
  67. 1998 Ford Explorer Clunk, then loud Whirr
  68. 1994 Explorer Missing
  69. OBD Code P0401 Question
  70. 1995 Explorer-Fuel line, filter to pump
  71. parking light turn off from keyless remote unlock
  72. 98 Explorer Swap/Upgrade Help????
  73. DPFE sensor
  74. 2001 Strange Electrical Problem
  75. I need help ASAP 94 explorer has no heat!!
  76. dash a/c
  77. Vibration
  78. Where is my Thermostat??
  79. 96 V8 5.0 EGR Valve-Where is it?
  80. low oil pressure at 2k rpm
  81. 2003 Sport Trac Brake Fluid Low???
  82. 97 Explorer Auto Transmission
  83. Removing Factory Radio Question
  84. Trying to program a remote
  85. Explorer.falls on face then dies,will idle
  86. REMOTE for alarm programming *need help*
  87. 98 Ford Explorer Help
  88. Changing the rotors.
  89. how to remove the slide cover from the moon roof
  90. 2000 Explorer XLS Horn?
  91. 2001 Explorer No 4WD
  92. 1998 Explorer SOHC Stalls on Incline
  93. 97 Ford Explorer
  94. Fuel Filter Location - 2002 Sport Trac
  95. Awd on 2000 exploder xlt
  96. left tail light and brake light inoperational
  97. 5 speed manual tranny noise
  98. Piaa Lights
  99. will start but won't idle until engine warms up
  100. Location of PCV Valve?
  101. 2000 Explorer Idles slow
  102. shakes and studders between 45-55 mph
  103. tranny vs thermastat
  104. 02 Explorer Engine Swap
  105. 96 Explorer High Mount $top light
  106. Funky exhaust or maybe transmission noise during light acceleration
  107. Need suggestions for rusted axle threads
  108. in dash dvd
  109. 2008 Ford Explorer Sport Trac XTL
  110. power windows and moonroof
  111. ford is running rough
  112. 2000 ford explorer DRL's not turning off
  113. rough idle
  114. Help: Front Differential Vent Hose Routing
  115. abs problem
  116. Lag
  117. Adding/Programming Remote Transmitter to 94 Explorer
  118. 1996 horn location
  119. Coolant System Drain & Flush
  120. Explorer Fuel Pump Woes!
  121. brakes
  122. 1998 Ford Explorer Wiring Diagram For Power Windows And Sun Roof
  123. 03 explorer trans hard shift neut/drive
  124. Electrical short or bad ground?
  125. P0171 & P0174
  126. Spark Plug Gap Question
  127. 2003 Sport Trac, no wipers, dome lights & Speedo
  128. Need torque specs for 93 4.0L
  129. factory paint
  130. Does the fuel pump need replaced
  131. 91 Explorer power steering pulley question
  132. low fuel light
  133. 05 Ford Expolorer Sport trac xlt door panel removal
  134. DPFE on 1999 Ford Explorer
  135. 2002 Explore Shift Problem
  136. interchangeable parts
  137. heat shield removal
  138. 99 Explorer tranny problem
  139. 95 Ford Explorer Neutral Switch
  140. 1998 Explorer "Thump" Noise While Driving Up Hills
  141. 2003 ford explorer v-8
  142. 1997 Ford Explorer smokes out the tailpipe in the morning
  143. Accessories??
  144. Tranny Problem- Aamco or Dealer?
  145. Extreme shutter after steering rack installed
  146. brake issues
  147. 95 Explorer check engine light
  148. Help Stuck in 4x4 low with no turn signals
  149. Front Differential Issues, Please someone!
  150. Explore will not start, Was running good
  151. 1994 Explorer
  152. Replace Steering Rack Boot 95 Explorer EB
  153. removing air box?! and vacuum lines??
  154. 1998 Ford Explorer A/C Maintenance
  155. Having Single Fuse Blow on a 2001 Exp. Sprt.
  156. Dead AC...
  157. Transmission makes grinding noise when put in gear
  158. what's this part called?
  159. front differential and fuel filter
  160. what years will plug and play with a 97 4.0
  161. shutter ford explore
  162. Automatic Transmission
  163. 2003 Driver Window problems
  164. 99 xlt alarm questions
  165. 1996 Explorer - P0153
  166. Help Me Please! 03 Explorer
  167. 94 explorer fuel odor
  168. 1994 4 door explorer power window help
  169. '97 4wd front wheel bearing
  170. P1451, P0304, P0305, P0171, P0174
  171. P0171 and P0174
  172. Problem with losing antifreeze/coolant
  173. 96 explorer sport dash and tail lights
  174. a/c & heater problem
  175. Help PO401 code
  176. Fog Light Help
  177. Replacing o2 sensor on a 1998 Explorer
  178. Identify 1998 exporer alloy wheels
  179. Cruise Control Update 03 Explorer, Any ideas?
  180. Thankx 2 All
  181. 2002 ford explorer rear brake lights wont cut off.
  182. Does anyone know????
  183. 2000 Ford Explorer XLS
  184. Cruise Control Issues 03 Explorer; Help please
  185. Fuel Filter remover tool for Ford explorer 2000???
  186. 2000 Ford Explorer XLS
  187. 91 explorer starting issues
  188. 99 frd expl 4.0L codes p0171/0174
  189. 95 Explorer O/D light flashing code 647
  190. Fuel Filter Location 2000 Explorer
  191. Loud Screeching in my 2000 explorer sport motor
  192. Brakes on 03 Explorer Make some $$$
  193. 1996 Explorer lower ball joint movement specs?
  194. Mass Air Flow Sensor Hums
  195. Vehicle security sustem
  196. anyone parting out a 91_94 explorer 4x4?
  197. emergency flashers, cigarette lighter
  198. Check engine light
  199. 2002 sport trac leaking fuel filling up
  200. 04 trans noise when coasting
  201. 2001 Explorer Sport 4X4 4.0 sohc Brake Pedal always drops
  202. 97 explorer trans swap
  203. 2005 improve ride and gas mileage
  204. Door Ajar Light Wont Go Off
  205. driver window issues for 2000 explorer
  206. driver seat is crooked
  207. 91 explorer runs rough, eats gas
  208. 1991 explorer brake problems
  209. Sticky accelerator pedal (2001 sport trac)
  210. 98 explorer will not start
  211. which drive gear should i use?
  212. 97 Explorer Daytime Running Lights Not Working
  213. 2002 Eddie Bauer Squeaky/ Cracked Springs
  214. Whining Noise On Decel
  215. 03 XLT rear entertainment DVD remote
  216. Radio antenna cable questuons
  217. 03 Explorer Emergency Brake
  218. all wheel drive is hopping on pavment like its in four wheel drive on sharp turns
  219. NEED TO GET OUT OF 4X4 low tonight
  220. 2002 Explorer door locking issues
  221. Headliner Removal
  222. 2002 4.6 Liter Knock Sensor Location?
  223. removing 6 cd player
  224. BIG PROBLEMS after motor swap 98 explorer xlt sohc
  225. 93 explorer timing cover gasket replacement
  226. '02 model owners: strange favor to ask
  227. vvs
  228. Explore power lock problem only locks from back
  229. Transmission Swap
  230. 2000 Explorer constant vibration
  231. 1998 Ford Explorer For Sale/Parts
  232. 2003 Sport trac dome light
  233. rear window off track?
  234. Do I have a tow package or not????
  235. 2 dead Cylinders?
  236. brake hose or caliper
  237. Removing front rotors
  238. help: 2003 XLT side view mirrors do not work!
  239. vacuum port
  240. 2002 Sport Trac Heater Core issue
  241. Emergency Flashers
  242. 93 Explorer emergency brake
  243. 1991 4X4 indicator light doesn't work
  244. min. thick ft. rotor 97 Exploder
  245. 95 explorer stereo
  246. po300, po171, po174, please help
  247. Bad CAM sensor
  248. 2004 ExplorerXLT_HatchCrack
  249. 99 Explorer LOUD pulsing hum and vibration from the front end
  250. 98 Explorer ocassionly will not start.
