View Full Version : Breeze
- No bus, no power to fuel pump
- Having a little trouble finding part, help!?!?
- 1999 Breeze replaced starter & No start
- 97 Breeze losing power above 40 mph
- Car computer
- smell antifreeze is leaking & little smoke on right side
- Won't stay running
- Thermostat problem
- 1999 Breeze fuel filter problem
- using oil
- battery being drained
- Power steering bad
- Identify this part please
- turn signal trouble
- 1998 Plymouth Breeze
- 98 breeze help!!
- 96 Breeze No Spark
- car won't start
- The strangest problem with my 97 breeze.
- 1996 Plymouth Breeze refuses to start
- 99 breeze a/c pressure switch
- 97 plymouth breeze few problems need help
- Front hub assembly wheel bearing problems
- 98 breeze engine
- Where is crankshaft position sensor on 98 Plymouth Breeze
- 97 Breeze won't start
- 99 breeze 2.4
- 99 Breeze 2.4 LDP
- Summer Breeze
- 98 Plymouth Breeze Smoking
- Random compression after lifter replacement
- Repalced bad crank sensor twice in two days - Going for number 3!
- 98 breeze still chugging along
- stuck key
- stuck key
- 96 breeze stalls out at stop light
- Heat won't work when car moves
- Four cylinder Engine ?
- 98 breeze trans not shifting
- 98 Breeze - not cranking, not starting
- Rear Drum Brake
- 99 breeze engine wiring harness, no spark
- '98 Breeze codes?
- 98 Breeze drivers side lower control arm removal
- 99 breeze a/c and blower
- Illumination Fuse Keeps Blowing 1998 Breeze
- Won't start after rain
- 98 breeze rear brakes don't release
- Cleaning an EGR valve on 99 Breeze
- CLUTCH RELEASE CABLE 1997 breeze
- Oil pressure switch
- 1999 Breeze Blower Problems
- 98 Breeze Weird Noise/Oil
- 97 Breeze oil seals.
- Car shut off and won't start
- v6 upgrade
- P1776 Code need ideas
- Proportioning valve
- electrical problems
- front motor mount removal 97 2.0 liter
- Parking Brake?
- Steering wheel vibration at idle ?
- 96 Breeze 2.0L hard start
- 2.0 to 2.4 head swap
- Electrical problems
- 98 breeze alarm
- Dragging front brakes, evan after replacing hoses,calibers, rotors and pads????
- 99 Breeze Stalls
- Gas Guzzler Blues
- 2.4L Breeze Rough Idle/Stalling
- 98 Breeze won't start (2.4L)
- Breaks Not Working
- 1998 Breeze Door Panel
- Crankshaft pulley removal?
- Blown 2.4 engine in 98 Breeze
- tach/odometer?
- 98 Breeze Trans Fluid
- 98 breeze wont start
- 97 , pcm asd fuse no start
- Catalytic converter install help
- Did mechanic tell me right about power steering issue?
- Engine Just Died 96 breeze
- 99 breeze front wheel bearings
- head gasket problems anyone
- Help Film on the inside of the lights
- Coolant Problem
- My ABS Light is on
- throttle body
- so it's not the fastest thing on wheels
- Help Me to Indentifying A Part
- Have a '98 w/2.4L; is it a timing belt or chain?
- need tie rod help on breeze
- Alternator Belt Broken Hlp!!!
- Spark question???
- small oil problem
- 99 Ply Breeze
- front door speaker cover panel
- neon tranny on breeze
- Location of Fuel Filter 2000 Plymouth
- Is there a good breeze forum?
- Climate Control issues
- 1998 engine rattle and knock
- ASD fuse blowing
- Not Starting
- 2000 breeze brake lights won't work
- For Sale. 99 Breeze Speedometer, 38k mileage
- P0700
- can mods from a neon fitthe breeze motor easily ?
- stargard alarm 00 Breeze
- HELP! Car dies!
- 97 Plymouth Breeze worth $1500?
- new owner
- Plymouth Breeze '98 Electrical Accessories Problem
- 97 breeze oil leak
- stripped plug
- brake bleeding
- brake bleeding
- need massive help
- Check Engine Light Came On After OBD Testing
- 98 Breeze ac blower
- headers
- 1997 Breeze Temperature Sensor
- Help: Heat stopped working
- Plymouth Breeze Heater
- input speed sensor!!!
- Help with Breeze, won't start!
- 99 plymouth breeze transmission
- 2.4L timing belt tensioner info
- steering column switch
- 96 2.0 sohc broken timing belt question
- Horn Relay
- clicking
- Ran fine--Won't start!
- Emission woes
- Need advice please
- check engine light
- Plymouth Breeze
- stalling out backing out and when foot is off the gas pedel.
- Low Egr Flow
- 99 breeze jars real hard on upshifts sometimes
- Free Modifications
- 98 2.4L Coolant Boiling Over
- 1998 plymouth breeze tach is messed up?
- 99 Breeze - Engine Died, won't start again.
- engine swap options
- wont start
- 99 Breeze Emblem/Logos removal
- Engine power loss
- 98 Plymouth Breeze Front Speaker Conversion
- locating the ecu
- breeze steering noise
- Coolant Replacement
- AC Question?
- 96 Breeze runs cold, dies, restarts when cold
- Breeze is cutting out
- 97 Breeze not getting gas..map sensor?
- 96 Breeze wont start?
- Brake Pedal Won't Push
- 1999 Plymouth Breeze 2.4 DOHC
- ignition trouble
- air/heat only blow on highest setting
- Equipment Install
- Cold Air Intake?
- Breeze is dead
- I am a woman driver "97 Breeze Problems..Help!
- rear window not working
- Dome light won't go on/Fuse box
- Gurgling Noise/check engine light
- Help!
- emissions
- What are some good Bulbs??? 99 Breeze
- breeze tranny and other questions.
- parting out a 97 breeze
- Problems
- 97 Plymouth Breeze Problems
- how many digits on the odometer....
- replace headlight on ply breeze 97
- noise- engine
- No Bus - along with a few other probs...
- Instrument cluster suddenly stops working
- Brake Auto assist automatically coming on
- srange engine noise
- No "PRD321" indicator or "door ajar" on gauges
- Front Bumper replacement?
- rpm surging at idle
- Rear brake problem
- Rattle in front
- front end problems
- performance mods needed
- tranny help
- Digital Odometer- HELP!!!
- how do i install new speakers
- The blower resistor block
- A/C Question
- cylinder missfire
- Autostarter
- 99 Breeze Fuel Gauge
- Door locks
- Back lights not working
- engine
- Performance
- Worst Car EVER...
- Oh Yeah? Well Check This Out
- Oil light on when Idling help!
- turns hard on cold engine
- 1997 2.0 liter motor
- Motor Swap Srt 4 motor in a plymouth breeze
- car won"t start
- problems
- no bus
- gurgling at shutdown
- 97 breeze steering wheel vibration @ idle
- I need a drivers side front hub...
- Runs but cuts off and gets to 40 45mph, but won't go any faster?
- I need a Breeze, Strat, or Cirrus Genius! PLEASE LOOK!
- Back Seat Removal
- radio wiring colors
- 1996 Plymouth Breeze P1768
- Help
- Neon lights for my Breeze
- Breeze Bad Story
- Looking to buy car
- new owner
- parting out 1995 dodge stratus
- Wheel Bearing
- where do you get oem parts
- Somebody please help
- Car goes by itself
- accerating on its own
- performance mods/other info
- Moonroof not lining up
- Alternator?? Battery??
- no breeze love?
