View Full Version : Eighty Eight
Pages :
1 2 3 [ 4]
5 6 7 8
- 1995 Eighty Eight SES code help
- Camshaft button wear
- 1988 codes 24,27,28,29,31,41. Help!
- Headlight problems
- awful noise
- 1995 Eighty Eight Engine Coolant Temperature
- tachometer in 1989 eighty eight
- New 1993 Eighty-eight Royale LS owner
- Lss Ground Busses
- 95 Eighty Eight Royale - Need Advice / Help
- 94 Olds 88 Cold Weather Brake Problem
- new blower motor, but still now air blowing?
- 1991 88 pops, shakes and misfire
- geting the head shaved? on the olds.
- 1988 olds delta eighty-eight, good buy??
- Speedo quirk
- 1992 eighty-eight HIGH VOLTS Problem
- Eighty Eight Dies often
- 1994 88 Royal LS - Vibration on highway
- 88 transmission problem
- TPS problems AGAIN!!!!!!!! i think?
- Fog Lights...Adding
- Manual to Auto
- which strut should i use??
- olds 88 pobs.
- Upper Plenum replacement 3800 series II - post install problems
- 94 Eighty-Eight LSS Shaking
- cold air is fun
- 95 olds 88 electrical problem
- My '86 stalls when it heats up
- Pass side heater does not work
- 96 88 speaker mounting
- fuel pressure regulator location
- '95 OLDS 88 engine problems!
- Blower won't work on 93 Delta?
- Locking up while driving?
- What to do w/ code 42
- Help....Will not start
- 88 oldsmobile 98 stutters and jerks
- new look for an old old's
- 98 Olds 88 Cooling Fan Problem
- PLEASE HELP ME ASAP!!!!!96 olds delta 88
- Weird Grinding
- Wanting to start but doesnt.. bah
- How to get trouble codes?
- 93 Old's 88 jerking tranny in 3rd
- 1994 OLDS 88 - Starting Problems
- 97 olds lss EGR code 4101
- 1999 Olds 88 won't go over 3500 rpm.
- estimated cost?
- 1994 Olds 88 LSS (cont'd from prev. post)
- Ignition stuck ON...'87 Delta 88
- 1994 Olds, 88 LSS
- '91 Olds 88, with 3800 runs rough
- Anyone have the torque specs for main/rod bearing caps?
- digital console
- Power Seat recliner works poorly
- 1994 olds 88
- '95 3800 engine trouble codes?
- 3800 engine starts, idles real rough, and stalls after 15 seconds
- surging 95 eighty-eight LSS
- 1995 LSS transmission slipping and speedometer stopped working
- 324 Rocket Pre Sale Info Needed
- cant get it started
- heater/blower issues....'93 Delta 88 LSS
- 3rd Starter
- 92 eightyeight stolen now car wont start
- 1992 Tranny Mount
- coolant leak
- Brake parts -1951 Olds 88
- Replacing Starter 1995 Olds 88 Royale
- pvc+$48 K&N air filter = alot of savings *PICTURES*
- What motors can I swap into my Eighty-Eight?
- Interior Lights Stay On
- Aesthetics
- 93 88 with 3.8 no start
- Amp light flickers
- **HOT** Parking Brake Wont Engage
- 94 Door Panels
- front brakes overheating
- a/c suggestions
- 1990 Eighty Eight Transmission Shift
- Starts on the second try, never the first
- Blower Motor Duct Not Opening 1991-88
- 1996 fuel pump. fuse? relay?
- 1999 Olds 88 AC blower intermittent
- backfire and rough start
- 1990 88 cooling fan problems
- '89 88 Battery/Starter Issues
- EGR? i'm not sure...
- considering an 88 88--issues?
- '91 Olds 88 - Cam Sensor (Code 41) Problem
- Just sayin...
- Need help Olds LSS 96
- Banlandia?
- Big Problem
- Connecting the lockup on a THM200 transmission
- OBD 11 Failed to link & Blown Fuse
- '87 Delta Idle issue
- Blower Motor Problem 1991 olds 88
- 1992 88 security code?
- Hey Acid-Crash
- 3800 history (link)
- i gutted the cat :)
- assembly manual
- 1996 olds 88 engine/transmission
- 89 Olds 88 - how to charge a/c???
- AC probs.
- Volt light stays on - 95 LSS
- NEED Expert help, '89 v6 backfiring
- Exhaust
- 1984 88 enigine
- 96 88 engine cuts out
- Help! 97 LSS will not run.
- 1992 88 Speaker replacement
- Oil pan removal - 95 LSS
- 1989 olds 88 royale brougham
- Help! - gas guage problems 1990 olds 88
- wheres the fuel filter on 96 delta 88 ls
- car jerked during accel tranny issue? :(
- Battery discharge, voltage leak?
- 96 88 oldsmobile Starting problems
- 97 Olds 88-Two problems
- Oil pan leak, or other on 95 LSS?
- turbo question 92 oldsmobile eighty eight royale
- Radio Unlock Code
- Intermittant dying while driving 1994 Olds 88
- 93 olds 88 ram air mod *PICTURES*
- auto trans interchange
- 1990 88 Transmission delayed engage
- metal flex pipe ram air :)
- Spark Plug Wires
- What could this be? ('92 Delta 88 LSS)
- Original Repair and Parts Manuals coming soon
- How to replace window regulator '91 Delta 88
- a/c question
- How to get my door panel off
- Broken Wheel Studs
- just bought 93 olds 88
- A couple of problems with my '96 Eighty Eight
- Water Pump
- odd electric issues
- Posers!
- easy mpg increase?
- 1987 Olds. Delta 88, Spark problem
- 1985 88 stereo wiring
- Back doors wont unlock
- 89 halfshaft removal problem :(
- Funny little story
- 1999 Olds 88 water in oil pan, runs rough - any simple fix?
- Greetings from Iceland
- Exhaust Dump
- 98 LSS Will not start
- Valve Clicking Help
- Wont Stay Crunk!
- Strobe Light Help?
- 87 Delta 88 FE3 Speedo problem
- Electrical Help!
- V8 in 1994 88?
- 1995 Olds 88 engine swap
- 1998 Shifting Hard
- Plenum leaking
- it doesn't start
- 94 delta 88 just shuts off no power to FP, seats or windows
- i need ideas for factory speakers
- 93 olds88 no power after warm up
- 1990 Olds Delta 88 Transmission Issues
- Disconnecting The EGR Valve
- Jerking, brake light, and check engine
- Custom Air Intake
- valve cover breather
- 1994 Olds 88 Front End Noise when Turning
- 1994 Olds 88 ABS Brake Problems
- Kick Pannels
- 94 olds will not start
- Cheap Power Increase
- hmm..finding and disabling keyless entry.
- how to test 95 Oldsmobile 88 cam and crank sensor
- '94 88 Royale OBD1 or OBD2?
- Multiple/Random Cylinder Misfire
- Gas Millage!
- Misfire in Cylinder 1
- Catalytic Convert '94 Eighty-Eight
- 95 delta 88 shaking problem
- 86 delta 88 topic
- paint
- antifreeze backing up into heater
- 94 olds 88 royale
- Cam Sensor
- new camsensor interupter magnet
- 95 88 Royale Starting Problems
- code 41 help desperate
- 96 Olds 88 - Fuel/Gas Door Won't Close
- 1994 Olds 88 Harmonic Balancer
- 1992 Delta 88 - Replace Front Pass. Fender?
- '93 Olds 88, w/ quite a few problems
- What are the best tires for my LSS?
- Fuel Enable Circuit
- what is a code 58...?
- Looking for Center Console
- Belt to bypass A/C pump?
- Where the h*** is the flasher?
- Wierd Noise
- 94 Olds 88 with stalling/check engine problems
- 89 Olds 88 Royale Brougham, excessive heat
- OBD or OBD II
- 87 Olds 98 regency no start
- setting tps tps problem
- '93 88 Royale water pump replacement
- 1993 olds 88
- Bad torque convert shudder on 95 eighty eight?
- Good source for parts?
- valve timeing
- Timing question
- Starting Problem Need Help!
- Aftermarket AM/FM CD suggestions
- 1995 88 3.8 K engine, starter wont crank
- 93 buick lesabre the same as 92 olds eighty eight
- 1999 olds 88 clicking noise very annoying
- Windshield wiper adjustment help
- change as you go straight flow pipe
- Diagnostic Tool - Best one for the money
- 1993 olds 88 rims?
- 1994 88 Misfire
- ugh stalling rough idle codes 15&22 this car hates me
- expensive a/c trouble?
- 3.8L V6 VIN C Vs. VIN 3
- check engine light and code 22
- almost got the problem solved just need a little help
- WEIRD - 1991 Olds 88 Sounds like exhaust leak sometime.
- Code 44 and 13 help
- Fuel Injectors + backfiring
- 1991 Olds 88 - Trans problem
- Keyless entry program procedure
- Problem starting my car
- code 66 mystery
- 98 lss outside temperature
- Chaning belt but want to leave ac off
- 83 Delta 88 Royal V8 enging PCV Valve Location
- What is making my baby stall so badly?
- 1987 delta 88 3.8 lifters question
- Engine Swap
- Engine Swap?
- 93 olds 88 transmission problem
- Power amp or not? 1991 Olds 88
- 89 olds 88 delta speakers
- Just scanned vehicle
- Eighty Eight vs. Ninety Eight
- 88,88 stalling when hot
