Size of bolts on Camshaft Position Sensor?
2k3windstar
09-29-2013, 08:40 PM
I was wondering about the size of the two little bolts that hold the camshaft position sensor (CPS) in place? None of my metric sockets fit it. Too big or too little. I did not see the size mentioned in any posts related to the CPS. I think a 7/32" is the correct size, but wanted to check with someone who has removed it before I buy some little sockets.
Thanks,
Eric
Thanks,
Eric
12Ounce
09-29-2013, 09:38 PM
That's what I remember. You can change them for something nicer ... like a socket head screw after you get them out the first time. (Did someone say "grinder"? Make a screwdriver slot and bingo!)
tomj76
10-02-2013, 09:18 PM
I have a '96 3.8L. The best fit that I have is a 7/32" socket. A 5 mm is too small, and a 6 mm is too big. The size of the head seams to measure 0.231", although 0.219" is 7/32"so I must not have measured correctly.
Mustang_Driver
10-03-2013, 11:02 PM
I haven't had to replace mine but it sounds like it's 5.5mm. I could lend you the socket but i am way to far away
