View Full Version : Windstar
- Howling harmonic noise from right front
- Knock
- Electrical problems
- Clogged EGR ports
- Driver side armrest
- A different electrical problem, '03 Wind
- Camshaft synchronizer assembly removal problem - need advice
- trying to remove VCR
- Fuel Pump Question
- spark plug changing
- newbie ford owner here.
- Heater Problem, NOT actuator
- door lock acuator install
- H frame rotten
- H frame rotten
- Front brake rotor hold screws
- Alternator Bearings
- Removing headlight housing - am I being dim?
- Pinging - EGR question
- Has Anyone Used An Oil Pan Pad Heater?
- 2003 Rear Defroster cable disconnected
- Rear entertainment problems
- P0302 Misfire on cylinder 2 (rear bank middle)
- windstar question
- Flashing Check Engine Light
- 2002 Windstar keeless entry error codes
- my 1999 windstar se will not start
- 6 cd changer won't eject or play (2003 Windstar)
- 171-174 codes after tsb
- 98 Windstar ABS light on/ help
- 99 windstar trans replacement
- 95 Windstar/Head gasket failure/Short trips
- Engine won't fully rotate! HELP!
- Ford Reman Trannies and Engines
- 1996 Windstar 3.8 engine swap, what's compatable?
- Back-up alarm quit working
- 99 Windstar - rough idle at stop or at start
- ignition problems,wont start
- 2001 Windstar Coolant hose pipe leak Solved with Pictures
- Power Steering, Intake Manifolds, And Automatic 2 Step...wtf?!
- Low oil pressure on new engine install
- electrical component on plenum 2000 3.8
- Engine Sputtering while in Gear @ Stop
- My new engine is installed 1995 3.8L
- 2003 SEL Windstar Window Washers Problem
- vaccuum line unplugged
- VSS Replacement Question
- 2 extra gaskets 171/174 kit from 1A auto?
- oil question (did 171/174 repair last night)
- 1995 start\stall
- Name That Part (with Bonus Question)
- Tail lights
- worth buying
- adjustment of washer spray heads
- Pinging & Oil Consumption
- Another Windstar heater problem thread
- 2000 windstar strut advice needed
- directions/suggestions for installing drain in trans pan
- Code P0315- Help!
- changing alternator
- 99 windstar imrc bearins leaking
- Blinking parking lights and won't start
- '95 Winstar wouldn't shift into 3rd, then stopped completely
- ford code po442 and engine miss
- Intermittent Battery Light
- RPM fluctuates with steering, is this normal?
- po705 problem resolved (was need help badly)
- Pulsating the right front brakes
- Transmission Problems
- Gas tank backpressure 1999 Windstar.
- anyone changed the TRS without the alignment tool??
- Remote Starter
- Check engine light
- Temp Gauge Acting Weird
- 2001 DTC Code P0156
- tsr connector wire diagram?
- od light intermitent all the time- 3.8 1996
- Type F trans axle fluid for 2002 Winstar?
- 1995 Windstar won't shift after running a while.
- po705 help needed badly!
- Window Motor 2001 Ford Windstar
- another cruse ?
- 2002 Ford Windstar Bumper
- Power Steering
- automatic locks on 2001 windstar
- Check your printer ink and warm up your printer. THE LIST!!
- 2001 door frame sticker missing correct Tire psi
- OD off flashing with P0741 code
- Message Center Annoyance!!
- '99 Windstar gaining negative camber on drivers side only
- Am-FM Radio and Entertainment System Sound
- 98 Wndstar won't shift
- OD light flashes for first 5 min of driving
- Power Steering Pump Pump Noise
- Intermittent misfire
- '99 Windstar runs poorly cold until warm
- flasher rate
- wipers
- Failed Spare Tire Cable/Winch System
- Entertainment System on 2000 Windstar
- 1995 Windstar power steering hose/line
- Microfuse
- Hiss from engine, 171,74 DTCs
- engine quit running on interstate
- Socket Size For Factory Lug Nuts
- 95 Windstar hestates wont go over 60 mph
- 98 Windstar Stalling
- Owners manuals online - Windstar 1996 thru 2003
- stalling at idle
- Vehicle Speed Sensor and "General Info" sticky
- Injector cleaning
- New Engine Break In 1995 3.8L
- rocker arm / adjust valves
- Seatbelt buckle switch
- windstar transmission dead ?
- Headlight repair
- Biggest transmission cooler the 95-98 will allow
- 2001 Windstar Idiot lights
- Windstar 3.8 Water pump, Heater core and Master cylinder
- CV Joint Boots just starting to Crack/Leak
- oil in coolant!
- Autozone Ball Joint Wear Indicator Inspection
- '96 Windstar front end noise.
- Parts Prices - Feedback?
- 2000 Widstar mis-fire on cylinder 5 and tapping sound
- Intake manifold runner control linkage
- Can running lean cause damage?
- Please help with windstar problem - P1518 IMRC code
- 98 windstar door ajar alarm and light
- Transmission Speed Sensor Discrepency
- P0104 P0107 on 2000 windstar SE 3.8L...again? PLEASE HELP ME
- Shuttering in low RPM, all gears, intermitent blinking CEL
- Transmission line removal RAPID ANSWER NEEDED
- 1999 windstar lx rough idle
- 2000 windstar alternator woes
- Power Steering
- 2002 Doesnt have DPFE
- 2000 Windstar SEL Door Lock Problem?
- Doorlock light's
- windstar intake knock
- Pulling the tranny
- AC how to check relay 204
- What is the little white module on the top of my transmission?
- 95 Windstar uneven break pad wear
- Mysterious front end noise
- air bag light code 21
- 2003 Windstar Transmission Problems
- 2000 Windstar Transmission issue
- Bad slipping between 2nd &3rd, but only when TRS is plugged in.
- Body and subframe separation fix: Insulators WHERE?
- Cruise control no worky in 95 GL
- change spark plug wires-01 windstar
- Revving in PARK produces odd shutter/shake 3500 - 4000rpms
- The Fastest and Furious Windstars :)
- Captains chairs or Bucket Seats into 2nd row of 95 GL
- Choosing between a like new 2003 LX or 2000 SE Windstar
- 98 3.0 Emmisions codes and Stalling
- 01 Windstar (SEL): Cannot read Codes
- 2000 Windstar PATS key
- Does 95 water pump give pre-failure warning?
- Replacing Control Panel Lights
- Airbag Light On
- Public service: US govt auction for donor vehicle in FL
- change plugs and wires on 2001 windstar
- Splash Guard?
- Just so you know on a Freestar..
- 98 Windstar code 1461 and 1462
- Opinions of value for private sale after new tranny and engine - 1995 Windstar 3.8L
- Backup sensor theory
- Replacing plug wires
- Does 95 turn signal switch have safety issue, not finding any
- any trick to removing rotors on 01
- AX4S Transmission Interchangeability 1995 - 2000
- Pulling motor 96
- Fluid Leaking
- Now running rough when cold after working in intake - '96 3.8L
- 99 Windstar ignition problems
- Tie Rods: Do Both Inners or all 4?
- Throttle Body Stuck To Plenum
- Oil Leak, Oil Pan or Crankshaft seals? 2002 Windstar
- Lubricating sliding doors
- Front end work
- power steering questions?
- '95 trans issue's.
- Drive belt and spark plug wires. What RU running.
- How hard to change the cats on 96 3.8l
- egr problems
- My heater blows cold air in front and hot air in back
- JB Weld
- 1999 ford windstar se 3.8l wont start
- 99 windstar lx 3.8
- van stalls with right turn
- '98 Windstar Transmission Repair Results a Mystery
- Sound system info!
- Do I need to change my Crankshaft Position Sensor?
- Thermostat replacement with lower temp opening setting
- Brake Pressure Switch and Cruise Control
- 96-98 engine in a 95 with AX4S transmission
- 95 3.8L water pump replacement procedure?
- 2000 Winstar door ajar
- 2000 drivers side sliding door jams up
- 95 Windstar ABS light
- 2000 Windstar will not stay in overdrive
- Alternator and Rain
- Thread size in Shredder valve
- Codes 171 & 174 ligh back after 5k
- 2000 Windstar powersteering
- 2000 Inner Tie Rod - My Experience
- Rough Idle and No Fast Idle When Cold
- codes p1506,p1152
- Stick a fork in it, its done.
- Erratic speedometer reading
- '98 Windstar Idle 'Hiccup'
- '99 3.8 LX, weird ind. lights/loss of electrical
- 2001 Windstar Heater actuator
- Cruise not working and O/D off light flashes
- 98 Windstar rear brake job
- 95 windstar rough 1st shift
- windstar trouble code 1056
- remote fob program
- 1989 ford windstar tumbler replace
- Changing alternator on '98 Windstar, pulley come with alternator?
- 98 Windstar w/trac control soft break pedal
- Front Engine Cover Coolant Leak
- 2000 windstar driver side windows: help
- Transmission shop put Mercon instead of Mercon V in my tranny, now what?
- 98 Rear Hub Assembly
- Lower Intake Manifold Gasket Leaks on 2002 Windstar?
- Windstar info
- Stalling Cold Start
- Main seal squrting transmission fluid a few days after changing transmission oil
- o2 sensor
- power locks makes nosie
- Wiswind Filter change
- Power window don't work
- Grinding AC clutch engagement
- To what degree does it hurt the transmission with not sufficient transmission oil?
- power outlet off when car is off?
- Shuttering
- lighting problems
- 14mpg with windstar in the city?
- Trans jerks
- How easy is it to change the serpentine belt?
- Drop-pan method only got 4.x Qt of transmission fluid?
- front end noise cannot diagnose
- rattling noise upon acceleration
- Squealing BELT - Which pulley
- '98 Windstar transmission shift hesitation between 2nd and 3rd gears
- 98 ABS kicks in
