View Full Version : S-10
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24
  1. S10 high idle
  2. Switching Fuel Injection to Carb
  3. late 2000 S-10 w/ some 2001 parts idle problems
  4. 1992 Temp Gauge Crazyness
  5. Engine won't crank after intake removal and put back on
  6. 99 S-10 transmission slipping
  7. 4.3 Supercharged or 350 ???
  8. 1993 S-10 Blazer 4dr 4wd
  9. 94 S-10 Blazer Tahoe/Runs but dies...Help
  10. Lifter knocking, will it get worse
  11. HELP!!! Rusty (Leaking) Fuel Lines on 4.3
  12. Fuel Pressure and the filler neck...
  13. Short in wiring harness
  14. Pearl White or Metallic Silver
  15. Chevy S10 Tahoe short/wont start
  16. popularity
  17. Changing Rear End Need Some Info Plz!
  18. 1992 vs. 1993
  19. Fuel pump
  20. interior electrical circuits
  21. How can you tell if your exhaust pipe is clogged or not?
  22. 4.8 Liter?
  23. 98 ZR2 4X4 front end noise,fuse blows
  24. My truck won't start
  25. '94 s-10 WON'T START
  26. S10 spark plugs
  27. 2.8 88 s10 stalls and sputters at idle without brake depressed and dosen't w/brake
  28. need transfercase help
  29. Heater
  30. Idle Problem 1992 s10
  31. 1997-1998 s-10 door panel
  32. Intermittent Valve Tap -- V6
  33. Need parts for my truck...dont know where to find them...
  34. Just did CPI replacement on a 94 s10 blazer
  35. "service engine soon" light on... '98 Blazer
  36. Computer Virus Alert
  37. 1986 s-10 headlight relay
  38. Water Problem
  39. s-10 blazer fuel pump relay
  40. Need a 4'' lift kit for a 94 S-10 Blazer
  41. Big Feet?
  42. 1998 Chevy S-10 heater core removal help/advice
  43. Hoping for some electrical help
  44. 85 s10 loss of power
  45. 1998 s-10 spark plugs
  46. Aftermarket parts/acc
  47. help with remote starter
  48. Rebuild Kits
  49. 305 and 350 block and parts question
  50. Coolant Leak!
  51. Electrical Question
  52. S10 fuel pump problems
  53. Full tune-up questions
  54. Oil filter location: 1995 chevy s10 4.3L vortec
  55. Battery Draining
  56. Any body need a 4.3?
  57. clutch problems, what have I done
  58. major problems: 93 4.3l vortec
  59. A horn fuse blew out, and I dont know which one it is...
  60. Speed Sensor
  61. clutch start switch 2001 s10
  62. EGR valve replacement
  63. temp gauge
  64. Need help withe central electric locks
  65. Must read; Don't buy anything from this guy
  66. HELP! Engine wiring harness diagram ECM to fuse box
  67. 1991 S10 brake bleeder screws
  68. How much is a decent paint job?
  69. 87 s-10 2.8l engine problems NEED SERIOUS HELP!!!
  70. V8 engine swap
  71. crew cab forum
  72. Brake Leak
  73. Transmission Sounds Like A PTO!
  74. 94 s-10 Annoying suspension vibration
  75. Transmission leak?
  76. Heat always partially on.
  77. Few Problems
  78. Squeak sounds like it's coming from....
  79. Differential Oil
  80. parking brake lamp
  81. 95 S-10 Misfiring
  82. alldata
  83. Coolant odor in cab
  84. parking light ?
  85. 87 s10 gas gauge
  86. Buzzing noise when headlights on
  87. speedometer not working
  88. Engine surges at higher rpm when cold
  89. Tsb
  90. Tsb
  91. 84 5 speed blazer s-10 tranny removal?
  92. 94 S10 loss's power
  93. 93 S10 Tailgate
  94. Heat always on after heater core replaced
  95. no start condition
  96. safty first guys... seriously...
  97. 1985 S-10 Durango not starting...
  98. PO122 code
  99. Distributor Problems
  100. 94 s-10
  101. Does anyone have a really hooked up s10?
  102. No Power Locks...heater fan...
  103. starting problems
  104. Weird Electonic Happenings
  105. truck pics
  106. ecm problems
  107. Where to find good online info for free
  108. Obscure problem or do Duralast parts suck?
  109. engine 'roar'
  110. turn signal antics
  111. any1 know a good place on the web for custom s10 parts?
  112. Has there ever been a diesel S10?
  113. 1991 blazer won't accelerate
  114. Need Help Replacing upper hinge
  115. did Midas make a mistake?
  116. *** 96 S10 4.3 Fuel pump prbl ***
  117. Aak! There's SMOKE coming from my dashboard!
  118. how many miles does your chevy have?
  119. umm what happens when you drive without brakepads for a while?
  120. Crap i think i messde up my a/c =(
  121. Timing Problem? '89 S-10
  122. a problem with an '89 idling engine
  123. Need help on where to place sound system
  124. At what speed does your S10 change into 4th gear?
  125. Lifter replacement 97 S-10 4CYL
  126. Transmission Removal
  127. replace waterpump yes or no
  128. 4.3 Starts but stalls
  129. 383 swap
  130. 2.8L engine mounts on frame
  131. PO442 small leak evap system?
  132. Transmission Weight
  133. It won't start at all
  134. Transmission
  135. 1987 chevy s-10 tahoe?
  136. how to remove center support bearing?
  137. Blowing ECM 1 fuse maybe a short?
  138. Speedo Woes-Need answers.
  139. Heater motor issues....
  140. 94 4.3 Vortec skipping under load
  141. windshield wiper grill
  142. truck pics
  143. 95 blazer - random misfiring
  144. How To Drain Fuel Tank
  145. cant find fuel pump relay
  146. Stuck Distibutor
  147. Looking for: Stock Stero Wiring Diagram.
  148. Custom Lifts 98 ZR2
  149. electrical troubles
  150. 1997 s-10 wont start
  151. 99-s-10 v6 won't start
  152. what do u think?
  153. Coolant leak, but where?
  154. Automotive Forum Member Praise
  155. got my Ravin exhaust
  156. Door pin and bushing repair How-To!
  157. Clutch Problems 91 5 speed
  158. WRECKED my S-10!!! Help!
  159. 95 2.2 sonoma 107k miles
  160. Valve stem seals, anyone in the know?
  161. '87 S10 location of fuse for fuel pump
  162. 99 Blazer Hesitation
  163. Does code P420 mean I need a new cat. converter??
  164. 1993 S-10 Blazer PROBLEMS!!!
  165. 2.8L serpentine belt diagram
  166. throttle body spacers, worth it or not?
  167. 1999 s-10 clutch problem
  168. The elusive door sping tool
  169. hop ups for 92 s-10 (4.3)
  170. Tire Topic
  171. 94 S-10 V6 monster
  172. Brakes making a squeaking noise
  173. 89 S-10 Runs short time then dies
  174. Aftermarket wiring harness
  175. 94 Silverado
  176. 1998 Chevy S-10 headlight problem:
  177. oh shit
  178. 92 s-10 performance
  179. Pulling Motor
  180. Front Signal Light Problem
  181. swapping in engine from a newer S-10
  182. 91 s-10 truble
  183. electrical problems with ING/GAUG fuse and Good alternator not charging battier
  184. 98 s10 2.2 coolant system
  185. help!! 4.3 drivability problems
  186. No first gear
  187. dash/parking lights
  188. 2000 chevy s10 w/2.2L
  189. dash /parking lights
  190. 1996 S-10 Won't Start
  191. 4x4 help
  192. Broken Mounts
  193. 4x4 suggestions
  194. 88 s10
  195. swaping out 4.3 vortec motor
  196. Manual Transmission Fluid Type
  197. Clutch fluid problem... slave cylinder leaking??
  198. 87 S10 Will Not Start
  199. Clutch or Slave Cylinder??
  200. engine swap
  201. 1993 s-10 ECM support
  202. Shifting 3rd to 4th
  203. ghostly, banned car commercial
  204. how to post pics
  205. 84 S-10 connected battery terms. wrong
  206. please help me stop clutch/transmission noise!
  207. Wont go into self-diagnostic mode.
  208. '02 S-10 cuts-out accelerating...Egn Light On
  209. bench seat to bucket seats conversion
  210. S10 - Sonoma Window Electrical Problem
  211. 98 S10 Throttle Body
  212. 4.3L to 2.2L Transmision Compatibility
  213. possible clutch problem
  214. 83 S-10 2.8 several issues..
  215. My personal web space is updated!
  216. Got some questions on a 4.3 to 4.3 swap
  217. Axle locked-up
  218. Will not start 2000 S-10 p/u
  219. 1996 S10 Starting Problem
  220. rear brake/turn signals
  221. Driveability-surges-hard brake pedal(new booster) misses-generaly runs like crap have
  222. vapor lock
  223. fuel injector question
  224. booster to pedal HELP
  225. NOOB - Looking to do a 350
  226. What does code p1222 fuel pump circuit voltage low mean
  227. newbee brake problem
  228. 1984 s-10 motor
  229. broken release cable
  230. transmission downshifts at top speed
  231. Please Help Stumped On This One
  232. 1993 s10 p/u *STARTER*
  233. No heat coming out at all
  234. heater fan switch does not work on high
  235. rough riding when between 35 - 50 mph
  236. Over Heating 2
  237. Clutch assembly
  238. Broken motor mounts
  239. What would you do?
  240. 87 s-10 rear transmission seal
  241. 1995 s-10 blazer, engine code W
  242. hard starting
  243. AC Orifice Tube
  244. 95 tranny
  245. shocks bouncing
  246. clutch
  247. 92 4.3 CPI s10 4x4 rough idle
  248. knocking on acceleration
  249. wheels and tires
  250. 95 Chevy Won't Start, No spark
