View Full Version : Montana/Montana SV6
Pages :
1 2 3 4 5 [ 6]
7 8
- 99 montana parts wanted
- Major Maintenance - Suggestions?
- Removal of Oil Pump Drive
- Cleaning the Lower intake gasket contacts
- 2000 Montana front brakes
- 2000 Montana Monsoon amp--
- Temp Guage and gas guage
- Antifreeze smell (intake replaced) Tranny Fluid?
- Montana Radiator Petcock
- just replaced intake gaskets
- 2002 Montana
- 2003 AWD Montana During Startup Idle will not engage
- Radio faceplate transplant a success?
- Front wiper replacement
- Keyless Entry Programming not Working
- Automatic headlights (DRLs)
- 1998 Montana Power Sliding Door Inoperable
- highest mileage Montana?
- ABS sensor on 2001 Montana
- interior heater problem
- Lower intake manifold gasket
- 2000 Front End Clunk
- 2005 SV6 ABS failure
- Anyone install a remote starter in their Montana?
- Class Action Law Suit affecting Pontiac Montana V6 engines AND other GM V6's
- Montana 2000 horn quit working
- Service Engine Light
- air bag indicator light?
- Steering question/Shake and bump
- How to Bleed properly?
- Oil "explosion"
- '98 would not shift from PARK (hand thing)
- Lower intake, water pump - price?
- Headrest removal
- 1999 montana fog lights
- Replace Overhead Console on Montana
- front wipers won't park
- Replace stud on wheel...
- oil level sensor leaking oil?
- Direction indicator display.
- check engine light
- front control arm bushings
- New ABS motor?
- 98 Trans Sport Abs Problem
- antifreeze smell
- Wheel bearing????
- Just noticed: transmission line crimps leaking
- Blow Head Gasket or bad Intake Valve?
- just Bought a 2002 montana what problems do they have?
- 2000 pontiac montanna antifreeze leak
- 2002 montanavision a/c problem
- 1999 pontiac Montana is over heating please help
- remote???
- headlights problem HELP!!
- Transmission not locking up into overdrive
- HELP - I have no heat
- Temperature Gauge on 2001 Montana
- temp gauge
- Rear Wiper Problem on my 03 Montana
- 2001 Montana thermostat problems
- Roaming Temperature Gauge
- Headlight interior cleaning?
- 2003 Montana Engine stutters
- GM oil life system information
- 1999 Pontiac Montana Thermostat replace
- Glove box door hinge - cracked plastic
- security
- Air blower not powerful
- "Tapping" into the existing speaker system...
- 1998 Montana - "service engine soon" & fuel system?
- heater no blowing unless on defrost
- 2003 Montana - rear suspension problem
- Typical Life/Mileage Expected
- head gasket
- 2004 Montana Vehicle Personalization Programming
- Poor gas mileage, weird smell...other issues
- Dim Headlights-how to troubleshoot
- Loping IDle
- Wireless headphone part number for 2002
- Overhead console with DIC
- Turn signal switch
- Intake Gasket failure -- what are the symptoms?
- 2001 Montana with a replaced battery
- No Power
- How to Replace Door Mirror and Internal Overhead Lamps
- Where can I get the 'best' transmission filter
- GM coolant system tablets
- rpm's fluctuating
- 2005 models how long do Dealers keep them?
- 2000 Montana, no power to ignition
- starter noise
- Keyless entry problems
- where is the transmission fluid going??
- radiator fans
- Left signal keeps blowing
- trans additive
- Shop recommendations - west Chicago suburbs?
- New owner of used Montana -> questions
- intake or head gaskets?
- Stained plastic body cladding
- Speedometer/CruiseControl Broken
- Brake Lights
- Air hose....
- 2001 Montana-Check engine Light - Chugging
- 2001 montana engine removal
- A/C prbloem
- compass, temperature mirror
- Radio Wiring diagram?
- Rear Shocks
- RDS radio Retrofit
- turn signal flasher/relay location?
- '02 Montana "gagging"
- Oil in Coolant but no Coolant in Oil
- No Start/No Crank Condition
- Fuel pump shut off - Short in plug
- 98 Montana Valve Lifter?
- 98 Trans Sport Montana engine question
- UPDATE: ERG and EVAP Code 2000 Montana
- 2000 Gas Gauge fluctuation
- ERG and EVAP Code 2000 Montana
- 1999 Montana Power Sliding Door
- Engine Oil Cooler hose replacement
- 2005 Montana SV6 is a lemon
- Front Wiper stays UP
- changing bad battery
- clunking when braking
- 2002 AWD Montana Rear Ball Joint
- 02 Montana head lamps will not go out..
- Valve for Montana load leveling system? Not airing up properly upon loading/unloading
- How to access Front passenger door speaker
- "Missing" Fuses on my panel
- Rear air shocks...
- rpm's going everywhere
- shut down
- New owner with problems
- spare tire.....
- power sliding door
- New member, new owner
- Can't program 2nd key
- Aircon blower switch only respond to level two higher, not level one
- radio volume control
- transmission
- NF2 OR NC1 federal emission engine
- dim lights don't work
- Montana changing to higher gear.. jerks hard forward
- Service Manual for 2002 Montana
- After market stereo installation
- RPM - What's it supposed to be when stopped?
- K & N air filter
- 2001 Montana Keyless Remote Question
- 2000 pontiac montana or any GM product with a 3.4 engine
- 98 Montana VERY fast Idle! Help!!
- 2001 Radio with no sound
- Radio Display Fix
- 99 montana electrical problem
- Changing the battery
- 2000 Pontiac Montana
- A/C Smells
- What does code "P0102 Mass or Volume Circuit Low Input" mean?
- Canadians: Which gas brand do you use?
- Which reader/scanner to buy?
- 2 Problems with my Montana
- Blown Mirror Fuse
- Power Window Fuse
- just replaced intake gaskets - still have probs - please help
- Sometimes won't start
- New key programming
- No Start Condition
- Fuel Cap?
- got engine oil in the coolant.
- Radio light out (intermitant) any ideas??
- Fuel pump relay location
- Buying Gas - My Montana is very picky
- Replacing computer
- Oil Cap Stuck
- 2000 Montana idles high in park and seems to want to acclerate on its own
- AC Help
- 1998 Montana Overheating
- 2000 Montana Starter question
- loss of power/dying
- Different cluster light prob..
- Coolant change q's
- My Montana Hell
- Blower speed (5) not working
- rear wiper
- Wheel Bearing or CV Joint???
- Heater hose
- 3800 engine swap
- Montana SV6 - Dashboard instrument panel control (IPC) malfunctioning
- coolant leak but not overheating
- Power Door Locks Unlocking Randomly
- No rear Lights or Cluster lights.
- Transport oil grade?
- clunking sound when turning the steering wheel??
- Strange Vapour
- Transport Running Hot
- Code P1810 TFP Valve Position Switch
- Montana glove box door hinge
- FYI - SV6 / Uplander Engine Harmonic Balancer
- When to Oil Change my SV6
- Another Montana key problem
- More Power Window Questions
- AC recharge help
- Should I replace the o2 Sensor??
- Front Wheel Bearing
- interior lights not going on???
- van cuts out when going fast and long distances
- leaking air cond. compressor
- strange idea
- 1999 engine blown?
- very noisey fuel pump
- overpriced replacement key
- code po122 and rpm revs high in park and drive
- fluctuating rpm
- 2001 Montana Shorty.....Transmission Slipping
- 99 montana 3.4 v6 wont start
- 99 Montana ABS and Brake lights on after brake service
- Gas smell inside van
- noise in the rear....
- Montana power windows
- Repair Manual
- Where do you find the paint code ???
- Loud Thunk
- Power windows switch
- Question for you folks with bad transmissions
- Coolant, overheating 1999
- 2003Montana, power sliding door open by itself in the parking lot
- gas tank heat shield vibration in cross winds
- 1998 Montana nightmare - blown engine!
- 1999 tranny issue........
- What is the gas tank made of?
- Intake manifold antifreeze leak
- Hatch pull-down
- drag coefficient, weight, gear ratio question
- Time for a tune-up, any suggestions
- My montana is a swimming pool.
- Overheating, high speed fans not kicking in !!!
- ABS Light on 2003 Montana
- Parking brake light, why ?
- Watch out for falling spare tires!
- rear quarter windows not working help
- ABS and Brake lights on. 99 Montana
- Compressor
- liquide sound under dash
- turn signal cause more lights to flash
- Engine dies
- 2003 serpentine belt replacement
- cruise and brake lights quit working
