2002 Windstar. Where is pcm? Anyone do remote starter?
jbarto883
01-26-2009, 06:58 PM
Looking for my pcm to get a tach signal wire, anyone tell me where it is? Also, anyone put a remote starter in one of these? I have PATS and a by pass module, no start though. Remote starter sayes it isnt getting a tach signal, {learning it}
wiswind
01-26-2009, 07:17 PM
I don't have a remote starter, so I am of no help to you there.
The PCM is located IN the firewall.....on the passenger side.
You access it from the engine compartment.
On the passenger side engine compartment, look at the TOP.....up under the windshield wiper cowl.....kind of behind the top of the strut tower.
There is a BIG wire harness plug there.....into the firewall.
The wire harness is plugging into the PCM.
As to what wire does what.....I only have access to that information for 1996 model year.....so I will leave that part to someone else.
kevink1955
01-29-2009, 09:05 PM
Try this, it is from 12volt.com, I installed a remote start in my 96 and went to the coil pack for the tach signal as is sugjested here for 99 to 02. Mine works fine but I did mot have PATS to deal with.
Ford
Windstar
1999-2002
Remote Starter Wiring Colors and Notes
Start:
DK. GREEN
IGNITION SWITCH HARNESS *
Ignition #1:
WHITE/YELLOW
Ignition #2:
BLACK
Ignition #3:
VIOLET/ORANGE
IGNITION SWITCH HANRESS **
Accessory:
BLACK/LT. GREEN
Brake Light:
RED/LT. GREEN
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
DK. BLUE/LT. GREEN
AT COIL MODULE ***
Parking Lights:
YELLOW/LT. BLUE (-)
AT FRONT ELECTRONIC MODULE ****
OEM Alarm Disarm:
LT. BLUE/BLACK (-)
16. PIN CONN. LEFT OF STEERING COLUMN
OEM Alarm Arm:
ARMS WHENEVER THE DOORS
ARE LOCKED.
Notes:
* These Vehicles May Be Equipped With Ford's PATS Anti-Theft System. Bypassing Transponder Theft Systems. ** Use Ignition #3 to Drive a Relay and Fuse the Constant +12 Volts of the Relay Seperately at Battery With a Separate 30 Amp Fuse. *** Located Top Left Side Of The Engine
Ford
Windstar
1999-2002
Alarm and Keyless Entry Wiring Colors and Notes
Constant +12 Volts:
RED
Starter Kill:
DK. GREEN
Ignition +12 Volts:
WHITE/YELLOW
Dome Lights/Superv:
ORANGE/WHITE (-)
OEM Horn:
DK. GREEN/ORANGE (-)
8 PIN CONN. LEFT OF STEERING COLUMN
Power Lock:
LT. BLUE/ORANGE (-)
16 PIN CONN. IN DRIVER'S KICK PANEL
Power Unlock:
LT. GREEN/YELLOW (-)
Trunk Release:
SEE NOTE *****
Alarm Input Wire:
ORANGE/WHITE (-)
Notes:
**** Located Behind Driver Side Dash Left Of Steering Column. ***** Sliding Door Operation Tan/Lt. Blue (-) At Switch (Same Color For Driver or Passenger Side).
Ford
Windstar
1999-2002
Start:
DK. GREEN
Ignition #1:
WHITE/YELLOW
Ignition #2:
BLACK
Ignition #3:
VIOLET/ORANGE
Accessory:
BLACK/LT. GREEN
Brake Light:
RED/LT. GREEN
Tach Signal:
DK. BLUE/LT. GREEN
AT COIL MODULE ***
Parking Lights:
YELLOW/LT. BLUE (-)
OEM Alarm Disarm:
LT. BLUE/BLACK (-)
OEM Alarm Arm:
ARE LOCKED.
Notes:
Ford
Windstar
1999-2002
Constant +12 Volts:
RED
Starter Kill:
DK. GREEN
Ignition +12 Volts:
WHITE/YELLOW
Dome Lights/Superv:
ORANGE/WHITE (-)
OEM Horn:
Power Lock:
LT. BLUE/ORANGE (-)
Power Unlock:
Trunk Release:
SEE NOTE *****
Alarm Input Wire:
ORANGE/WHITE (-)
Notes:
