View Full Version : Windstar
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
  1. 02 Windstar-mechanic says transmission is about to blow........
  2. blend door
  3. 2003 winstar gl 3.8l coolant leak
  4. Is the chamber adjustable on a '96
  5. 99 Windstar Flashing OD Light
  6. 2003 WStar Battery drain
  7. 96 Windstar 3.8L Coolant in Throttle Body
  8. Windstar electrical problem
  9. Trans cooler... tow lights..... door lock actuator
  10. Engine noise-'99 3.8
  11. breather tube missing
  12. A/C, Transmission, & Misfire
  13. Front Lower Bumper
  14. Gear selector hard to shift
  15. 3.8 #6 misfire
  16. I did it...2000 water pump.
  17. 96 Windstar Exhaust Leak
  18. Doing a Tranny Flush...99 Windstar
  19. 01 Windstar ABS Light & Brake Light On
  20. spark plugs
  21. vacuum leak
  22. 98 3.8L GL Transmission Leak
  23. Head Gasket Scare! ... '99 3.8l
  24. Help changing Water pump ??
  25. Special tool needed for removing fuel lines?
  26. '02 How do you remove the rear bumper cover?
  27. Can I access/replace the fuel pump from inside the van?
  28. 2001 Ford Windstar - No start, no crank
  29. 2002 power door lock relay location?
  30. regarding prevous post: "Wiring for 99 Windstar universal actuator / keyless remote
  31. 99 Windstar - wiring for universal actuator/remote ket
  32. Trans Rebuild and Lucas Trans Fix
  33. 00 windstar, od switch not working
  34. Power steering rack failure ... 99 3.8l
  35. 2000 windstar trans trbl
  36. 1998 Transmission Failed
  37. Antifreeze smell coming in through vents???
  38. Transmission Not Shifting Into 4th Gear
  39. 01 turn the key nothing happens
  40. 02 winstar misfire cylinder 5
  41. 03- Front speakers cutting out
  42. 97 Windstar- Fuel pump/filter/something!?
  43. Power seat 2002
  44. cooling help needed 95 windstar
  45. Ccrm
  46. Headlight Mounting Plate
  47. Pimping my 2000 windstar with new front speakers
  48. is it hard to change a starter
  49. 1999 Windstar 3.8 P0136 & P0141 - Help?
  50. Blend Door
  51. Weird Oil Leak
  52. 98 3.8 Winstar service eng lite
  53. 02 Windstar - turn signal problem
  54. '99 Windstar Air Conditioning
  55. Electric power/battery problem
  56. 99 Windstar Coolant Smell w/ heat on
  57. Driver Side Sliding Door Problem
  58. 02 windstar lx - programmable key questions
  59. 1999 windstar
  60. 01 Ford Windstar knocking sound from enginge compartment
  61. 03 Windstar chugging on hills
  62. Windstar with a distributor?
  63. 1996 windstar lock actuator
  64. # 1 coil will not fire?
  65. 98 Windstar - popping when turning
  66. '02 Windstar chugging on accel - no CEL (yet) - Where to start
  67. Holes in Oil Dipstick Tube
  68. IMCR problem code 1538
  69. 96 and 01 what's interchangable?
  70. 98 winstar
  71. lose power steering when drive through puddle
  72. PCM fault, turns on injector when shouldn't
  73. New Problem?
  74. Voltage specs at DPFE on 2002 3.8
  75. 2000 sel windstar: Front speaker install
  76. Just Finished Isolator Bolts Have Questions
  77. EGR Valve Solenoid
  78. Question About AutoLight plugs APP 765 VS APP105
  79. power sliding door fix
  80. Data Link Connector information
  81. Lower Intake Gaskets
  82. Setting up the EPC Trany presure Windstar 96
  83. 95 windstar engine knock
  84. Van chokes at 4000-4500rpm at idle
  85. Muffler on sale
  86. RPM surge at exactly 19mph, 2000 SE
  87. Power Sliding Doors
  88. 2000 Windstar SEL won't start
  89. 2003 SEL steering sways from acceleration
  90. helpful youtube video re: TRS - neutral safety switch
  91. 171 174 codes
  92. help, brake pressure switch wiring
  93. 2003 windstar high ide when hot
  94. windstar 2000 repair manual
  95. OBD does not communicate with safety inspection computer
  96. 95 WINDSTAR, 3.8 blend door actuator removal
  97. 96 Windstar CEL Codes p0161 & p0174
  98. 2000 Water pump
  99. Cause of P0171 & P0174 Codes 1996 Ford Windstar
  100. Front Brakes ....Help
  101. transmission change
  102. Passenger Side Slider Doesn't Unlock
  103. air bag light
  104. Ashtray lamp replacement
  105. Steering/Heating/Cooling Problem
  106. 171/174 on 2000 Windstar
  107. Wheel Bearing '98, how difficult?
  108. PCV Catch Can Install
  109. can i put wheel adopters on my 03 windstar?
  110. Anyone running NGK iridium plugs
  111. TRS Removal Problems
  112. 2000 windstar power window issue
  113. windshield washer doesnt work on 03 windstar
  114. feeing a sudden "push" when driving '03 windstar
  115. are there any bodykits available for windstars?
  116. are there any bodykits available for windstars?
  117. Ford's Brake Deactivation Switch Kit
  118. 2000 windstar intake oil leak,should I replace head gaskets while Im at it?
  119. 18" universal 5 lug fwd rims wont fit '03 windstar
  120. 1998 3.8l Windstar
  121. Just made some repairs and now won't start!!
  122. 2002 Windstar 3.8L crankcase
  123. 03 Windstar - suggestions on a remote starter
  124. Castrol LMA Brake Fluid
  125. 2000 Windstar slow to heat-up
  126. p1409 iSSUE in 1996 windstar
  127. 1996 3.8 liter windstar engine removal
  128. interior light come on when driving
  129. 02 F150 5.4L V8 Triton Plug Problems
  130. ABS light
  131. O/D light bliking, no trans codes from autozone?
  132. Van will not go above 40 mph without shuddering- help!
  133. 95 WS abs problems
  134. Overhead dvd installation
  135. 1998 Windstar -- Losing Coolant
  136. Squawk on startup, '02 Windstar
  137. Fuel Injector Spray End Cap fell into Bore/Spark chamber
  138. windstar won't start - sometimes
  139. Lock Jammed, Sliding Door, '02 Windstar
  140. Freestars??
  141. 2000 windstar 3.8 engine out of balance
  142. Well she's dead.
  143. Windstar stalling/light problems?
  144. 00 windstar misfires need help!!!
  145. '03 Windstar Surging Idle at Cold
  146. 2000 winstar van stalls
  147. Oil smells like gas
  148. '96 Wndstar internal coolant leak
  149. 99 windstar 3.8L Rough idle & accel misfire
  150. Transmission Fluid Question ..
  151. '96 Windstar coolant loss & cylinder miss
  152. oil leak on the passanger side
  153. erg flow insufficient 2001 ford windstar
  154. Bad battery/starter/???????
  155. 98 windstar 3.0 will not keep running
  156. mifire on #5
  157. brake shoe de-lamination - 2nd time
  158. 2000 windstar tranny leak
  159. Hot soak start rough idle
  160. Overdrive off light flashing in Park
  161. MPGuino Fuel Consumption Computer?
  162. '99 WS; Trans bucking on 4th to 3rd downshift; anyone?
  163. 1998 3.0L Windstar transmission failure? possible damage?
  164. doing the tranny flush on a different make
  165. automatic tranny fluid
  166. IMRC stuck open 1998 3.8
  167. Coolant temperature issue
  168. Fuel pressure leak down rate: acceptable or not
  169. Engine Calibration
  170. Cold engine knock
  171. Does my Windstar have 2 PCV valves?
  172. 03 windstar fuel problem
  173. AX$S Schemas?
  174. Trany oil type
  175. Radiator fan assembly removal procedure
  176. squeel when steering
  177. Help me find this ground cable 95 3.8L
  178. 2000 windstar need door weatherstripping
  179. Fuel pressure lower after new fuel pump installed
  180. IAC Questions: Voltage and Knob
  181. Lubing Caliper Sliders 1999 Windstar
  182. 96 Windstar Fan Module change
  183. 2000 Windstar 171/174 then more codes/issues
  184. Design Flaw in Transmission??
  185. 2002 Windstar Spark plug replacement
  186. 2002 Windstar Spark plug replacement
  187. 2002 Windstar. Where is pcm? Anyone do remote starter?
  188. Coolant "Y" Pipe to the Heater
  189. Alternator and A/C clutch
  190. Cam Synchro/Sensor: Clicking, rattling, metal tapping or clanking
  191. Misfire on cylinder 1
  192. Another Intermittent ABS Light
  193. 18" Mustang Wheels on my Windstar
  194. '01 PATS key in steering column
  195. Brake Deactivation Switch Replacement Procedure
  196. 98 Windstar, drivetrain vibration solved.
  197. Stablizer Bar Issues Windstar 1999 SEL
  198. Help With Front Brake Job 1999 Windstar SEL
  199. Missing Brake Fluid
  200. coolant leak 95 windstar
  201. abs and traction control
  202. 1998 Windstar transmission
  203. No heat - 97 windstar 3.0L
  204. 01 Complete rear brake job, now brake warning light is on.
  205. Blend door removal?
  206. Wagner Thermoquiet Ceramics on Front '99 SEL
  207. Engine won't crank, why?
  208. Does your Windstar do this after fans turn off?
  209. 96 windstar 3.8 lights flickering and stalling at idle
  210. 97 windstar 3.0 IMRC stuck open
  211. 2000 Windstar died, thank you Ford.
  212. Valve cover replacement
  213. 2001 Windstar Won't Start
  214. Intermittent ABS & T/C warning light Indication
  215. Engine Lt. on
  216. Engines Stalls Shortly After Starting
  217. new engine & transmission install
  218. Light on Bumper Cover Windstar 2000 SEL
  219. Tsb 03-16-01 (p0171, P0174)
  220. alternator
  221. 01 windstar missing and baterry light on
  222. Windstar towing
  223. loosened lug nuts
  224. Cold air from heater vents
  225. 2003 Transmission shudder
  226. Anyone used an accel after market coil.
  227. Transmission Leak
  228. 98 Windstar Heating/Cooling
  229. Code 1538 puzzle...
  230. Do I have to fix P0171/P0174 What could happen?
  231. 2002 Windstar Hitch hitting ground
  232. RPM gear problem?
  233. 2001 Windstar
  234. p1400
  235. Anyone Replaced Inner Tie Rod Ends?
  236. Brake Fluid
  237. Neverending belt squeak - yellow fluid - a/c leak?
  238. 1998 Windstar tran flush
  239. Antifreeze Leak
  240. a/c problems
  241. leaking radiator fluid
  242. 98 windstar stalls when coming to a stop
  243. 2000 Windstar po171/174 Finally Fixed
  244. Radiator Fan Relay Number & Location
  245. 2000 front drive axle joint seal/ lip?
  246. Reset the Computer to shut off idiot lights
  247. Battery Replacement on a 2003 Windstar
  248. Won't turn over
  249. Front End Issue
  250. 2001 Winny - No front brakes
