Plymouth Breeze '98 Electrical Accessories Problem
xyphon
05-15-2007, 04:32 PM
Hi everyone, I have a 98 Plymouth Breeze and have a little problem with the electrical accessories. I recently changed a fuse because it was blown up and nothing worked (indoor lights, radio, etc) when the car wasn't started. Now that I changed it, everything works even when the car is stopped and there's no key on the contact. By that I mean that the wipers, the radio, the fans are still working when the car is not running.
Anyone has an idea for that?
Thanks
Thanks
jdl
05-16-2007, 08:20 AM
Sounds like a problem with the ignition switch. The wipers and radio circuit goes hot with the key in the on or acc position. You might try positioning the key, a little, one way or the other, when you kill it, see if the radio goes off.
