which exhaust insulator to get?
parkerb
02-01-2013, 07:33 AM
hi all,
need to replace the black figure 8 looking rubber exhaust insulators. ford only sells them with the hanger ($30+ each). i see them at autozone, and rockauto has them individually. where have you replaced them from and which is closest to the ford design/ material?
tia,
parker
tia,
parker
northern piper
02-01-2013, 07:53 AM
oh I'd be using aftermarket for this part without question. I can't imagine dropping 30 for a Ford part. Likely the same part but just inventoried to death with Ford numbers and bureaucracy. Use the aftermarket one and go on...if it's the same shape... use 'er!
scubacat
02-01-2013, 10:56 PM
Ditto to that. This is a part I'd be least concerned of an exact OEM match. I actually ordered the ones from rockauto and they're perfectly good, but any option should be fine.
