View Full Version : Eclipse 2000+
Pages : 1 [2] 3 4 5 6 7 8
  1. Dash
  2. 2006 eclipse gs airbag light stays on
  3. Orange film on gauge cluster?
  4. 01 Side Exhaust
  5. need to reinstall shift knob!! help!!
  6. how hard is to install a cold air intake??
  7. Used 2003 Eclipse GS
  8. 2003 Eclipse GTS- suspension problem?
  9. WTB: Stock Intake 3rd Gen V6
  10. HOW Do I add PICS on my profile?????
  11. Premium gas for 3g 3.0L GT (Can regular?)
  12. eclipse gt 01 on ZEX
  13. I think it is my HEATER CORE..what do you think???
  14. 2000 eclipse gs turbo help
  15. WTB Factory Infinity Amp for 2001 eclipse GT
  16. PLEASE HELP!!!!!!! 2001 eclipse spyder gt check engine light
  17. PLEASE HELP!!!!!!! 2001 eclipse spyder gt check engine light
  18. So I think I'm retarded...
  19. Antifreeze/Coolant disappears from reservoir. (3g)
  20. Lag/high RPMs with Acceleration... 03 Eclipse
  21. Engine Swap
  22. Good Chance To Make Fun Of Me (engine Swap)help!!!!
  23. need blinker cover...
  24. clutch squeak
  25. Engine Swap Help!!!
  26. Low / High beams...
  27. Security System Killing Battery
  28. Aftermarket headlight HELP
  29. Headers
  30. 2006 + eclipse?
  31. 3rd brake light removal on 03 eclipse
  32. 3rd brake light removal on 03 eclipse
  33. cooling system problem
  34. Rust!
  35. synchronizer
  36. wierd grinding from pass. side (in dash)
  37. How to bypass factory amp on 03 eclipse gt
  38. stuck gearbox
  39. need alittle help please
  40. eclipse 01 - what are these parts called?
  41. Transmission Problems
  42. V6 Spark Plugs
  43. Eclipse 03 w/ Blitz body kit, Blinkers???
  44. Broken Strut Tower
  45. big 3 upgrade
  46. Please Help Fast!
  47. 2002 eclipes wont start 2.4 eng.
  48. Installing Remote Start
  49. 2001 eclipse
  50. Buying Eclipse?
  51. so anyone need a box?
  52. what bodykit is this?
  53. HID brands
  54. Transmission Blues
  55. SES again
  56. 01' GS Won't Crank
  57. INtake??
  58. Exhaust?????????//
  59. 03 Eclipse Gt
  60. help
  61. Question about the cat
  62. SES light
  63. piece of spark plug went inside spark plug hole, please help
  64. got bored with a dremal
  65. 2001 GT ecu location help!!
  66. after market gauges
  67. need a little help
  68. Look What Someone Did.
  69. Best duel exhaust for 3g
  70. heater not blowing warm at idle
  71. low oil pressure light comes on at low rpm
  72. Stalling My Eclipse
  73. Noise when clutch isn't pressed.
  74. Drifting Your Eclipse
  75. Set of stock rims for sale
  76. car got jacked...big time
  77. need help plz
  78. Not starting! Why?!
  79. The seat back question.
  80. Battery or Alternator or other???
  81. Rear Seat Backs - Drive with them up or down?
  82. 2001 Eclipse Top replacement
  83. Need help:(
  84. 2000 eclipse 3.0 cranks but won't start
  85. which projectors look better?
  86. In Dash Tweeter for 04 Spyder
  87. Smoke...
  88. 2000 GT won't start.. Help!
  89. Rattling
  90. Radio/Clock Problems
  91. Electrical Short
  92. headlight adjustors dont work
  93. need help
  94. weird noise
  95. Connecting IPOD to Infinity Stock Stereo
  96. How to program the Factory Remote
  97. Err over heating problem
  98. okay, another problem
  99. Dickless pieces of shit...
  100. do you know how to take out an EGR Valve? 2000 Eclipse GT.
  101. wiring issue
  102. A few quick questions
  103. speedo accuracy
  104. Please help
  105. Please Stop
  106. wanted to know if you can hook up a amp and speakers to a stock radio
  107. a/c problems
  108. Making a clicking noise on the right front side when I break
  109. suping up a 4banger
  110. Need Help...
  111. engine swaps
  112. Recent Problem
  113. How to get better mpg
  114. Car Problem with 2000 Mist. Eclipse GT
  115. 2001 eclipse spyder GT performance upgrades
  116. turbo...good deal?
  117. vibs bad when in gear
  118. Engine Blown...HELP!!
  119. Just got my 03 eclipse
  120. stock radio and dash speaker on a 01
  121. help with leaks...
  122. Car won't IDLE
  123. New Buys
  124. egr trouble
  125. Parts
  126. Power seat fuse question
  127. Differential
  128. Insurance
  129. air intakes
  130. Biggest Bang For Your Buck
  131. Looking for grille inserts
  132. Car goes to Hot when idle
  133. Draining power?
  134. 2001 Mitsubishi Eclipse EGR code
  135. Vr4
  136. misfire cylinder 2
  137. Saying Goodbye
  138. 2k Eclipse clutch problem
  139. 2002 eclipse spyder engine swaping
  140. Code 1610
  141. Changing Spark Plugs
  142. Worth it??
  143. Trunk space
  144. Underhood fuse box question for an 03
  145. Whats some good name brand tail lights?
  146. Exhaust
  147. lighting problems
  148. Any of yall using EvoScan or Nology?
  149. so little wires and not a clue
  150. appearance?
  151. exhaust ?
  152. 2001 eclipse backup light wont go off
  153. Another Clutch Question
  154. louvered Rear window
  155. rubbing noise
  156. Clutch going bad?
  157. Tire Opinion
  158. Transmission Temp Question
  159. 2007 Eclipse?
  160. parking light problem
  161. WHY Do this to the car????
  162. Broke my crankshaft pulley
  163. Brakes & Rotors
  164. weird clutch noises
  165. windows
  166. Need some info on a harness
  167. Just a curiosity question
  168. '03 center dash speaker
  169. 2000 Eclipse Error Code
  170. 2001 Eclipse GS speed sensor
  171. ? needs answering quick about a turbo
  172. 2000 3.0 oxygen sensor need help
  173. body kit
  174. WpBoosted3g
  175. Strut, bushing, or swaybar?
  176. Replace tie rod for 2003 Mitsubishi Eclipse
  177. Just got my 01 eclipse, gonna mod it.
  178. Fuel Injectors?
  179. 2002 Eclipse GT question
  180. CLutch Trouble
  181. 2000 recall
  182. new eclipse.....?
  183. Seat Belt Guide
  184. SPEC clutch help
  185. Stock Head Unit *Error* Codes
  186. Need help with o2 sensor
  187. clutch slipping
  188. supercharging
  189. Keyless remote programming
  190. eclipse heating problems
  191. Please, HELP!!!
  192. FS: 2003 Eclipse
  193. 2001 GT Eclipse Turbo or SuperC help
  194. Need CD/Cassette Radio for a 2000 Eclipse
  195. Product review: tires Dayton ZR 215/50/R17
  196. weird sound
  197. Cheap mods for 2001 eclipse GS
  198. Infinity stock CD player help!!!
  199. turbo kit 2000 eclipse gt
  200. 2006 Eclipse Gt Spyder
  201. 2000 Eclipse GS window Stuck
  202. backup lights
  203. GSX Revival?
  204. Re Bulid my v6 gt motor
  205. Transmission issue
  206. Bad Reviews!! HELP!
  207. Ever Notice?
  208. 2007 Spyder Suggestions and Help needed
  209. Suggestions
  210. Air Filters
  211. Hello fellow Eclipse owners...
  212. Stop Posting In What Car To Choose Thread!!!!!!!!!!!
  213. shaking/smoke smell
  214. Spark Plugs!!!! I Need Help!!!!
  215. whistling out the exhaust
  216. ??????forced induction???????
  217. Headlight Bulbs!!!
  218. Revs dropping and rising
  219. Happy New Year everyone!
  220. Transmission conversion??
  221. Wiring guide
  222. Is my transmission my probmlem??????
  223. ticking in my engine
  224. 2002 ecu location possible flood damage
  225. Heater Problems
  226. High Stall Torque Converter?
  227. I need codes
  228. Cold Temperature Problems?
  229. headlight wire clips
  230. Flood damaged car.
  231. Update software?
  232. Stuck in the Midwest
  233. manifold differential pressure sensor
  234. 2001 Eclipse Headlights
  235. Is it worth it to put on suspension or have shop do it?
  236. dumbass in need of some assistants lol
  237. engine shuts down in the middle of the street
  238. Max Rev Turbo Kit
  239. eclipse guys in florida
  240. 2003 Eclipse RS, AT transmission shift bump
  241. Rough engine sound
  242. Fuel Filter need
  243. WTB. lifters
  244. Dual Exhaust
  245. turbonator does it work?
  246. i need some advice
  247. need some advice
  248. mitsubishi eclipse stock radio center display
  249. 2003 Eclipse RS, AT transmission forces to shift gear
  250. 2003 Eclipse RS, AT transmission forces to shift gear
