89 Olds 88 Royale Brougham, excessive heat
ahkjr33
02-15-2006, 04:15 PM
I recently bought a used 89 Olds 88 Royale Brougham, not running bad for the condition it is in, but when heat is turned off and you are just crusing a lot of heat seems to be coming out of vents. Fan does kick on and off, I have heard it. I don't know much about cars, any suggestions on what I could check, can't afford to put it in shop. And temp. gauge goes nowhere near hot.
tri-power
02-18-2006, 01:02 AM
Does it still blow out hot air when the blend door is adjusted?
ahkjr33
02-19-2006, 03:07 AM
Thanks for replying. I'm not sure what a blend door is, is that a vent or is it under the dash.
tri-power
02-19-2006, 09:42 AM
Yes but before you worry about taking it apart, does it still blow hot air when you adjust the temp to a cold setting?
ahkjr33
02-21-2006, 01:07 AM
Yes, when you set to the lowest setting it still blows hot, but the problem is that hot air comes out when the climate control is turned off. Thanks ahkjr33@msn.com
tri-power
02-21-2006, 09:58 AM
If you still get warm air when adjusting the climate control to a colder setting, you should check the blend door underneath the dash for proper movement. I don't remember if it's vacuum or electric activated. As far as the fan control still blowing out air in the off position, it's a common thing, and I honestly don't have a fix for you.
ahkjr33
02-21-2006, 04:53 PM
thanks for your help, I'll get under there and see what I can see, if I can, I'll let your know
