small oil problem
jmoerau16
10-02-2007, 10:45 AM
the oil gets past my spark plugs and gets on the end of my ignition wires..what could be the problem?? if anyone knows please explain thanks.
vando002
10-13-2007, 09:26 AM
I don't think the oil is getting past the spark plugs, otherwise there would be no spark. I think the oil is leaking into the tube from the top. Mine is doing the same thing and I'm not sure how to fix it either.
reino134
12-23-2007, 10:57 PM
The spark plug tubes have seals that go bad on them and leak into the tube, soaking the plugs and wire ends. I do not know if you can buy them seperate or not I got replacements with a valve cover gasket. Very simple and inexpensive fix..
98_plymouth_breeze
10-29-2008, 10:39 PM
they come with valve cover gasket cause u need to remove the cover to replace them 20 dollars gets the set
