View Full Version : Windstar
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
  1. stablizer bar snapped out at the top. Can it snap back in?
  2. Buying 1998 WindStar Suspensions
  3. 1998 Rear Self Leveling Air Spring Problem
  4. Late or Erratic A/C Clutch engaging
  5. Rear seat question on a 1999 Windstar SEL
  6. Reverse Sensor
  7. Suspension and Tire Wear
  8. Brake pressure switch Connection
  9. Help understanding Windstar codes
  10. Strange sounds at shutoff 98 3.8 Windy
  11. Bay area inspection and brake light
  12. 02 3.8L Coolant leak
  13. Ground location for: Horn, Airbag,&Cruse 98
  14. electrical
  15. EGR mystery
  16. 99 Windstar Random Starting Problems
  17. timing
  18. 2001 Deathstar - Shifting Problem?
  19. Windstar Sliding Door Speakers
  20. 2002 Ford Windstar Alternator
  21. just purchased "run your car on water" book
  22. 99 Windstar Sliding door simple question
  23. Windstar 2000 SEL door lock problem
  24. Windstar Dirty Radiator and Antifreeze
  25. Transmission Damage ???
  26. A/C got stucked on Defroster position
  27. '02 dryer problem- 2nd blowout
  28. Swaybar bushing bolt broke...now what??
  29. 2003 windstar transmission shutter
  30. Sliding door question (2 part question)
  31. What is a gas/fuel ABG line?
  32. monroe quick struts
  33. Not getting vacuum from pcv after replacing
  34. Air cleaner problem. I NEED HELP!!!
  35. Found a plug receptical ???
  36. how to remove ac condensor in a 2000 winstar?
  37. Windstar Electrical Ghost in the Machine
  38. 1998 windstar
  39. 01 Windstar Message Center Doesn't Work
  40. P0231 code
  41. removing '95 Windstar bumper
  42. Coil Pack or EGR???
  43. 2002 windstar - charging problem
  44. my 98 windstar idles rough, air cond and heater stop after warm up
  45. 99windstar passenger side window
  46. 2003 power windows & locks gone crazy
  47. 95 Windstar Front Wheel Bearing vs Taurus
  48. Filters falling off
  49. Whinning Noise
  50. More brake troubles
  51. '99 3.8l P1516
  52. 1999 Windstar stalls
  53. coolant temperture sensor
  54. 2000 Windstar - dragging noise
  55. 97 Windstar Heater/AC Only blows on High
  56. 95 Windstar P/S return hose quesion
  57. 96 Windstar A/C clutch not engaging
  58. 97 windstar vacuum question for a/c at the defroster.
  59. 2000 Windbag heat/cold door flapping ?
  60. dvom reads 41 milliamp draw
  61. replace check engine lamp
  62. blackstone labs - silicone in oil??
  63. Where to evacuate AC ?
  64. Behind Driver Automatic Door Question
  65. p1538 and p1131 codes 97 Windstar
  66. Another IMRC quandry (scratch head)
  67. ford windstar whinning
  68. cold air intake - anyone done this?
  69. 2002 Windstar replacement wheels/rims
  70. tire wear pattern
  71. 2000 windstar mpg ?
  72. '98 rear air - not dash switch
  73. 98 Windstar strange overdrive behavior
  74. Code P0720
  75. ABS Codes Were Pulled
  76. Tranny doesn't work right, and no speedometer or odometer movement
  77. 98 Windstar -- IMRC Vacuum Check Valve
  78. 2000 Windstar VSS splice location
  79. 2002 Windstar, P303 code
  80. 2002 Windstar, P303 code
  81. Proportioning valve leaks, need breakdown diagram
  82. 95 3.8l 200K mi, overdrive cancel switch won't light.
  83. 2000 Windstar SEL Towing
  84. Changed transmission fluid 98 3.8L
  85. '98 Windstar Rear Air
  86. 2002 Ford Windstar Brake/ABS lights on
  87. 2000 pass side door
  88. 98 A/C clutch would not engage :-(
  89. Cruise control
  90. 95 3.8l 200K mi, gas gauge goes to "E"
  91. how to "switch off" a single cylinder?
  92. Weird battery light on reverse only!?!
  93. DIY Recharging of A/C?
  94. 96 Windstar bites the dust
  95. 99' stalling???
  96. Both Radiater Fans Inop 96 Windstar 3.8 eng
  97. Heat won't turn on...cold only
  98. 96 Windstar Radiator Fan
  99. How to remove 2001 Windstar Condenser
  100. 02 Windstar Cam Synchronizer Replacement
  101. Now the FLEX!
  102. HHO Run My Car On Water - Worth It?
  103. Engine Light Will Not Turn Off
  104. Airbag code 51
  105. Electrical issues on '98 Windstar
  106. Bad fuel pump? 95 3.8L 158k miles
  107. Radiator Fans? Air-Cond Clutch;
  108. Any Mileage Chips/Programming out there?
  109. MILEAGE: 3.0=Good, 3.8=Bad ???
  110. 95 keyless pad programing??
  111. change both F rotors, not pads?
  112. Windstar NO REAR LIGHTS
  113. Having problems removing caliper anchor plate
  114. Problems finfing Mercon V
  115. Strange Squealing noise
  116. 1999 - Key Security Chip Gone - No Start
  117. FM Transmitter
  118. Rad Fan Resistor
  119. O/D light Flashing
  120. Power steering...Dangerous problem
  121. Coolant in oil,98 3.8 Windstar
  122. CEL Misfire
  123. Gas smell after driving about 20 miles
  124. Ball Joints on 2000 Windstar
  125. 96 Windstar, trans leak only on good days!
  126. leaky thermostat housing 2000 3.8
  127. PCV oil "catch can"?
  128. rubber squeak after quickstrut install
  129. Oil Leak..Please HELP 2003 windstar
  130. ABS Light & E Brake light
  131. Differences on 99-00 3.8 and newer?
  132. 2000 Windstar Power Driver Seat
  133. Strange Transmission Drag
  134. BOO Switch
  135. 2001 W-star fault lights
  136. 2002 windstar
  137. 95 Windstar engine miss to much fuel
  138. 1999 Ford Windstar SEL Speakers Going Out
  139. Liqui Moly, MotoDoctor, etc.
  140. 95 window motor binding repair tips
  141. 95 hood latch adjustment tips
  142. power window
  143. Water bypass tube part number
  144. where to get coolant...
  145. climate control problem
  146. Replaced sway bar link
  147. 1995 Ford Windstar Power Windows Inop (Front)
  148. Grinding before and still after brake install
  149. Power Sliding Door Latch
  150. Parts
  151. spark
  152. car fax
  153. Engine OUT
  154. severe valve knocking......
  155. Mysterious thump sound - suspension?
  156. Air Cond, Compresser
  157. Air Cond, Compresser
  158. please help me on fiquiring out this obd 2 scanner
  159. "Door ajar" light, and buzzer
  160. Need help with P1518 & P0303!!!
  161. A/C Blowing through the Defrost Only
  162. Fuel consumption display
  163. Recharge the AC
  164. how can u pull a code check without a high price machine
  165. quick struts price
  166. 95 windstar squeak sound
  167. i need help please on 96 ford windstar mini van
  168. just bought a 96 ford windstar and replaced a moduale
  169. Airbag Diagnostic Code 23
  170. catch can not "catching"
  171. install armrest 2001 windstar
  172. Master cylinder repair time
  173. 1999 Windstar will not idle
  174. Side door can't open from inside
  175. clicking heater door on 2001 windstar
  176. 95 Windstar coolant problems
  177. Engine Mount Replacement
  178. Front Wheelbearings
  179. 2002 AC compressor not pumping
  180. need tires and advice
  181. Odd/Irritating Start Problem
  182. driver window not working
  183. 95 start\stall *Fixed*
  184. rear a/c windstar 2000
  185. No fluid to rear wiper
  186. Wouldn't turnover then started what's up
  187. transmission fluid ??
  188. 99 Windstar engine misfire and burning oil
  189. 1999-03 Ford Windstar 3.8L Intake Manifold & Valve Cover Repair Kit
  190. hot engine hard start, poor idle
  191. o/d off light flashing HELP
  192. 98 3.8 rough idle missing? tried many things :(
  193. clicking in dash on 2001 windstar
  194. Need help to know where to tow the thing
  195. interior lights
  196. 99 Windstar trans Prob ??
  197. Blowby ?
  198. Parking assist
  199. 2001 wont start
  200. help me
  201. Power Steering Pump Replacement
  202. Rusted cradle
  203. 99 Windstar Front Brake Rotors
  204. Water pump removal information
  205. 1999 windstar a/c clutch not engaging
  206. 2002 se oil plug bolt
  207. PCV catch can install w pictures
  208. Thanks
  209. Buying parts for 171 and 174 overseas
  210. 2003 LX Rear Drum Squeak
  211. 2001 SEL 62k Trans flush & compass questions
  212. 2003 LX High Idle warm or cold
  213. I think I'm in trouble
  214. Power steering noise
  215. Little tid bit about synthetic oil
  216. anyone subscribe to HELMINC Ford online website?
  217. Inner tie rod - my scary experience
  218. Defrost only!
  219. 1999 Windstar Power Door Lock Trouble
  220. location of ecu
  221. Win 95 3.8 with 171/174 Codes Help
  222. 96 Windstar start problem
  223. funny "rubber" squeek sound at front end
  224. anyone done the front subframe welding?
  225. 2001 - No front A/C - Rear A/C Works
  226. oil filter
  227. rigid to flex brake line help needed!
  228. 2003 Rear Power Window Motor
  229. 2003 Hard Shifting after tranny Service
  230. 98 Windstar Electrical Diagram
  231. fuel system status
  232. Fuel Injectors
  233. Cold Start - Rough Idle
  234. Struts on 1999 Windstar 3.8L
  235. 97 WS - Both Power Windows Out (and Rear Wiper)
  236. Humming sound coming from front end?
  237. rear brake shoe - 2000 windstar
  238. Driver Side Electrical Pannel Cannot Move Both Front Power Windows.
  239. IMRC actuator, help
  240. Just making sure I'm not missing something
  241. windstar bad hesitation
  242. 2002 Windstar - Stalling when cold low spd
  243. 96 winnie 3.8L cel codes
  244. Radiator Fan Droping Resistor assistance.
  245. 99 windstar heater door problems
  246. Attempts stall, Idle Pulses 600-800 rpms, horrible MPG
  247. 98 Windstar Braking Problem
  248. Dash Lights
  249. 96 windstar cooling fan issues
  250. 98 Transmission
