Chevrolet
> Lumina
View Full Version :
Lumina
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
HELP! 97 lumina L&R brake light gone first, then won't start totally
98 Lumina Code P0300
Rodent entry into HVAC?
Transmission Noise??????
Shuttering at acceleration
What Would YOU Do???
Paint?
z34 ground effects
1994 APV 3.1: Recommended Coolant & O2 Sensor Missing?
lumina for sale
instrument lights go off when outer lights are turned on!!
Part number help please
'95 Lumina APV problems/NEED HELP PLZ
Lumina DIS fuse blows
What did you paid for your Lumina
93 Lumina APV cruise and AC problem
non peeling?
PROBLEM 3.1 car RUNNING BAD!
Is A 1992 Lumina Z34 Worth fixing up?
97 Lumina - air conditioner
Compressor not working - where to start?
94 Z34 summer project
98 Lumina Air Conditioning
Body Kits
What Year Is Your Lumina???
clicking on start up
Going to look at a 92 APV tomorrow.
Shock Replacement
1998 lumina blower direction?
Now Im confused..97 Lumi 3.1 A/C probs...
How to replace AC evaporator
90 Lumina Warm Rough Idle
warning lights
1990 3.1 randomly runs/doesn't
93 Lumina Rear Disk Brakes
Coolant Leak?
Engine update
whine
1996 Lumina For Sale
mirror
fuel problems?
1990 Lumina -Engine NOT turning over
Transmission wont shift to 3 & 4 gear
92 Lumina 3.1L Radiator Leak / Replacement
Bucking\Hesitation
help me!
Looking for some help...
Lumina paint issue
96 Radio question
fuse for cig lighter
For Sale: 92 Lumina Z34 5-Speed
yet another strange problem
another strange occurance
weatherstrip
Help me fix up a good car.
98 Lumina LTZ?
92 Lumina power steering problem
'98 Lumina LS power door lock problem
brake light
92 3.1L problems
Confused
Phantom Horn Honker
Idling Problems
90 Lumina 3.1 has no power starting off.
what was I thinking?
95 lumina 3.1 electrical problems
Please help me out.
help, smoke!
Wiper delay mod?
2001 Lumina Body Creak
Lumina A/C Problems
Stumped on something!!!
3.1 :Fix or Replace?
New A/C PAG
Acceleration problem -97 Lumina - Please Help
Threads
93 lumina 3.1
lumina troubles with acceleration
98 Lumina Recharging Aircondition with freon
faulty throttle position sensor?
Do front calipers on 93' Euro have 2 copper compression washers on brake line?
Correct idling speed?
98 Lumina EGR
ANYBODY PLEASE!?!? 1995-2001 Ashtray
coolant flush?!
lumina euro key dinger
interchangeable years
91 Lumina engine swap?
#1 Cooling Fans Not Working!!
CD Player
Rocker arms
Hanging on for Z-34
93 Lumina Voltage Light?
97 3.1 Crankcase breather tube part#
Testing the cooling fans
When I start up it does no stay on
Transmission problems-96 Lumina
No Spark 3800 apv helpppppppppppp!
Junkyard Parts
91 Chevy Lumina, a couple of problems!!
95 lumina duel exhaust
Cannot start 1999 Lumina
92 3.1 cooling problems
1990 lumina idle to low
Factory Fog/Driving Lights 1999 LTZ
New Thermostat in 97...
A Body Kit for Lumina what hink you about this...
1997 Lumi Fuel Pump.... Figures
Is it my head gasket?
Looking to buy 1997 3.1 Motor Mount & Throttle Body Cable
97 Lumina......New Color....wat color should i paint it
2000 Lunima - need to change battery
Replacing Spark Plugs 92 Lumina Z34
how to back probe cam sensor to ensure it is working?
Lumina 3.1 l camshaft sensor test
1995 Black Limina FOR SALE **PICS**
Vent turning on after car shut off
97 Lumina ABS light
Lumina cooling and air conditioning
1995 lumina bucks
1995 lumina car 3.1 bucks in overdrive
Sell for parts
HVAC - Vaccuum Leak
Compression
95 Lumina Sedan - 3.1 - Power door lock
95 Lumina sedan - 3.1 - Power window problems
my 95 apv lumina 3.1l misfired around 40mph and shut off around 50mph
Changing Thermostat in 1997 Lumina 3.1?
1998 Lumina LTZ Again
z34 wiring
Towing question
just when you think it couldn't have any more problems..
93 Lumina Needs New Engine
1997 Lumi 3.1 A/C probs....
97 Lumina oil leak
Please help me out! No bleed screws
Air conditioner problem
It's hard to push!
O2 code
'95 Lumina A/C Compressor problems
1991 lumina trouble starting / makes horrible noise!need help!
APV 3.1 Bleed cooling system
94 APV 3.1l No hazard or brake lights
JeffCoSlacker...
1997 Lumina Overheating Problem?
91 Lumina !KEY PROBLEM!
90 Lumina Gas Pedal Sticks
Error Codes who can help...
98 Lumina LTZ 3.8 water in oil
Does $3500.00 Sound Good?
'92 Euro ignition problem?
Electrical or computer problem?
99 lumina p0440 code .Help please
Question about monte rims on 1996 Lumina.
96 Lumina with 20k miles
Rack and pinion is clonking. Help!
speed reading innacurate
Where is my anti-freeze going?
Thought I broke it...
96 lumina stumbles on acceleration
Turn signals
94 Lumina APV Window Problems
93 Lumina won't stay running
trans swap help PLEASE
Did I get hosed by the dealer?
95 Lumina lagging on acceleration
New motor – No start
light reads = change oil soon
Tire Size
Anyone have any experience with KYB struts for a 93' Euro?
LOW or HIGH impedance injectors?
2001 Lumina Upgrades
94 Lumina code 32
Lumina 1998 Relay where i can find it???
93 Lumina
How much for...
98,alternator question =
'92 Lumina blowing ECM fuses
92 lumina 3.1 v6 won't start
97 Police Lumina
fuel inj. lines & pwr. steering
93 lumina Z34 not running right after running low on gas
Weird problem
97 lumina pcv valve
90 Lumina APV Stalls
waterpump.. what is this tube on it called?
PCV valve location
Lumina 95-01 Ash Tray? Looking 2 Buy
I'm having tempermental starting issues
93 lumina 3.1 euro specs
HELP with Codes
Anybody found the trunk leak fix yet ?
SES on, runs BETTER?
Thanx ALL...wow what a P.I.T.A 97 lumi.. ball joint
Brown chunky coolant !?!
91 Lumina wont' give accurate speed reading
A new stall to my "92 lumina
93 trans and motor switch?
trunk....
APV needs reset to start...
Replacing the A/C Compressor in 97 Lumina
'94 AM/FM Cass issue
97 Lumina Water Pump Replacement
z34 tranny issues
no pressure in radiator hose
95 lumina ls van window
1998 Lumina LTZ
1998 Lumina LTZ
Cigarette lighter not working-92 Lumina
93 euro stalling
97 lumi 3.1 DUMB QUESTION....Real Dumb...
Can't find the bloody battery
question about a 91 2.5
Charging problems w/ 91 Lumina 3.1L...long
91 Lumina engine and trans swap?
overheating? wont start
96 lumina transmisssion / engine light on
92 lumina euro smoking
92 lumina 3.1 problems
My Latest problem on the wifes 95 Lumina
steering problems
Ok Here Goes...97 Lumi...3.1...For cryin out loud!!!
lumina not firing
Leaking under 92 Lumina
Oil pan/transmission pan gasket leaks-92 Lumina
Where is the pcv valve on 3.1 Lumina?
Window Crank / how to remove?
Where is the ECM? 93' Lumina Sedan
types of engine
timing problems lumina z34
looking for chepest way to get more hourse and torque for my 92 z34 5-speed
92 z34 3.4
90 Lumina 3.1 no spark...
z34 5 speed
93 3.8 lumina apv no spark,cranks ok
93 lumina stering?
How do you replace the climate control bulbs?
1990 3.1 euro lumina oil pan help
1990 stalled got fuel pressure up to the rail
93 lumina does not start?
Anyone know if a 2001 lumina and 99 can interchange parts?
Where in the suspension is the front strut bearing 1993 lumina Euro?
93 lumina ignition module???
Another 91 Lumina that wont start warm
99 LTZ 3.8 tranny question...
New engine rebuild 3.1 '97 car install Runs Rich /Rough
96 lumina 3.1 help
93 Lumina please help
