View Full Version : Corsica
- Trying to get codes
- 94 Corsica, high rpm shift
- How to remove my rear dash panel on a 96 corsica 3.1L?
- 96 Corsica Thermostat replacement. How to?
- 89 Chevy Corsica Trouble Help
- Corsica 95 2.2
- rough idle, poor mpg, running rich.
- 1996 Corsica hard first start then fine.
- GM 3.1 pushrod order layout
- 1993 Corsica 2.2 Fuel line feed
- 3.1L Very Poor Gas Milage Now
- 1996 Corsica ABS Light
- Rough Idle, Acceleration miss
- 95 Corsica Transmission?
- Luke warm heat 1996 Corsica 3.1L
- 91 corsica 2.2l fuel pouring into throttle body
- Resolving Corsica/Beretta interior water leaks
- 95 corsica... key switch/steering column/starting problem
- coolant leak
- '92 Corsica: How to revive my dead cooling fan?
- '92 Corsica 3.1 warning chime and speedometer drop after turning off
- 89 corsica will not start when hot
- 1995 Corsica V6 3100 issue(s)
- 89 corsica manifold temp
- 90 Corsica 3.1 starts but stalls right away
- problems pushrod valve
- need fix car
- 1995 corsica charging issues
- 1995 4cyl fuel injector replacement
- 1996 corsica no oil to the top
- 1994 corsica
- R/F brake not releasing/over heating and smoke
- '96 Corsica- Can't remove brake drums?
- Misfire on three
- Wheel Cylinder
- 1990 corsica fuel problems
- my first car!
- I broke my corsica : (
- Belt tensioner 1996 Corsica V6
- Wheels/Tires and Front End
- 90 corsica radiator fan not working
- Loud air conditioning
- high idle and transmission won't shift
- Low speed surging linked to tranny leak?
- Car bogs down when punched.
- 1994 Corsica 3.1 Thermostat replacement
- 1996 V6 power steering pump pulley
- This is becoming a frustrating issue very quickly
- What a long strange trip it's been......
- Possible over heating
- A new issue with the 91' Corsica
- 1993 6 cyl Corsica Over heating
- 1996 Corsica 2.2L Oil Light Comes On at Idle
- valve sticking
- Still have an Idle problem....
- Rough Idle - Running Rich.....
- Fuel pump issue...
- 1994 Corsica Won't Start
- Leaks in rain
- Lock cylinder
- Corsica 3.1 for sale
- A little help with a/c troulbe shooting
- 96 Random Start
- transmission slips
- Flooding while cold
- 1988, brake lights dont work, just the cyclops
- Car has a miss, can anyone help me figure out the reason?
- 91 Corsica, no heat. BRRRRR
- Electrical Problems......
- Low coolant light - Coolant Bleeder Screw?
- This Charge Sound Right For This Repair??
- Heater controls/vaccum locations
- 1988 Corsica starter problem
- 2 issues with my 90 corsica?
- How to Read SES Light on 93 corsica 3.1
- 1994 Chevy Corsica: Won't Start
- 1996 Corsica Won't Start After Sitting 3 Months
- corsica really???
- 1996 Corsica 2.2 No spark, or computer codes
- 1996 Corsica bogs down
- 95 Corsica Knocks Bad When In Park Or Reverse
- What's the name of (Cooling Sys)...?
- 94 Corsica 2.2L MAT too LOW
- Coolant overheating
- 94 Corsica 2.2 auto 3 speed shifting problem
- odd thing happened
- Girlfriend's Corsica stalls after long drive.
- geez. oil pressure absent
- Optional Instrument Cluster
- Power Windows Elec Prob. Please help!!
- Is the head gasket bad? or WHAT?
- 94 3.1 v6 cooling fan
- 91 3.1 rough idle then dies
- No Heat Constant Flux of Temp Gauge
- 91 corsica exhaust
- 96 Engine issues
- brakes!
- Corsica CPS Question
- 90 3.1L rough idle
- Has anyone resolved their surging issue?
- intake for 3.1l
- 95 corsica 2.2 Automatic, engine movment and large popping
- 93 3.1 stalling out at low rpms while driving?
- 91 corsica 3.1 fuel pump not pumping
- `94 Headlights not working...everything else does! help!
- low coolant light on but resevoir is full
- 92 3.1 Whine sound?
- 95' 2.2 puzzle???
- fuel pump changed on 92 3.1
- 1996 3.1 V6 Coolant Issues
- I'm removing my head gaskets
- 1995 corsica
- 1995 corsica
- Couple of questions...
- 94 corsica wont start. CLUELESS!!!!!!!!!!
- Shifter cable
- '94 Corsica Radiator fan
- Bad Motor Mounts? 93 3.1L Corsica
- no power
- Car wont start
- fuel filter
- swimming pool in foot well
- 94 corsica cannot bleed brakes
- 96 corsica lost power
- 96 Corsica 2.2 cold start fuel problem HELP!!
- 95 corsica cold start problem
- 92 corsica no very little vent heat
- speakers used
- 94 corsica cooling problems
- 1990 corsica
- 95 adjust screw on carb???
- 1994 corsica
- 1993 Corsica No Heat But Air is Blowing
- 91 corsica problem
- 94 corsica,low gas mileage
- 92 3.1 mpi misses
- 1994 Corsica heater Problem
- 91 corsica 2.2 4 cylinder wont start hot
- Service Engine Soon light on...no code
- 1989 Corsica making noise from wheel area while turning
- 1988 Corsica wont run when hot
- One power window doesn't work
- 92 Corsica Fan and Wiring
- 93 corsica
- 96 corsica acceleration hesitation
- 95 corsica won't start
- 89 corsica not starting replaced solenoid
- 1991 Corsica Right Turn Signal Problem
- 1996 Corsica error po441
- test
- Corsica 96 3.0 ABS Problem
- Car stopped shifting while driving! PLEASE HELP
- MPG"S 1996 v6
- 96 Corsica Electrical Issues
- Transmission Problems Coming?
- 1990 Corsica stalling - How to disconnect TCC solenoid?
- 95 fuel door hinge????
- Somebody please help me ! 92 corsica injector problem !
- Performance parts?
- wheels help
- presure test on coolant system
- I need help with no spark in 88 Corsica
- 92 dash lights
- 96 corsica from 3.1 to 2.2
- 94 4 cylinder Corisca won't start
- 95 corsica shaking hard at start up then dies.
- 89 Corsica ignition lock removal
- 93 corsica tcc disconnect location???
- 1992 corsica 3.1 has miss when throttling.
- Surging at Idle
- spastic water temp?
- 93 corsica 2.2 stumbles
- 93 corsica wont start
- hood latch is broken , please help
- Code 44 & 45 at same time
- Dave
- 1995 CD install
- Help Crankshaft Sensor Stuck
- raced out corsicas?
- 3.1 or 2.8L fuel regulator needed
- 1996 Chevrolet Corsica Engine rebuild Question
- try to start 91 2.2, stutters but no start
- brakes wont let go
- 1996 Corsica Fuel Pump Replacement
- High Idle issue
- 92 corsica engine stumbles on acceleration
- 91 Corsica key stuck in on position
- 94 headliner coming apart
- shaking 96' corsica
- 88 corsica...code 44..need rear doors
- Anyone who have an answer for a viking..??
- 91 Corsica coolant leaking
- Overheating
- 92 Corsica Radio Wiring Connector
- 93 Corsica Key Switch
- '92 Won't Crank
- High Idle 90 Corisca 2.2
- 96 corsica electrical issues
- what should i do about a blown head gasket?
- Tire sizes?
- Gas in Oil, No acceleration, Poor idle
- 91 corsica - key won't crank
- 91 Chevrolet Corsica
- Alternator?
- Coolent leak
- Dash, temp and gas gadge.
- 96 corsica 2.2 died
- 1996 3.1 surging issue
- How do I replace fuel pump, 93 corsica 3.1L
- need advice re starter/solenoid
- fuel injectors, 96 corsica
- changing the coil/module 96
- 94 Corsica Overheating and Spitting Water at High Speeds
- '95 battery drain problems
- Hard to start when hot
- Air has stopped blowing from vents
- 93 corsica fuse
- 88 Corsica #2 no spark
- Help with 93 corsica please?
- 96 corsica won't start when hot
- 1994 corcisa
- 93 Corsica Oil Pressure spiking
- Stuttering when barely hitting gas
- help me fix my headlight switch
- 96' corsica brake problem help!!!
- 94 Corsica - clueless
- 93 Corsica power issues
- Clunking sound coming from under trunk?
- Need Some Help
- 90 corsica oil pressure gauge pegged
- abs not working
- brake goes to floor after replace master cyl
- A/C pump clutch not engaging
- specialk98
- 90 corsica 3.1 no fuel pressure
- 96 Corsica p1780 code?? HELP!
- 2.2 Shifting Problems
- locate plug to disengage tcc in 91 corsica
- 88 corsica stalls only when first started up
- corsica stalling
- new corsica
- 91 corsica
- Black power steering fluid?
- Will not accelerate
- Key lock cylinder
- No Get Up And Go...96 Corsica
- 92 chev corsica 6 cyl 3.1 plug wires 1 & 4
- corsica-1993
