View Full Version : Eighty Eight
Pages :
1 2 3 4 5 [ 6]
7 8
- 1995 LSS engine code diagnosis problem
- power windows wiring
- '75 Delta won't start with turn of key
- '92 88 royale stalling
- Backlights are out
- door lock blowing fuses
- Olds 88 403ci ok to leave EGR disconnected?
- Harmonic Balancer Bolt Removal
- really wierd engine start problems
- Possible tranny question help
- 91 Olds 88 Royale
- cabin air filter
- Where's the starter on 1994
- How to adjust TPS?
- refrigerant for 93 LSS?
- Buying a 1994 '88 Royale for my 1st car. Supercharging?
- Air conditioning recharge kits?
- Auto climate control
- Odd smelling exhast
- Headlight question
- 86 olds front right axle
- stalls
- Water OK for 2 min Radiator test?
- 1998 3800 R & R intake gaskets
- White Smoke from exhaust pipe?
- DexCool for 95 LSS??
- 92 Gauge Cluster
- Anyone from Oregon, Washington, or Idaho?
- Belt replacement 88 Royale
- AC condensor Swap?
- 92 88 Royale Stalls While Driving
- 1995 oldsmobile eighty eight
- Dead Beater-mobile
- 1995 88 Fuel Pump ???????
- 97' Olds Eighty Eight - Needs New Motor?
- my 86 delta olds fuel filter
- 92 Olds ac/heater vents
- 1988 "88" Won't start...Code 63???
- engine coolant temp sensor in olds 88
- 1988 Delta 88 Stalls, and Won't Start
- Flooring it to second
- 88' 88 Rewire headlight Q.
- Help - mechanic says motor gone
- Transmission Fluid and blown Bright
- Clutch Cycling Switch
- runs bad
- Removing Radio 88
- '92 Olds 88 steering wheel removal
- '95 LSS Delta 10 MPG?!!!!!
- 1989 Olds,Wheels
- 1974 Delta 88 Convertible Problem
- Exhaust pipe size?
- ac wont work
- 1986 Delta 88 Fuel Filter location
- ATTN: 95-99 Olds 88 Owners with Non-Supercharged Motors
- Stalling & Dying while Driving
- code 26
- intake wont work right
- 95 LSS brake pedal
- Xenon or white light headlamps?? 1983
- radio removal
- Rear Brakes
- ?????Olds air ride question?????
- 88 Harmonic Balancer?
- 87 olds staling problem
- Mirror Replacement.
- 92 88 No spark?
- Just some pics for this tired old forum hah
- Bleeder Valve
- Location of Inertia switch for 1990 Olds 88
- 89 olds 88 sticking front brakes
- Eighty Eight HVAC Problems
- 87 Power Seat Switch Question
- 89 delts 88
- `95 Delta 88 SHAKING ETC
- O2 sensor
- Olds 88 A/C Clutch not engaging
- screwy gas gauge on '97 LSS
- Keyless remote problems on '97 LSS
- Replacing Mem-Cal/Cam Sensor?
- Strange noise and starter problem
- 1990 olds 88 / fan not coming on all the time
- '94 stalls at stop signs
- wnat 24s!!!!!!!!
- In need of a cheap transmission
- climate control in my 98 delta 88
- Did a search, found nothing.
- 93 88 starting issues
- '89 eighty eight front brake problem
- No 3rd, Overdrive and Reverse Gears
- real bad day for my 88
- Radio Removal
- 1989 Window wiper replacement
- 1998 Oldsmobile 88 interior lights and locks not working
- Sputtering and electrical
- 1990 --Removal of Hood Latch?
- Moody & Mind of Her Own
- wont start, but will start
- Gett Better Bass
- 1987 delta 88 royale problems installing cd player
- When I stop It wont restart O_O Quick question.
- heads
- 1995 Delta 88 Wont kick over
- Help, 1993 Delta loses oil pressure all at once?
- 1990 Olds Delta 88 Check Engine Light?
- Replacement Seats for 97 Olds 88
- 3800 Engine Oil Pressure Problems
- hp specs on a 76
- subwoofer's what are you guys using?
- Help with a quick repair (I Hope)
- 3800 turbo
- 3800 turbo
- Xenon HID bulbs for 1997 88
- loss of heat controls
- Check Engine Light
- Bleeder valces rusted shut
- Hesitating car....
- Odd Radiator Leak Problem
- blowing fuses
- 88 runs bad when warm outside
- Numerous Electrical and other Quirks (long, help!)
- 1995 Oldsmobile LSS
- stock speaker sizes ( i searched already)
- Fast Chime When Interior Lights On
- More power out of an 89 Custom Cruiser?
- My 77
- ABS and traction control issues...
- 95 88 A/C Compressor
- Help finding where electrical connector goes on 93 88?
- 20 in wheels
- 94 olds 88 stalled after hard right turn
- Starting Problems-Dead 88
- For Sale: '92 Eighty-Eight Factory Service Manual
- Cruise control won't work-95 OLDS 88
- 93 olds 88 3800 engine no spark/wont start
- Plugs and wires????
- gas milage
- Lights
- service engine soon light stays on
- Engine won't turn over when it's wet outside
- Brake lights won't turn off
- 1978 Delta misfiring and sputtering
- Trying to get a 91 eighty eight royale up and running again.
- Super Great Speedo
- KEN-CO plenum kits
- 95 Olds 88 Parts Available!
- k&n cone filter
- 94 oldsmobile 88 royale I need help with its choking and dieing
- Where to buy parts online??
- 1990 88 Royale - Door's armrest broken
- 1987 Wagon, curious no-run problem
- Pass Key II issue for 1996
- Belt tensioner
- 89 eighty eight backfireing through intake
- 1988 royale brougham idles extremely rough
- 1988 Delta 88 3.8L hard to start in very cold weather
- Speedometer Questions
- 86 Delta 88 Stalling
- 92 tranny problems
- Starter clicks, but doesnt engage
- auto temp control
- '92 Olds 88 will not start
- no speedometer
- 1996 Olds LS88 keyless entry problem
- '89 Delta 88 Window Handles
- I Need To Replace The Ignition Cylinder In My 1972 Delta 88 Asap!!!
- 1998 88 Ls
- amp light
- im having some trany problems
- Fuel Pump Fuse 95 Royale 88
- heater module question
- What could it be?
- 91 eighty-eight stalls going around turns
- 1988-3800 Keeps Blowing Cam Sensors
- Replace rear 6X9 speaker ?
- 1992 Olds 88 doesn't start
- Pass Key II ?
- cutting off
- Installing new head unit..
- 90 Heating Problem
- All Lights Flicker
- Power Antenna Help???
- Interior Lights are Haunted
- Am/fm--cd
- keyless remote
- Ac and heat not coming out.
- Need some Help With my steering column
- heater blows cold air
- Wheel lock troubles
- Chirp in Engine
- brakes
- starting problem
- 97 Olds 88 LS
- CD wiring harness
- Radio wires
- Oil in Coolant
- olds 98 parts compatible w/ 88 parts?
- Door Panels
- A M Radio Probelm
- 92 Transmission
- Hood
- door locks on a '95
- Climate Controls Light is Out
- Can't bleed brakes?
- Transmission issue
- Manuals on 1955 oldsmobile
- coolant leak
- wheel swap
- someone please help me my car is dangerous!<im a female...lol>
- not firing!!!!!
- Interior water leak
- 1990 Olds. Cutlass Ciera S
- Fan problem
- dash lights and tail lights both out
- Need Parts
- '96 LSS lighting & remote problems
- rim sizes
- newbie
- Thinking about buying a 88
- 96 LSS CEL after low on gas
- Sounds Like air coming from engine
- speed sensor location
- Horrible Mileage!!! Help!!!
- Annoying whistle??
- Paper clip trick??
- Strange problem with 92 delta 88
- Firing order for 87 Delta 88
- Trans chatter on hard take off
- Engine Light and Starting problems
- Vehicle weight
- rear drum brake adjustment???
- front left lower ball joint help....
- Loud grinding/rattling noise in my olds 88 (-90)
- engine struggles when brakes applied
- Help replacing CV Drive shaft on 1988 Delta 88
- Delta 88 rough idle + (1988)
- Rip@ 156,053
- Question about getting this car
- Major Brake Problems
- My car features
- Coolant in engine oil, need advise?
- Big Favor: 1995 Olds 88/LSS Factory Service Manual Pages
- Carburetor, Lean Mixture Screw help needed
- 4T60E trans
- exterior door handle
- 93 Olds 88 with transmission fluid in oil?
- 94 check engine light/smell of gas
- my 88 keeps cutting off while i am driving
