View Full Version : Ninety Eight
Pages : 1 2 [3]
  1. For Sale:96 Nintey-Eight Regency Elite under KBB
  2. hi everyone
  3. Child safety features making me crazy!!
  4. 1977 Olds 98 Dashboard removal
  5. Please clean key and try again in 3 minutes
  6. 1991 Olds 98 problems
  7. Transmission Clutch Converter Lock (TCC)
  8. replacing r12 system 88 98 regency
  9. 85 Old Delta 88
  10. 90 olds regency window
  11. Transmission and Engine Woes on my '91 98 RegElite
  12. 3.8 liter Comparasions
  13. 1991 Olds 98 Regency Radio and CD Wiring Solutions
  14. Intermittent engine miss
  15. Fuel filter location
  16. blink codes - older GM cars
  17. side mirror for 92 Olds Regency Elite
  18. '88 98 sputtering, backfiring and cutting off. ICM?
  19. Amplifier power wire
  20. '90 Ninety-Eight A/C blower and front panel vents
  21. How long has yours lasted?
  22. '88 98 underpowered and whining
  23. 1991 Regency,no run but turns over
  24. Regeny Sound System
  25. My 1987 98 Regency Brougham
  26. Change Engine oil light issue
  27. Keyless Remote Compatibility
  28. 1988 98 regency brougham problems
  29. 57 Olds question about deck lid molding/trim
  30. 1979 Olds Regency 98 HELP I need.....
  31. Engine/Tranny Upgrade
  32. Hard Start/Rough Idle. Guzzler
  33. 1990 88 Transmission
  34. Rear brakes and shocks questions.
  35. Boost horsepower?
  36. diagnostic codes
  37. Will just quit running
  38. 20 in wheels
  39. Won't start problem
  40. won't start
  41. coolant leak from tube in intake help please!
  42. Electrical Problems
  43. Short killing battery
  44. firing order
  45. transmission problem
  46. 98 regency-fan not spinning
  47. Small motor running ? 89 Olds 98
  48. 1989 Olds 98 Heater issue
  49. can i puy custom head lights in my 89 ts?
  50. torque convertor
  51. What to install in my 86'98Regency
  52. 1990 Ninety-Eight ECC Programmer/Door Linkage
  53. Any 85-88 98 Regency Owners here?
  54. 90 Olds 98 - Engine quitting
  55. 1994 Oldsmobile 98-Fuel Pump
  56. 98 parts compatible with an olds 88?
  57. Need Suggestions.....
  58. 1990 Oldsmobile question
  59. How do I get my old radio out?
  60. DLC on a 92 98
  61. Help 77 Olds 98 no heat
  62. SES/Temp Light, Speedometer to 0, Engine Stalls PROBLEM FIXED!
  63. Olds 98 Door Assembly
  64. Problem with my 88 Ninety Eight Olds
  65. 1981 Olds Ninety Eight Engine/Tranny SWap
  66. My "New" 1988 Touring Sedan
  67. Trouble Code 12
  68. DLC location on '88 Regency?
  69. battery drained
  70. steering wheel control panel
  71. 1988 Regency
  72. dual exhaust on a '90 98 regency
  73. ABS/Brake lights flash, Hard braking
  74. Rough idle, service engine light, and a funky exhaust smell....
  75. Supercharger issues
  76. 90 Touring Sedan climate woes.
  77. My first Olds (any info please)
  78. Remote Keyless Entry Programming
  79. 1990 oldsmobile Stalling out
  80. 95 Regency Sluggish Cranking
  81. '88 Ninety Eight power door problems!
  82. oldsmobile stalls
  83. automatic windows
  84. Big Water Problem
  85. 455 engine swap to a 1954 oldss 98 2d htp
  86. where is my flasher
  87. A/C Motor
  88. a few questions about my 89 olds
  89. keyless entry program?
  90. Car just dies as I am driving. HELP!
  91. 92' Regancy elec.(sun,moon) roof prob.
  92. Rough idling
  93. Help!!!! Raido Is Loc
  94. MAF Sensor, Clean vs replace
  95. Transmission
  96. 1983 98 towing capacity
  97. 1989 ninety-eight PCV valve
  98. Radio died, screwy electronics
  99. 79 NinetyEight 403 -- Need advice
  100. 93 98 Regency Electronic Problem
  101. 1986 Olds 98 won't start
  102. map sensor
  103. 1979 Olds 98 No Start
  104. 1984 Oldmobile 98
  105. crankshaft sensor on 98
  106. antitheft module
  107. button for trunk stoped working
  108. antitheft module
  109. fuel problems, any tips?
  110. Radio help.
  111. BIG Car Problem!!
  112. Help, please!
  113. Turn Signal Problem -- All Lights Flash At Once
  114. 92 Regency Elite Blower runs after key is off
  115. 1989 Ninety-Eight Regency Starting problems
  116. Help Needed
  117. Planning to sell a 1976 Regency 98
  118. Parting out 1990 Olds 98
  119. 3800 oil pressure
  120. 3.8 conversion to 3800
  121. Uncomfortable seat
  122. "94 Olds won't start
  123. Help! Can't find brake lines!
  124. Radio problems
  125. flasher
  126. Help please! '94 does not start at random times
  127. Heater not working in '87 Olds 98
  128. 81 regency 98
  129. 1988 Olds 98 Regency Specs
  130. 89 regal check engine light on
  131. program keyless entry 1991 98
  132. Overheated EGR valve melts stuff!
  133. motor transplant
  134. Stopping dead
  135. '94 olds 98 stalling.
  136. auto-leveling
  137. Missing Engine
  138. constant warning tone in 98 olds might have to kill myself
  139. where is the flasher??
  140. wacky cold start idling
  141. gas in oil
  142. Remote programming for '90 Olds 98?
  143. 91 olds 98 regence elite for sale.
  144. 1984 307cid
  145. programing keyless entry
  146. Side Marker
  147. 1/4 mile time for 1970 olds ninety eight?
  148. 1994 Olds eightyeight shuts off when driving
  149. Whoo hoo!!!!
