View Full Version : SC/SL/SW
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14
  1. Transmission Shifting
  2. Maintenence questions on a 1998 SL1
  3. Alternator
  4. 1994 saturn sl2 cutting out on takeoff
  5. '94 dying when clutching
  6. upper motor mount
  7. 1999 Saturn SL2 Rear Door Panel removal-frozen torque screws
  8. Reprogram Remote?
  9. Start Problem and Code Question...
  10. 95 SC1 Mosquito Sprayer - pt 2
  11. Start Problem and Code Question...
  12. Horn started blaring apparently spontaneously, now won't start.
  13. clutch a problem or not?
  14. 99,Saturn SL1, Hot air
  15. 98 SC1 Tranny shift issue
  16. SL1 - SL2 Man trans swap - ???'s
  17. Clutch Question
  18. mmo soak?
  19. 95 Saturn SC2 5sp 144k with slightly high idle
  20. 96 SL1 tranny ?
  21. SL2's computer monitors read "not ready," can't pass inspection!
  22. RH Rear Quarter Panel removal for 94 Saturn
  23. RH Rear Quarter Panel removal for 94 Saturn
  24. Door skin swap
  25. strange noise help
  26. Where can I buy murder mystery oil?
  27. OBD II code reset question
  28. Ticking axle
  29. mmo soak
  30. Rough idle, acts like stalling
  31. No Start on 93 SC2
  32. Power Cuts in and out on long drives
  33. '97 SL2 blow by issues
  34. 1997 SL1 Won't start when below 30
  35. my starter sticks on my 99 sl1
  36. sl 5 speed manual xmission
  37. 99 sl2 wont start
  38. SL1 Problem - dont really know what to say
  39. 01 SL1 wont start
  40. SL2 rear speaker help
  41. 2001 Transmission shifts hard from 3rd to 4th
  42. 95 Saturn SC2 5 speed - ENGINE REMOVAL
  43. Rear drums. any thing to look for??
  44. Where can I find a cheap Catalitic Converter?
  45. 92 s-series exhaust manifold
  46. SOHC 1.9 1996, rebuild, no oil pressure
  47. Best plug???
  48. 94 SL2 high idle, surging warm restart?
  49. No Reverse, Probably My fault..Help
  50. 99 sl2 wiper problems
  51. 1991 saturn wont start when hot
  52. 95 SC1 Mosquito Spayer
  53. O2 Sensor or motor mounts?
  54. 2001 Saturn SC1 Quarter Panel
  55. 95 SL1 starter spins don't engage
  56. transmision swop for a 99 saturn sl1
  57. My waterflow tank is always empty, help
  58. 92' saturn starts runs...then stalls untill it gets warm
  59. Wolfman's Reverse Slam Remedy
  60. 2001 Saturn SC1 Reverse Slam
  61. gas pedal question?
  62. Drive Axle Seal installation
  63. 99 SL1 key problems
  64. 93 SC2 stalls service Cant get a code
  65. timing cover gasket
  66. 99 sl2
  67. Murder Mystery Oil Soak How-to
  68. 1998 sl1
  69. Revving when clutch in
  70. '01 SL2 Front end vibration/shimmy shake......HELP!!
  71. 96 motor and tranny swap
  72. SL Spring Special
  73. How Good Are SL1's and 2's?
  74. 01 sl2 Timing Chain Replacement
  75. 1999 s/w
  76. Flex pipe size?
  77. radio time adjustment
  78. radio locked
  79. 01 SC1 scraping & grinding when brake low spds
  80. ok, probly last thread i make in the SL section...
  81. 93 SL2 O2 Sensor
  82. Automatice saturn wont shift right
  83. 94 sl2 auto trans prob when cold
  84. car shuts off
  85. high mileage-extremely poor fuel efficiency
  86. rough idling/rpm fluctuating
  87. 95 SL2 manual will not start
  88. had a little misshap..
  89. 93 SL2 idle problems
  90. 94 Saturn SC2 Engine Locked Up
  91. 2000 Sl2
  92. What are the rpm's at 60 mph
  93. '96 SL2 running rough
  94. Theft-Deterrent Radio
  95. "Service Engine Soon" Light Problems
  96. 99 saturn sc,
  97. Glove compartment won't open, any ideas?
  98. bad viberations-96 sc2
  99. idle is ruff
  100. 94 Saturn SL1 Smokes Bad.....
  101. 1998 SC1 gas mileage
  102. O2 sensor locations......?
  103. P0341---'01 SC1 1.9L SOHC Manual
  104. Funny noise
  105. Radiator extraction for 97' SL 1.9L SOHC(Procedures)
  106. 94 SC2 Problems
  107. 97' SOHC manual tranny fluid change.
  108. 99 Saturn SC2-horn
  109. 97 saturn sc-how to change a fuel pump?
  110. just got a new header..
  111. 2000 SL2 turns over will not fire
  112. fuse
  113. 99 saturn SL1, Coolant temp.
  114. coolant change/flush
  115. 93 SC2 Starting issues
  116. 1994 Saturn Fuel System Problems
  117. Need help of certified saturn mechanic
  118. 98 saturn manual trans hard to shift
  119. Goopy coolant
  120. Driving lights not working
  121. Oil Pressure and Suction seals
  122. sc2 gas mileage
  123. 93 saturn serious fuel system problem
  124. 93 SL2 automatic
  125. vibration when im braking
  126. 1996 saturn sl1 coolant drainage? help
  127. low coolant/high temp light intermittent flashing
  128. difference between a 2001 sl2 motor and a 99 sl2 motor
  129. 98 sw1 em. brake light stays on
  130. 98 sw1 em. brake light stays on
  131. My SC2 keeps blowing fan relays
  132. 2002 SL2 - Engine Pings...
  133. 96 saturn sl1 air dam
  134. Im looking for a website about engines
  135. 97 SL manual trans won't start
  136. 1998 Saturn SL2 flickering dash panal lights
  137. 99 saturn sl2 keyfob programming
  138. 1995 Saturn SL2 Gas Pedal Problem
  139. Loud Engine
  140. won't stay running
  141. 99 sl2 headlight dim
  142. Few problems with my Saturn.
  143. 95 sl2 cuts out on hard take off
  144. 1995 Saturn SC2 smoking at idle and missing
  145. 92 saturn sl1 wont start
  146. Type of Coolant
  147. traction control switch
  148. 92 saturn sl
  149. 1998 Saturn SL2 has high idle?
  150. 01 SC1 Morning Sickness
  151. Transmission clunks/stuck in third
  152. service engine soon and ignition takes 2nd attempt to start
  153. Keyless won't work and Passlock is disabling engine.
  154. HELP!!! 98 Saturn SL2
  155. Help! Parking Pin broken or what?
  156. I have 2 problems, (1) horn doesn't work (2) airbag light stays on
  157. questions re 1998 SC1
  158. Silly Harmonic Balancer, Crankshaft Pulley quesion
  159. 92 starts then dies
  160. 98 saturn sl2 Flashing coolant light
  161. 94 saturn SL1 Front bearing Hub - transaxle noise
  162. 92 saturn
  163. won't shift into 1st or 2nd
  164. Saturn Engine Swap Dohc to Sohc Please help!
  165. 93 sl1
  166. Ill Saturn
  167. Twin Loop
  168. Specs
  169. 2001 sl2 whine noise over 40 mph
  170. 01 SL2 Cant Get Ignition to work with new key
  171. Rattling during acceleration
  172. 1998 Saturn SL A/C Not Working
  173. 92 saturn sc hesitating and running rich
  174. 97 saturn sc2 wont turn over
  175. 1.9 DOHC High mileage ??
  176. Engine and Transmission Swap
  177. 92 Wil Not Start!
  178. 92 Saturn SL2 sometimes stalls when I do a quick reverse
  179. 93 tranny leak
  180. I need Help!!
  181. Please help: Key won't release from ignition
  182. Strut assembly or strut mounts?
  183. Car wont start. Cranks Fine.
  184. 02 Saturn Transmission
  185. Strange "vibration"
  186. 97 SL2 Manual Tranny Fluid
  187. 1992 SL 1.9L SOHC No Fuel
  188. 1997 SL2 Cruise Control Problem
  189. Need rear brake help FAST
  190. K&N intake results??
  191. model explanations SL1,SC1 ect.
  192. Have to change waterpump on 97 SL1
  193. wont start but starter spins
  194. 1997 Saturn SL2 Auto Transmission
  195. 1998 saturn
  196. 95 SL2 down shift issue
  197. 98 SL A/C not cold anymore
  198. 1999 sc2 motor
  199. 99 Saturn SC1 Hood interchange
  200. 96 sc2 noises
  201. 97 SL2 Engine Removal Conficting Information
  202. How to check rear wheel hub bearings?
  203. 93 SC2 Oil Pressure Release Valve
  204. saturn high idle and vibration
  205. Saturn Oil Pressure Issue
  206. Realistic SL mpg and K/N air filter
  207. 93 coolant sensor
  208. not sure
  209. 1998 SL-II Reverse not working - HELP!!!
  210. wire diagram
  211. 94 Saturn sedan A/C not working
  212. Transmission Heat Noise
  213. 1997 SC2 Spark Knock?
  214. 99 SC1 Turn signal fuse blows PLEASE HELP
  215. 1995 Saturn SC2 Overheating Issue
  216. Weird noise
  217. se code p1336
  218. Help, car jerks/rocks when accelerating
  219. S Series Oil Consumption
  220. 96 SC1 Dash lights do not work
  221. 94 SL No Compression
  222. SL1 Blowby?
  223. 98 sl1 inspection problems
  224. Mileage Expectations '98 SLI AT
  225. 98 SL motor/transaxle mounts?
  226. 2002 SL2 - Engine Pings...
  227. 98 SL with 99 TPS?
  228. 96 belt prob
  229. Coolant problem.
  230. Starter Relay Location on Saturn SL2 2001.
  231. Saturn SL 2001 Starting Problems.
  232. 1999 saturn sc2
  233. SC2 Hard To Shift Into Gear.....
  234. fuel filter
  235. 1997 SL coolant refill procedure
  236. 97 SL2 Intermittent Engine cut off problems
  237. 01 SC1 wiper motor
  238. throttle positon sensor promblem in saturn sl2
  239. 2002 SC2 with a problem I can't seem to identify...
  240. SC2 CD player...
  241. 1998 saturn sc2
  242. radio/CD Player goes off when car come to a stop
  243. 01 sc1 gas mileage
  244. HELP!! Saturn SL2
  245. 95 SL2 Transmission Issue
  246. overheating problem
  247. 2002 SC1 3dr coupe....Audio System
  248. 2000 SL2 A/C Diode
  249. Temperature/transmission issue
  250. 97 SL1 Exhaust
