View Full Version : Focus | C Max
- 2012 AC evaporator change
- Engine Malfunction
- 2016 1.0L Focus Sudden Oil Pressure Loss
- 05 focus zx4 accelerator cable
- Crank sensor replacement
- 2005 Ford Focus 2.0L Rough Idle & Low Power
- Lower right side dash
- Hearing a “thoom” sound when turning steering wheel
- transmission removal
- Can't get Focus into gear (manual)... and then I can. until I can't...
- Impossible to start the car or unlock the doors
- 2012 Ford Focus Air not blowing through vents
- Coolant loss
- 2010 Focus SE Transmission Whine
- Transmission not in park
- 2007 Focus wagon SE info input
- 2013 Focus 2.0L - How to get battery out and back in?
- Hard braking causes chime
- Smart key ford focus 2016
- 2012 Focus SEL noise while backing up
- Tire size question
- 2014 parts in 2017 focus
- 2012 ford Focus SE - No Reverse Then Starts working
- 2012 Ford Focus oxygen sensor
- Just bought 2008 focus 125k, vibrates as soon as I turn on.
- Ford Focus 2006 zx4 lost all power
- 2014 Ford Focus Unidentified Part - Please Help
- 2010 focus alternator
- 2003 Focus wagon, brakes mystery
- electrical issues
- 2012 Focus W/S wipers Crazy
- 2012 Fcous Suspension
- 2010 Focus without cabin air filter
- 2013 Ford Focus won't turn over
- Is it that darn fuel pump? Or... Help
- Focus 2012 SE Digital odometer after flood
- 2005 Focus Starting Issues
- Engine won't turn over, 115K miles, starting issues
- 2005 Ford Focus
- 2006 Ford Focus Won't Start - PATS Flashing/Dashes where mileage should be
- 2002 Focus Won't Engage In Park
- 2012 Focus SEL - SES Light and Codes (P0805, P087a, P2831, P2832, & P2836)
- 2003 ZTW, alternator
- Ford Focus 2012 Front Wiper Problems
- 2013 Focus ignition key sticking
- squeal
- 2003 Ford Focus won't start
- No low beam on driver side
- poor fuel economy with random
- Focus wagon idles rough when engine is warm
- 2012-2014 Ford Focus Steering Wander- FIX
- 2007 Ford Focus Vent Selector Broken
- 2011+ Ford Focus & Fiesta Powershift Clutch Shudder FIX To Try At Home
- Instrument panel goes crazy
- Ford Focus & Fiesta Powershift Dual Clutch TCM Failure Symptoms
- Polish to Scraches
- New Experience with Focus !?
- Ford Dual Clutch Warranty Extension Details and New TSB Clutch Parts!
- 2003 Focus ZTW wagon, rear wheel bearing
- Timing belt issue
- Help with 2010 SEL Idle Issue????
- 2012 focus a/c short cycle
- Ford focus fuel pumps
- 2012+ Clutch Replacement Demonstration
- 2012+ Transmission Shudder Issue Explained
- 2003 ZTW, Numerous issues
- Low Temp Gauge??
- No Start Theft Light Blinking Easy Fix
- What the hell is this noise !!!!
- Oil filter gasket (Fram) separated
- No Throttle Response DTC's P1235
- Air Bag Light On B1932 Drivers Air Bag
- 05 focus wagon brake light/turn signal
- 2012 focus se stereo upgrade to the 1 out of the titanium model
- looking to sell my focus
- Shift Solenoid A P0750 No 4th Gear Repair
- Sticking Throttle Repair
- Battery Light
- 2003 Focus, hesitates
- Resetting the PCM after Repairs are made
- Richard Hammond review of the Ford Focus Hatchback
- Engine Clean Up - Never Wash
- Zetec Oil Leak
- 2008,Ford Focus No Reverse Automatic
- Zetec Oil Leak from Valve Cover Gasket
- ford focus zx3 2002
- Focus MK2 self-service
- hef719
- 2003 Focus , Drives for 20Min at a time.
- 2009 focus High RPM and Transmission not shifting proper
- 2007 focus sport dash lights
- Engine torques
- 2003 Focus Dropped valve seat
- 2003 focus wont start
- Focus non-servicable parts ? Advice please !
- Ford focus door lock mechanism
- 2012 tire size question
- SPI to Zetec swap Problems
- 02' Focus ZTS low gas mileage
- Ford Focus 06 Door Lock Problem
- Ford MPG Fraud
- 2005 Focus instrument panel warnings dim
- Door ajar light flickering
- help needed with my 2000 focus
- Focus hatchback lock mechanism
- Dashlights Not Working
- 2012 Focus Message Center Display is Goofy
- transmission problems?
- Focus auto locks even if car not moving
- Can I increase idle rpm
- A more fuel-efficient Ford Focus
- 02 focus oil filter
- Tyre issues Ford focus
- Focus 2001 1.8 TDDI - battery drain
- 2002 Ford Focus- car sputtering and then shutting off
- 2012 ford focus fuel pump problem
- Recomend Cam shaft
- 03 Focus - 2.0 SOHC P0302 & P0316
- 2013 Focus Sirius Radio
- Focus rear tire inside edge wear solution
- loud air sucking sound and rough idle
- no reverse lights
- 2nd Ford with sudden acceleration !
- Wheel Nut torque 2002 Ford Focus
- Dead Ford Focus 2001 ztec 2.0 !!
- Alternator or battery?
- 03 ZX3 Power Steering Pump
- 2001 a/c problem
- 04 engine problem
- Alternator
- 03 Focus coupe ZX3 #4 NO FIRE
- Oil Filter Missing/Seized Engine - Dealer Claims "Stolen"
- Can someone help me?
- Transmission Codes 0765 and 0770
- 03 Focus Rack and Pinion Leaking
- Torque Android App
- 02 focus wagon. No crusie
- 2011 Ford Focus rear signal
- Ignition Fuse
- Transmission Problem???
- Bypass module has everyone stumped!
- engine switching off/stalling after 10 mins of driving
- 03 Dropped a Valve
- Stalling while idling - in park
- Rear Passenger Door External Handle
- 09 Focus Driver door stuck closed
- 2000 Focus 'no-start/run' - Alarm???
- fuel problem
- 2008 Focus timing belt & brake questions
- Rough idle - shut
- Rear disc brake pins frozen in Bracket
- new fuel pump, no pressure
- 2002 Focus 6 cd/radio in dash
- 02 focus cylinder 1 full of fuel
- 2003 ZTW, no headlights at all
- 2001 ZX3 serp belt tensioner
- Found a fix brake, running, liscense plate light or trunk release problems.
- 2003 Ztec Focus ZX3 with oil in vac line?
- Installing after market driving lamps - 2003 Focus SE sedan
- 200 fosue se hard idling
- 2002 Focus starting problems
- 2002 Ford Focus Clutch or Electrical ?
- 03 lx Speedometer Jumping
- Ford Focus 'stalling' problems after driving off curb
- motor swap 2000 focus se wagon
- OBDII readings, does this mean the O2 sensor is dead?
- Fuel smell
- Speedometer issue!
- Window Regulator
- Car wont start when its hot.
- 2002 Focus A/C Condenser
- 2007 Ford Focus SES ZX5 fuse problem?
- 2012 Ford Focus Review
- Help Me Please!
- Rear Drum Brakes
- 07 Focus shutters on braking and accel.
- 2000 Ford Focus power locks quit working
- Overheating& air conditioner
- 09 Focus Rims peeling
- car is hesitating and has weird gear changes
- Engine fan constantly runs and is loud
- 2005 Ford Focus ZX4 - Timing Chain?
- Any fellow hypermilers?
- 2003 Focus - Keyless Entry
- 2003 Focus - Engine Questions
- Poor fuel economy
- 2003 Focus power window collapsed
- focus consuming too much gas
- 2002 Ford Focus Transmission Problems
- 2006 focus zx4 automatic transmission problem please help
- Door panel
- Urgent ! Ask your help ! The Focus skylight fly out on the high way !!!
- Overdrive Off function
- 2003 Focus Stalling Problems
- [2004 Zx3] P0128 Code - Temp Gauge works fine.
- shifter cables
- Ford focus starting problems
- an 04 focus No ABS?
- Cigarette lighter scocket doesn't work
- P0171 code problem
- Tire rotation and waves in tires
- Wheels Wont Spin Please Help?
- 04 focus zx5 steering problem
- Brake short
- '09 Focus SE w/19K Mi. & clutch chatter
- 05 focus issues, please help
- 01 Power Steering Pump Pulley
- 05 Focus tranny problem
- 2011 Ford Focus picked as Official Car at Consumer Electronics Show
- Totally Stumped (Deep Rumble) 2002 SE
- battery causing alt overcharging?
- 2002 ford focus 2.0L ztec shifter problems
- 2012 Ford Focus
- 03 Focus cuts out during acceleration
- OEM battery terminals
- car coasts ?
- 07 coil resistance
- Lean AFR with fuel rail pressure sensor plugged in
- 07 focus battery light intermittently comes on
- 07 ficus battery light intermittently comes on
- ford engine problems don't konw what to do
- Leaking Power steering pump
- 2000 Focus Headlights
- WTB: 2005 ford focus cd player good / bad
- 2003 Focus Rough Idle on Cold Start
- 2000 Focus SE Stumbling & Stalling
- 00 Focus- No Brake Lights on Right only
- 2007 Focus Heater / AC Fan
- Focus engine sputter
- 01 focus sohc dead cylinder
- what more to pull center console?
- Focus ST
- high cooling fan doesn't work
- 2006 Ford Focus...
- Ford Focus luggage section
- A/C runs cold then runs hot
- Just bought - need a new engine, help!
- 2003 Won't idle when hot
- 2000 Focus mouse in fan blower
- 06 focus..blinking pass airbag light
- 05 Focus ZX3 A/C only cools when accelerating
- 2001 ford focus
- 2001 ford focus
- 05 focus ses 2.0l
- rattling in front suspension
- Seasonal front end squeak?
- stuck seat belt buckle
- Focus wheel bearing
