View Full Version : Lumina
- 98 lumina wiper turn signal pod
- egr valve on 93 euro 3.1
- 95 Lumina bucking at downshift point
- 92 z34 starting issues
- Left front noise, any ideas?
- Brake Pads
- 1990 lumina igintion???
- how to tighten drive belt on 98 Lumina
- 92 Lumina Sedan- drivers door won't open from outside
- help with timing issue
- 92Lumina PROBLEMS!!
- 1999 Lumina LTZ Guage package
- 95 Lumina still overheating????
- Changing my oil
- 95 Lumina suspension question
- CV joint
- lumina euro 3.4/1993 - antifreeze leak
- 91 lumina rear brake calipers problem
- 1994 Door Lock
- horn electrical short
- Need new struts, and some answers!
- flasher relay
- Fan temp?
- No power from ignition switch to starter
- Noisy Engine 3.1 Litre
- 99 LTZ brake light short?
- 1996 Lumina APV p0341 engine code
- 95 lumina - Replacing 3.1 engine
- Van won't start Please Help
- '98 lumina NewMember
- My van was not used for 3 days and now won't Start
- z34 1994 rear window
- 93 Lumina left turning noise
- 1991 Lumina 3.1 - Starting Problems
- How to remove the dashboard from a 96 Lumina
- 96 Lumina Gas Smell/Brake Lights
- 1994 APV charging system
- 97 problems
- back fires out of throttle body
- 1995 lumina trans
- 95 Lumina 3.1l heating problems (long)
- Lumina running rough at times
- 95 lumina 3.4 surges when cold
- Starter Failure?
- is this turbo too big?
- '95 APV plugs
- 92 Lumina auto transmission
- 90 lumina van won't start
- 93 lumina 3.1 liter problems
- 92 Lumina APV
- '92 Lumina Z34 5 Speed
- how to change 91 lumina 3.4 spark plugs
- 93 Lumina Brake question
- finally fixed 95 lum van
- turn signal drl and brake light trouble
- '90 2.5 litre, died and has no spark
- 1990 Lumina Won't Start
- 97 Lumina 3.1 thermostat repair
- 93 lumina 3.1 with 184,334
- 95 lumina stalls out.... alot
- help! heater cold when idleing, hot when driving
- 95 3.1 Lumina Won't Start Need help pulling code
- 95' Lumina
- My 94 z34 will start for only 3 seconds
- 90 Lumina Light Problem
- Owners manual
- rotten egg smell in 91 lumina
- 1997 Lumina Fuel Pump
- 1990 Lumin TCC solenoid replacement
- no heat.
- No Power with new battery
- Exhaust problem?
- 91 Lumina Van wont start
- pipe between water pump and stat housing .......
- How Do You Change The Back Plugwires LUMINA 1999
- Brake lights on all the time
- 93 chevy lumina
- Lumina (drum) brakes
- Monroe Sensa-Trac / KYB GR-2 / ACDELCO / ??? - Any opinions?
- 93 Chevy Lumina With Problems
- Fuel Pump Relay
- Monte Carlo Dash to Lumina
- Where to find parts?
- Won't Start
- 96 Lumina APV - no brake lights - turn signal switch?
- No Spark from new coil
- 93 Lumina APV- Various issues, please help!!
- Car Door will not shut!!!!
- Coolant Leak
- Trans shot? How hard to change?
- 91 lumina euro 3.1 dies making right turn?
- stalls lunges dies
- 1993 Lumina Z34 Crank Sensor
- coolant leak
- Vents Barely blow air even on High
- Rear Disc Brakes
- help 4 starting problems
- engine will not turn over
- 96 Lumina over heating not sure y!!!!
- Is my car insecure?
- Lumina 1993 has no "choke"
- timing chain marks
- Lumina z-34 lean fuel/egr code 44 and 32
- Lumin apv wire harness
- OBD Issues on a 97 Lumina
- Electrical Insanity...Heat related???
- 92 Lumina Euro Driver Door Panel Removal
- 97 Lumina Delayed Trans Engagment When Cold
- 94 Lumina backfires through throttle body
- Coolant leak
- Fuel Filter
- removing Quarter window
- Jump start from 1996 Chevy Lumina
- 94 Chevy Lumina APV keyless entry
- 3.1L V6 Coolant Capacity
- 94 Z34 engine swap
- 1995 Chevy Lumina Newly Rebuilt and won't stay running, THEFTLOCK problem?
- turn signal flasher 97 lumina
- 93 lumina 3.1-fuel filter location
- 93 Lunina Won't Start
- 91 lumina euro 3.1L Oil leak or Transmission?
- 5 speed for a 3.4 DOHC
- anyone have a police package lumina?
- 97 Lumina 3.1 (which engine heater to use?)
- No Start-total Mystery!!! Help!
- remote starter Brands
- Seat belt problem
- Replacing fuel filter???
- 94 Z34 Hesitation at High speeds
- 91 Lumina HELP
- Remote start+Door locks
- Engine missfire after changing plugs/wires
- Low Coolant Light Keeps Going On and Off
- Just died
- 97 lumina-no taillights and no dash lights
- rear brakes
- Heat/Cold selector
- Groan on accel
- do u use (d) or d? differences?
- Still will not start.
- Cold engine?
- 1997 Lumina dies while driving
- Door handles--90-94 Sedan FYI
- broken window
- 1997 Lumina LS Taillight on the trunk
- 91 Lumina - Tie Rod Bellows and Motor Mounts
- Average Life Expectancy
- Lumina Rim offset
- I need a transmission for my lumina 1995/what transmissions will fit?
- Intermittent buck and jerk
- Advice on high mileage maintenance
- 93 lumina euro problems stalling/poor acceleration
- 93 3.1 lumina bad knock!
- just purchased a 2004 suburban
- Power window problems--put up manually?
- coolant leak below the oil (filter) cooler
- 92 Lumina downshift problem THM440-T4
- Sludge on my radiator cap!
- P1381C code - Please help!!
- 99 Chevrolet Lumina multiple problems
- Fuel Sending Unit
- fuel consumption too high
- Oil Pan Gaskets
- bucking/surging
- 93 Lumina - Rear brakes not working
- Bad idol, when in gear 70 mph
- Head Gaskets
- 95 lumina
- HELP! Van won't start
- electical problem w/ fuse
- 2002 trialblazer, Better mpg?
- 93 chevy lumina fuel pump?
- 91 factory service manual
- transmission...shifting delay in higher speeds
- 95 3.1 hard starting finally died
- flooding ?
- Lumina full throttle problem
- how tough: engine swap - 91 3800 into a 92 Lumina
- Fan does not come on
- Security & Change Oil Soon
- dash lights
- 1998 Lumina code
- Won't start when cold
- coolant light
- Seatbelt Light while driving
- coolant sensor staying on
- many problems....
- 92 Lumina APV 3.1 TBI dead spot
- 95 Lumina APV 3.1 problems starting < 30°
- Couple of repair questions -advice needed
- Cheap performance mods?
- Um, something is hanging from the bottom of my car...eerrrrrr
- 95 lumina rear lights and signals
- '91 Lumina APV 3.1 Tourqe Converter lock
- High and Low RPM at idle
- Power steering fluid leaking
- dead, only sometimes
- Replacing the "big 3" wires on 97 lumina (3.1)
- `97 Lumina have heating issues...please help if you can!
- 96 Lumina 3.4L engine
- 2000 Lumina rotor removal..how to?
- who's bright goddamn idea was it to use TORX head caliper bolts?!
- Need directions for MAP sensor install
- Please help me fix my '98 Lumina 3.1 Need help!!
- 90' apv 3.1 engines stalls in gear while hot
- '98 Lumina trans. fulid fill?
- 3, 2, 1, No ignition!
- 2000 Lumina missfire
- TCC Shutter
- '93 sedan door locks
- Truck cuts out during acceleration
- DRL only works during daytime
- exchanging motors
- Lumina 4T60E trans trouble
- looking at 95 Lumina
- low voltage,then normal
- 97 lumina airbag light
- 99 Lumina LTZ Overheating/Losing Break pressure
- pulsating/flickering headlights, `01 Lumina
- 2002 s10 blazer limited slip rearend
- P0300 Code Please Help
- hm..?
- 2.5L Engine Swap
- 93LuminaHighIdleAfterWarmedUpStart
- 1999 Lumina rear struts
- Can anyone tell me the intake manifold torque specs. for a 1991 Z34?
- 90 Lumina that just won't run
- The Loserboy Riced Out Lumina's Thread
- Convert rear brakes to disk
- 96 lumina 3.1 same as 2000 3.1?
- Questions from new Lumina owner
- cam shaft sensor replacement
- EGR Insuf Flow
- Lunima APV 1993 3800 V6 -No spark
- 93 lumina euro won't start during jump
- 95 Lumina Driver Side Window Problem
- 95 Lumina, connecting AUX audio source, is it possible?
- 98 Lumina Braklights in-op
- 96 lumina noise
- Getting a gas gauge fixed?
- i hate fuel lines
- lumina mods
- Replacing Rotors
- 90 Lumina 2.5 to 3.1 engine swap? Anyone done it?
- Coolant Leaking (but from where?)
- 1996 Lumina keeps blowing Security 10amp fuse
- Acceptable "piston slap"?
- Torque Specs
- AC not working
- Loss of acceleration
