View Full Version : Lumina
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
  1. 2000 engine fit in a 2001 lumina 3.1
  2. 1995 lumina brake system
  3. Need Help: Whistling in Engine
  4. 96 Lumina 3.1 Thermostat Pipe
  5. pCM
  6. Wanted: Source for Fuel Filler Tube
  7. Turn signal smokes
  8. Cig lighter Power on always
  9. Battery dies 91 Lumina
  10. 98 Lumina Change oil soon light
  11. 92 Z34 died/no start
  12. 98 Brake Problem
  13. Wheel bearing/hub?
  14. security light
  15. a/c high side port
  16. 1990 lumina won't start w/new cps/ign mod
  17. Crankshaft Oil Seal (Shortcuts?)
  18. ball joint replacement
  19. 1998 base model. a/c question =-
  20. 1990 brakes
  21. Touchy Brakes at Startup
  22. bad strut symptom question=-
  23. 1995 Lumina ECM
  24. Where To Find Replacement Vacuum Hoses?
  25. A/C Compressor Replacement
  26. 96 Lumina cooling fans don't engage
  27. Couple of minor trim fixes
  28. Clear headlight housings
  29. Lumina Doesn't start sometimes
  30. tranny swap for 93 lumina
  31. 95 Lumina Tensioner pulley
  32. A/C Recharge
  33. Voltage Light
  34. water pump?
  35. engine swapping
  36. Top rad. neck broke off and motor overheated
  37. Alright, I'm stumped on this one...help me guys!
  38. cooling fans
  39. 1998 Lumina AIRBAG light on after honking horn
  40. service engine light
  41. 94 lumina transmission interchanges.
  42. Overheating after doing LIM gasket change
  43. 1990 lumina3.1 Euro starts cold, runs ok until stop engine, then wont restart
  44. ac prob
  45. 1997 Lumina won't Start
  46. 98 lumina
  47. 96 Lumina brakes problem
  48. radical radiator issues back again to finish this enigma
  49. 1990 chevy lumina 3.1 3 speed hydramatic shifting problems
  50. P0440 and no air blowing through vents
  51. spark plugs
  52. How much would replacing/fixing leaking wheel cylinders cost?
  53. Window Regulator (Install)
  54. Intake Manifold leak detection...
  55. 98 Lumina LS w/ radio issues
  56. Loud Rattle Noise (Driver Side behind brake booster) Video Inside
  57. 97 Lumina Multifunction switch and TCC shudder
  58. Moddifications to 2008 6.0 Lumina SS
  59. Fuel filler neck
  60. New England
  61. Chilton manual
  62. Keyless entry 97 Lumina???
  63. Need help with p0452 & p0440 codes
  64. 96 lumina tranny fluid disappears
  65. Tinting Windows - Which % Film?
  66. Lumina 2001 LTZ v6 3.8 acting up :(
  67. Heat A/C control problem
  68. 90 Lumina 3.1 Starts/ruff idle/stalls
  69. Possible axle or suspension issue...i've seen this fish before...
  70. O2 Sensor and Trans codes...also some interesting behavior after an oil change.
  71. A/c
  72. overheating
  73. Window Regulator
  74. quick fixes and additives Your thoughts?
  75. interesting tranny question 3.1 96 lumina
  76. 1998 alignment question=-
  77. 1992 lumina brakes
  78. just paid to have intake gasket replaced and now runs worse!
  79. New Pump & Sending Unit but Gauge Still Fluctuates
  80. 1&4 cylinder no spark
  81. Help! - Coolant light stays on, car stalls at stops, and coolant leaking
  82. euro muffler
  83. Guys I really need your help!
  84. Replacing Turnsignal Switch
  85. question about electrical center under hood for 93 lumina
  86. 1997 lumina
  87. Oil Consumption situation
  88. Where did my crank sensor wire go?
  89. Correct Tire Pressure - 95 lumina 4d 3.1
  90. 93 lumina
  91. 1992 Lumina
  92. 1996 Lumina won't start...HELP!
  93. Replace Lower Control Arm Bushings - Difficult?
  94. replace a window
  95. Thread lock on head bolts?
  96. Automatic Tranny Solenoid
  97. stupid radios
  98. speedometer Odometer not working? 96 lumina
  99. Died while driving and no start
  100. 1996 3.1L intake manifold help
  101. Fixing up My Lumina
  102. 98 lumina won't crank
  103. 98 electric window question=--
  104. overheating and speedo not functioning
  105. Hard Start/Rough Idle
  106. anybody install trailer hitch
  107. Iam stupid?
  108. Can not shift gears anymore
  109. Cooling Water loose and burning smell...
  110. P00446
  111. No horn!!
  112. Clean Engine and under body...
  113. 1991 3.1 Lumina Weird runing issues
  114. Hazard Lights blink randomly
  115. 1998 Lumina not running good after tune up
  116. Dropped shaft in block
  117. 92 Lumina Won't Start ICM Voltage
  118. Removing tstat pipe
  119. 99 lumina
  120. 99 lumina electrical problem
  121. door lock module
  122. 95 Lumina 3.1 won`t start - no spark
  123. Seat Belt Alarm
  124. Turn Signal
  125. Fuse Diagram
  126. 92 lumina eletrical problems
  127. Replace the hazard warning switch knop
  128. Purge Evap Solenoid
  129. 96 lumina replaced fuel pump AND RELAY just wont start
  130. 91 Lumina newby problem
  131. spark plug wires
  132. 98 Lumina car
  133. Headgasket Seepage
  134. Hammerite
  135. help help help
  136. 99 lumina ltz staring issue
  137. 98 Lumina with electrical NIGHTMARE!!
  138. Question about turn signal red/orange
  139. 97 Lumina Redlines at start up
  140. 93 lumina problems
  141. 98 3.1L top end rebuild (pics)
  142. 92 lumina no spark when warm
  143. 1998 lumina ltz starting problems
  144. 1990 no start after driving
  145. 97 lumina no start condition
  146. Car wont start all the time
  147. Volts Light
  148. Where are these MAF, IAT, O2, Coolant Temp?
  149. Engine "sputters" only when starting.
  150. Please help. 2001 Lumina. Power steering went out. Fluid everywhere.
  151. replace tierods,not struts=
  152. No start
  153. 92 lumina Z34 the money pit lol
  154. How Involved is Redoing Valve Cover Gaskets
  155. trailer hitch
  156. 1996 Lumina Passkey Resistor Bypass
  157. security light
  158. 97' Lumina misfiring
  159. '94 Lumina Speedometer Swinging, Transmission Slipping
  160. when did chevy start production of the 1990 lumina
  161. 96' Lumi always has no heat!
  162. 96 chevy lumina front strut problem
  163. cat coverter
  164. Again engine problems? WTH???
  165. Low Coolant level Light 2000 Lumina
  166. Security Light on dash
  167. Replace Ball joint
  168. 94 lumina fuel pump problem
  169. 1990 lumina fuel pump
  170. 98 elec window question=
  171. fuel pump
  172. 97 Lumina 3.1 EGR Valve Testing
  173. update:still no go
  174. RTV sealer and Loctite on Intake Manifold Lumina 3.1
  175. 1990 lumina stalls when hot
  176. 95 Lumina - starting crinkle, rev when braking?
  177. 3.1 3800 engine
  178. 99 Lumina Don't Start When Cold!!
  179. 95 Lumina - radiator fans and A/C clutch
  180. 1990 radio install
  181. 98 Lumina Blown Head Gasket?
  182. Power trunk release
  183. 91 z34 need replacement under frame metal holding stablizers
  184. a/c clutch dosnt move
  185. Odd behavior '95 lumina
  186. Chevy Lumina 96 3.1-Stalls when idling
  187. Front emblem
  188. '95 Chevy Lumina Siphoning Problem
  189. 94 lumina starting problem
  190. 1993 lumina euro 3.1 starting prob.
  191. Urgent Please: Lumina SS -2007
  192. Rear strut swap
  193. 3.4l d.o.h.c
  194. rear exhaust manifold cracked again
  195. 1995 Lumina Brake Stop Lights don't work
  196. Dented oil pan....help, please. 93... 3.1...lumina
  197. 95 Lumina - Repetitive squeak
  198. Brake fluid leak
  199. 1995 Lumina - Need new Oxygen Sensor
  200. 1996 chevy lumina engine replacement
  201. how do i replace front struts on a 92 eurosport with 3.1l engine
  202. very poor acceleration
  203. Poor Gas Mileage
  204. misfire at 2000 rpm and above
  205. Broken manifold vacuum port 3.1 L
  206. 98 lumina dieing out after warmed up
  207. 96 lumina, blinker sound & lights flash??
  208. Throttle Bottle to Rear Valve Cover tube?
  209. Chiming when driving like doors are open
  210. correct keyless entry transmitter for 99 Lumina?
  211. 98 Lumina 3.8L Power steering reservoir replacement
  212. 97 Lumina No strat/rough start/loud noise/backfiring.....
  213. not sure what to do or how to get it checked out
  214. 96 lumina
  215. 2001 lumina bypass vats
  216. '97 Lumina (5) lifters problem
  217. 3.1L lifter position?
  218. 1991 Lumina Z-34 cruise control inoperative
  219. 95 Lumina Hesitation trouble- thought I had it fixed
  220. 4T60E Trans Trouble
  221. 97 Lumina 4T60E trans questions
  222. 1999 Limina Axle Nut
  223. Alternator Replacement, 95 Lumina, 3.1. ?
  224. P0422 Code. Any ideas?
  225. 1995 W-body, fuel pump?
  226. 1994 Lumina 3.1 intake backfire
  227. 94 Lumi Euro Dash/Door lights randomly on when car is off
  228. ABS computer box location
  229. 97 Lumina Trouble Starting
  230. 96 Lumina P0300 code
  231. 98 Lumina - A few problems...
  232. Wiring diagram
  233. No hot electrical power!!!
  234. ARGH! Coolant Pipe came loose!
  235. 1995 Lumina still wont shift!!!
  236. Lumina Misfiring After Intake Manifold Gasket Change
  237. wont turn over / passkey II
  238. ac condensate
  239. won't shift into overdrive
  240. How much A/C PAG oil?
  241. Shift Solenoid
  242. Low Coolant Blinking - 94 Lumi Euro
  243. Can 95 Lumina A/C Condenser be flushed?
  244. Where is the starter located on a 2001 chevy lumina?
  245. 1997 chevy lumina-More A/C Problems
  246. not sure if my raidiator fans are coming one how can i check.
  247. 95 lumina transmission removal
  248. Replacing master cylinder - 95 Lumnina w/ anti-lock brakes
  249. 1994 Blue Lumina Eurosport Paint Color??
  250. 97 lumina brake lights
