View Full Version : Windstar
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
  1. 2001 Windstar Why make simple hard.
  2. Exhaust flange won't seal
  3. 2002 Ford Windstar LX - Passenger power window stopped working, driver's side switch repair
  4. 1999 Windstar SEL with possible head gasket issues???
  5. PCV system problem
  6. Aux Belt ...installation tip.
  7. 1999 Windstar REM Question
  8. Help! How to seal the cowl/windshield?
  9. Misfire issue
  10. 2001 windstar rough idle at warm up,
  11. Abs light & brake light come on.
  12. 02 ford windstar
  13. Severe engine vibration
  14. Brought in for coolant flush, now no start!
  15. 1999 Ford Windstar won't stay on
  16. Head gasket repair additives,
  17. sway bar bushing removal problem
  18. Rough idle of my 2000 Windstar
  19. Dim information panel
  20. Checking transmission
  21. 2000 Windstar lower intake
  22. Replacement taillights
  23. 98 winstar rear hub removal
  24. '99 Windstar SEL won't start after long drives
  25. 03 Air vent door shaft repair
  26. 2000 Windstar Serpentine, Squealing, Stalling
  27. 03 airbag code 19
  28. DIY? power slide door cable broke.
  29. Is Head Gasket? Or Intake Manifold Gasket?
  30. Water Leak Rear of vehicle
  31. Transmission Flush Question
  32. Shift Cable Removal
  33. Bad timing? Rough idle?
  34. Lower Intake Manifold Gasket Replacement
  35. Bent fuel rail
  36. '99 Windstar Cluster Replacement
  37. 205K, running rough, throwing codes
  38. Smoke coming from dash, now cluster dead
  39. 2000 Ford windstar Not starting.. Replaced the ecm 3 times got it to start then it stopped again after 3 days.. NEED HELP!!
  40. New Owner of '99 Windstar SE with 3.8L
  41. Little bit of smoke...
  42. 2000 Windstart Alternator Smart Charge 14.7v @start, 12.5v after 30 minutes
  43. Heat out of Vents only
  44. Windstar Hard to Diagnose Engine Misfires
  45. Lean Codes P0171 P0174 Intake Seals Repair
  46. 03 Windstar no start (theft light)
  47. Please tell me its something simple
  48. coil spring code
  49. 99 Windstar Crankcase Ventilation Tube?
  50. Another ford windstar problem this one is a missing problem.
  51. upper radiator hose drooping
  52. 2001 Windstar 3.8 rough engine
  53. 4-cyl rpm specific loud timing belt rattle
  54. replace entire rack or just outer tie rods?
  55. 2000 Windstar Alternator Problem
  56. 2000 Rear axle repair - prevent
  57. NO HEAT: Clicking Actuator in Dash Removal
  58. coolant leak and rusty steam - PICS
  59. 2000 windstar, charging light
  60. 2000 WS Power steering fluid question
  61. Cruise Control Inoperative Diagnose
  62. O/D switch off
  63. 2000 Windstar wipor motor recall picture request
  64. Rough Idle Cold and stumble at 2000 RPM
  65. Windstar 2002 Minivan - Lifts question
  66. Windstar 2002 Minivan - Lifts question
  67. Windstar To A Trailer Conversion
  68. 1999 Windstar Trans Flush
  69. Park Lights Stay on with Switch Off or come on by themselves when cold
  70. 95 Satanstar Wiper Arm Question
  71. 02 windstar no start
  72. Cosmetics
  73. 1998 windstar no reverse
  74. Can't Keep a Front End
  75. Ford's 3.8L on the Windstar SEL 1999
  76. Dreaded P0174
  77. Battery Hold Down for '99 Windstar SEL
  78. 01 Windstar 2nd opinion
  79. oil drain plug leak
  80. Some Tips for Lower Intake Gasket Replacement Windstar 1999 3.8L
  81. 2002 windstar Battery light came on tried two alternators still On.
  82. wet drum brakes
  83. '99 Wind* 3.8L...Oil in coolant
  84. Silver Colored IAC on Windstar '99
  85. Windstar subframe recall performed - now rusted through pic attached.
  86. 03 Windstar Sport
  87. RIP Windstar 2000
  88. Soft in back
  89. ABS BYPASS ? 98 Windstar
  90. Advance trac light fixed
  91. Engine Temperature Gague inop
  92. IMRC check
  93. Size of bolts on Camshaft Position Sensor?
  94. Turn Signal lights don't flash when locking 2000 Windstar
  95. passenger slider door track question
  96. Vacuum Reservoir Check Valve Difference
  97. Windstar '99 Consuming 1 qt/1000 miles
  98. Master Cylinder Pressure switch
  99. most tread wear from which end?
  100. 1998 Ford Windstar , no break lights or shifter unlock.
  101. 2003 Windy-P0305 crank sensor assembly position variation procedure not learned.
  102. 2002 3.8 Oil Capacity
  103. DTC trouble code diagnostics on alldata.diy
  104. Help! Missing Trans fluid during flush
  105. Possible Valve Stem Seals Issue
  106. 98 windstar A/C problems
  107. 98 Windstar Power Locks Going Crazy
  108. Running rich at high RPM
  109. Has anyone tried KYB struts?
  110. Gear indicator no longer indicating
  111. 2000 3.0i Windstar P0340, bad idle, bad low-RPM
  112. 98 windstar stalls while driving
  113. Stalling
  114. Misfire on CYL 3 after MAF cleaning
  115. Replaced heads, rebuilt engine - blown freeze plug
  116. po 1451 - need help quick
  117. Ongoing 171 & 174 on 99 windstar
  118. '00 dead, seems fuel system problem
  119. Windstar fuel pressure problem.
  120. Camshaft pos. sensor CMP and fuel timing
  121. 2000 Windstar Transmission, Brake and Exhaust Issues
  122. Need Advice! Misfire
  123. Surging forward on its own at idle in drive
  124. My first transmission rebuild :)
  125. 99 LX Windstar window issues
  126. "99" Transmission issues
  127. 99 Windstar keyless entry
  128. ford windstar misses when accelerating
  129. flush fill AND bypass tube?
  130. 2000 fuel injector
  131. Trailer wiring HELP!!
  132. attachments not 'attaching?'
  133. At a loss with 95 cooling problems
  134. Blend Door Actuator
  135. trans rattle only in D while braking
  136. Headlights and cruise on, turn signal turns cruise off
  137. 99 Windstar won't start when warm
  138. Transmission shift solenoids
  139. 03 windstar stalls going up hills ????????
  140. OBD2 FULL scantool for FORD
  141. Jack it Up
  142. Day Running Lights for original holes Win2000
  143. 99 Stalls at Ideal.. Runs like a Top in Drive
  144. 2003 Windstar LX - P0171 & P0174 CEL codes
  145. more new info on ford tranny AX4S
  146. change shocks and strust on Ford windstar 2002
  147. ford AX4S tranny problems
  148. Shocks and struts replacement on 2003 Windstar LX
  149. Alternator Diagnosing
  150. Coolant Loss
  151. Cabin air filter location or internal air intake for a/c location
  152. 2002 Ford Windstar LX Door Locks Not working
  153. Looking at 2002 Windstar LX to buy
  154. the dreaded slider door rattle
  155. Electrical Problems, Flashers Problem - 99 Windstar
  156. 1999 2000 Windstar A/C not kicking radiator cooling fans on
  157. 2002 windstar starting problems
  158. 2000 a/c air conditioning charge brought on black death?
  159. LOW/INTERM. Servo Explosion
  160. 2000 Cargo: ONLY LR has plastic inner fender.
  161. Replacement Fuel Pump Brand to use: Love/Hate Pump -v- Assembly
  162. 2000 Fuel Pump Retaining Ring - How Easy to Break?
  163. Few codes - Which one to fix?
  164. 01 windstar 3.8 catalytic converter stopped
  165. Best rebuilt brake alipers for 1999-2003 Windstar
  166. 2003 Windstar 3.8L SERIOUS BLOW BY and oil leaks!!
  167. '99 Windstar Burning a Quart Every 1,000 Miles
  168. spare tire winch problems 1998 Windstar
  169. Advice Please - DIY torque converter or transmission replacement
  170. Front brake pads wearing a lot faster
  171. 2002 Windstar Surging Issues
  172. good prices on 2000 3.8 parts
  173. O2 Sensor
  174. 95 windstar ccrm mystery :)
  175. 03 windstar stalling
  176. Inner Tie Rod R&R
  177. 00 windstar won't start?
  178. A/C Diagnostic and Troubleshooting - Help Needed
  179. Pin part number
  180. Problem code C1103
  181. Odd smell in vehicle
  182. 2002 Windstar misfire at idle
  183. 03 windstar with P0340 & P1504
  184. 99 windstar spark and fuel but wont start
  185. Transmission problem
  186. 2003 ford windystar
  187. bolt head size vs thread
  188. Rear Valve Cover
  189. Ground Location
  190. 2002 Windstar P0306 Surging during acceleration
  191. Rebuilt tranny, fail when hot, any idea??
  192. 2000 Windstar: Replace fuel pump, drop tank, Jacking Instructions
  193. 2002 Windstar dies when put into gear
  194. Rought idle at start sometimes
  195. No fuel pressure, blows fuel pump fuses... but sometimes runs.
  196. Low servo repair: transmission slip problem solve
  197. screwed tranny / sorting springs
  198. circlip broken on low servo
  199. Speedometer/Odometer Stopped Working
  200. dash lights stay on
  201. transmission replacement - your thoughts
  202. Battery dash light
  203. 2000 Windstar intermittent won't start due to severe misfiring
  204. wifes winni heater issues
  205. strong chemical smell suddenly appears in 2002 windstar
  206. Transmission glitches on 1998 3.8L Windstar
  207. which exhaust insulator to get?
  208. 2000 windstar Hood will not open
  209. 2001 windstar tapping banging from black upper intake
  210. Using engine oil SWG 20-50 instead of SWG 10- 30
  211. 2000 windstar airbag code 32 and horn doesn't work
  212. 2000 SEL ABS Light problem
  213. 2003 Windstar Power Driver Seat
  214. 99 Windstar License Plate lights
  215. 2002 windstar struts
  216. When using heater, thick exhaust smell coming from air vents
  217. OT- oxygen sensor head scratcher..
  218. 2001 Rear heat is not hot
  219. Air Bag Light on DASH after front brake and other service
  220. Keep blowing driver seat adjust 30A fuse
  221. Exhaust Flex Pipe Options: Cheapo OEM, Universal, ?
  222. Battery getting drained on 99 ford windstar
  223. P0340 on a 95 Windstar 3.8L - Camshaft Position Sensor
  224. Correct charging voltage
  225. shaking when starting sometimes - every 10th time or so..
  226. 99 Windstar No Heat
  227. My turn with the broken blend door...
  228. Second Windstar totaled- Freestar or Sienna?
  229. Removing sludge in engine thoughts
  230. Anyone know where to get a decent CV axle (halfshaft)?
  231. Pictures
  232. CV Joint boot changing
  233. Leak at torque converter between engine and transmission: THE END OF the OLE WINNIE?
  234. 2000 Windstar LX starting problems
  235. Need help with 2000 windstar problem please help
  236. Does a 2003 WIndstar engine have a low oil level sensor?
  237. fuel pump heads-up!
  238. 95 Windstar Front End Problem
  239. Windstar Idles high
  240. Misfire Mystery
  241. 2000 Windstar Won't Start from Time to Time
  242. 2000 lower intake gasket
  243. P0305 Code 2003 Ford Windstar 3.8
  244. Code P0446
  245. Multiple DTCs, erratic idle and loud pinging
  246. 3.8L Timing Cover Removal
  247. Knock in engine
  248. Windstar SEL 1999 Gauges Gone Crazy
  249. Body Protection - wheels
  250. Power sliding door cable adjustment
