View Full Version : Riviera
- 1995 Riviera - tools/parts needed to replace master cylinder & brake booster
- Driver power window stuck in DOWN position
- 97 Riviera Power Steering fluid and oil leaks
- 1995 Buick Riviera Supercharged need help installing torque axis engine mount and belts
- 1995 Buick Riviera Supercharged - No power to under hood light
- Rive photo archive
- Belt tensioner
- 1995 Buick riviera motor mount discontinued
- series I 3800/Engine rebuild question
- 1995 buck riviera please help!
- 97 Riv seatback trim detached
- Troubleshooting my dash cluster in my 91 Riviera
- Horn usually doesn't work
- PCV kit - easy question
- 97 Riviera - replace Driver Air Mix Actuator
- HELP!!! 92' won't start.Acting stange.
- Climate control - Air flow and temp flaky
- 92 Riviera Transmission Problem
- 97 Riviera - carpet got damp in trunk?
- Rebuilding 97 Riviera
- Typical radiator life
- Slight RPM hunting after a warm start
- Seat back lock removal how to
- 97 seat internal frame PARTS NEEDED
- 97 Riviera - driver door window rattles
- Drivers seat back slips back under light preasure
- 90 Riviera-no air from dash vents
- More engine harness repairs - need tips and hints
- Mushy brakes 97 riv sc
- Windshield area paint restore
- Rear brake replacement (and later front)
- Front strut replacement - 97 Riv
- Grease fittings on the Buick
- 97 Riv - paint brake lines
- Bench test of airshock pump
- General lower front-to-back inspection
- 97 Riv - front wheel well (rocker panels)
- help identifying this part
- 87 Riviera.....Scanner questions
- 95 buick riviera hard to start hard to keep running
- 1985 Riv w/307
- 97 Riv - rust in rear wheel wells
- Damaged Injector/Vacuum Wires
- 97 Riv - spark plugs and wires
- Riviera aft side-window trim
- Grill and side-lamp clips (Riviera)
- Ants crawling on car body
- Engine module firmware update
- Coolant flush procedure
- Dj
- 96 Riv. Burning coolent
- 1985 Riviera Dash Lights
- 1996 Riviera idle and heat Problems
- Damaged tilt wheel mechanism
- 97 Riv - Belt tensioner pulley noisy
- Air bag conversion?
- 97 Riviera rear air-shock system
- 95 Riviera engine noise
- Factory SHop Manual FS
- 97 Riv, Service Engine Soon lamp
- 95 Riviera motor vibration
- Is the riviera coming back?
- 95 Riviera, dropped a used engine in it.....
- High pressure AC line leak
- 97 riviera blower motor won,t come on
- 97 riviera heater/air cond. blower motor quit?
- Junk yard engine or a rebuild?
- Miss fire at 2500 RPM
- Heat shield wanted
- 97 Riv - play in drive train
- Water in passenger rear floor area
- 1990 Buick Riviera A/C
- Grease fittings on 97 Riviera
- Aftermarket exhaust on the Riv
- Headlight adjustment for 1997 Riv
- 97 Riviera - enabling cornering lamps
- 97 Riviera trans-axle bucking
- 95 riv sc
- 1971 buick riviera
- 97' rear shock- Can replace w/ gas type?
- 97' sun roof problem, how to get fixed
- 92 Riviera: Plugs not firing, when I do get started it dies within minutes.
- 95 Riviera SC, AC compressor question.
- My Little Duece Coupe!
- 95 Riviera bottom side engine knock
- '97 Riviera, Heated seat and air ride...
- 95 rivi s/c no power all of a sudden
- New General Altimax HP tires
- '85 Riv with wiring issues...among other things
- 97 riv missing bolts for lower bracket mounting to block
- 92 riviera
- 98 Riviera, headlights won't come on
- "CAR IS LEVELING" light stays on
- 95 riviera radio goes "Pop"
- Riviera 95 heating issues
- couple more questions 97 riviera
- couple questions on my 97 riviera
- Super Charger Question
- buick riviera 96
- 95 riviera
- 4T60E Noise downshifting into 3rd.
- 89 CRT Replacement
- Superschargers, Lets talk...
- 95 wiil not start
- Re: 97 Riviera not starting - security light stays on! <Redux>
- Factory bumper fillers for '84 Riviera
- 96 Riviera Supercharger Noise /no power
- 98 Riviera has intermittent miss
- 91 Riviera problems??????
- Re: ALTERNATOR VOLTAGE
- 92 buick riviera almost got it but need a bit help
- Winshield wipers quit working...
- 95 Riviera non supercharged questions on codes
- 95 riviera overheating
- 95 riviera heater core trouble
- 95 riv recent purchase
- 98 Riviera with radio/steering wheel control issues
- 95 Riviera with some problems.
- 95 riviera oil light
- 1995 Buick Riviera Spark Plug Change
- 95 riviera no injector pulse
- 1984 Riviera Shifting Problem
- 89 Riviera leaking gas when running
- 86-87 ecm check codes
- 95 Riv engine noise
- 97 Riviera 3.8L s.c. fuel pump
- 95 Riv Rear Shock Info
- Gauges, Odometer, Climate Control No Longer Working
- leaking water pump 95 super charged
- Hard Starting 97 Riveria
- 95 riv digital gear display
- 95 sc riviera replacing half shafts
- Car wont start
- 96' taillight instrument lights
- 1987 Buick Riviera T-Type
- 95 rivi brake system
- Windshield Fluid not spraying anymore
- 95 Riv Strut Question
- Car is running rich, can't figure out why...
- 92 Riv tranny problem
- antenna issue
- Revive This Brand
- 95 riviera Crossed polarities for battery >_<
- 95 rivi ac/heat problem and weird noise
- No tail lights or instruments light
- '98 seat/mirror module
- 1995 Buick Riviera Supercharger oil change
- interior lights, 1990
- Re: 95 riviera..overheating 11
- 1995 riviera engine question
- 1990 Opera lights
- Radio replacement
- Turns over but wont start???
- Car wouldnt accelerate and now wont start?
- how do you check codes...95 Riv SC
- HELP! A/C compressor pulley seperated!
- doors won't open on 1997 riviera
- Need Some Direction.... Stumped
- AC Compressor smoking!
- Camshaft sensor loacation
- Stalling Car at low idle and shaking at braking
- 1989 Riviera-Water Pump shot?
- 90 not starting
- 97 Buick Riviera non-SC Multiple Problems
- 1996 Common Problems?
- 95 riv starting prob
- e85
- 91 buick riviera struts
- Annoying chime with Traction Control!
- 98 Riv power window switch problem
- Strange intermittent vibration/chatter/noise behind dash in '95 SC Riv
- 1996 riviera temperature control module and stereo wiring
- rev limit
- 95 up Engine and tranny mounts
- no overdrive
- 95 Riviera not shifting
- 95 riv runs bad
- coilpack firing order
- 91 riviera bleeding brakes
- 98 Riviera Climate control problem
- Panel/courtesy lights (front doors) 1997 Riviera
- Tranny Problem
- steering colum 1996 Riviera
- Turn Signal glass Riviera 92
- what's the biggest engine
- 1995 Riv front end problem - new member
- 1989 Riviera Radio Woes
- 1991 Riviera FSM
- 95 riviera..overheating
- '99 Rivera Wiper Problem
- 95 Riv
- 92 riviera NO POWER
- '89 Riviera. Rough Idle, Horrible throttle response
- Horn and remote panic button problem
- power steering help needed
- UnKnown Clicking Noise
- 98 Riviera misses on hwy
- 1995 Riviera non s/c wire harness MAP sensor?
- Rivieria Window switch kerplunk
- My 95 Riv
- Help! Heated Seat Stays On
- Right front wheel bearing
- soft brake pedal
- 97 riv sc "chuggles" on right turns and....
- 81 Riv Electrical Short problem
- 1989 Riviera engine dress-up kit?
- 95 riviera keyless remote instructions
- 90 riviera code 42
- Hissing Air Conditioner
- Need To Fix, Leaking Brake Fluid
- '95 riviera s/c P0361 code HELP!
- trans wont shift
- Mass air flow , how to trouble shoot brake booster vacum leak
- Turn signal controller? module?
- Steering Column related to stalling?
- 95 Riviera windshielder washer pump
- PimP in distress....
- Parasitic draw- Body and Cps Fuse's
- Leaking Coolant
- 97 Riv rev limiter activating when accelerating in gear at lower RPM`s
- '95 Riv tranny Problem
- 97 riv stereo and cd scan randomly
- 95 riv no sig to injectors
- 98 Riv, Exterior temp wrong
- Just looking for some advice....
- hot engine-No Heat?
- HELP!!! 95 s/c starts if i prime.
- 97 riv outside temp
- 97 riv lighting issue
- 97 riv fuel gauge problem
- 95 riviera S/C "rocks" sound doing idle in park sometimes and always in D
- digital gas guage
- 95 Riv Engine swap Question
- No Heat IN MICHIGAN!!!
- 97 Riv climate control not lit up
- 82 riviera wiring issue
- headers?????
- passanger's side tail lights
- 95 Riviera Air Shock Pump Runs often
- Ultimate IQ test, please help
- 95 rivera sc has check engine
- 95 Riv. Battery Vent Tubes broken
- '98 Riv startup noise???
- '85 Riviera stall out
- '98 Riv S/C question???
- 95 riviera a/c / heater doesnt blow any air
- 96 Riviera, supercharge, start problem
- Amplifier/Subwoofer installation
- leaking near front right tire, not winshield fluid
- Wheel bearing
