View Full Version : Rodeo | Passport | MU
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25
  1. Excessive Cranking
  2. AC probs. on 95 Passport
  3. Hot A/C
  4. power window only goes down
  5. timing belt installation
  6. Power Window Problems
  7. IAC Location 2000 Rodeo V6
  8. 94 Rodeo Auto Trans
  9. HELP! - Dipstick broke off inside tube. . .
  10. sick, sputtering, and staggering rodeo
  11. firehawk tires
  12. Radiator Fan Clutch
  13. Poll: What oil are you running?
  14. Tokico Trekmasters vs. Monroe Sensatracts
  15. 1992 Rodeo for SALE 4x4.......
  16. right turn signal problems
  17. Taking over 2000 Rodeo 2wd, V6 - maintenance question
  18. 96 paasport intake manifold ?
  19. Will a 16x8" wheel fit in the wheel
  20. A little more bang out of my rodeo?
  21. power window problems
  22. 91 4x4 p/u problems... :(
  23. high mileage oil
  24. Ebay air intake
  25. AirVent question
  26. 99 A/T Woes
  27. Battery Volts?
  28. Power issue with 95 Passport 3.2L
  29. More 01 Rodeo problems
  30. Walkman car kit = audio tachometer
  31. A/c Filters??????
  32. Oil results with Rotella after 900 miles
  33. 95 rodeo knocking sound on top of engine
  34. jumpy oil pressure gauge and over heating
  35. easy 3" lift
  36. Sea Foam and Auto-RX
  37. Advice on buyin '93 Rodeo
  38. 97 3.2L Valve train rattle
  39. Roaring at 2,000 RPM...
  40. Noisy air conditioner
  41. 1999 Isuzu rodeo oil pressue light
  42. Electrical problem help!
  43. 4x4 Indicator Light
  44. Rotella - 1st Impression @ 400 miles
  45. Fuel Sending Unit Fixed
  46. New tricks for an old rodeo
  47. Idle problems
  48. a/c and cooling fans
  49. Amigo-2K - found Rotella
  50. Key stuck in ignition switch
  51. 01 Rodeo That I Just Bought
  52. couple problems with 92 rodeo
  53. How much for a 98 rodeo, 2.2L
  54. 01 Rodeo Issues
  55. bad oil pressure sensor? help!
  56. O2 sensor question (02 passport)
  57. How many miles have you gone without a timing belt replacement?
  58. Cel
  59. Recalls on my 1998 isuzu rodeo.
  60. super/turbo charger
  61. 96 Rodeo starts sometimes, died at a stoplight
  62. ABS Light on
  63. 93 Auto Transmission question
  64. Engines for 97 Passport 3.2liter
  65. rear collision-alignment/tranny problems
  66. is my isuzu really a isuzu
  67. 18 MPG HWY & 200 MPT (tank) City
  68. Free after rebate Chevron Techron Conc:
  69. 98 rodeo not starting :(
  70. Engine Swaps For A 91 Rodeo?
  71. "Tickers" - if you knew then, what ....
  72. Rodeo Tranny problems
  73. Piston Slap?? Can anyone describe
  74. '93 Rodeo 4x4 front axle rebuild?
  75. cabin air filter?
  76. Rear rotors
  77. door lens cover
  78. Diagnosis complete = sticky/stuck lifter
  79. Isuzu assesories
  80. electrical problems to 2001 Rodeo?
  81. limp
  82. Flip Kit Questions
  83. Opinion: 5w-30 High Mileage oil?
  84. Multiple problems with my Isuzu Rode 1993(V6) ....please help
  85. upshift and cruise control problem
  86. Can i use a spark plug ...
  87. Should I Buy a Used 2003 Rodeo???
  88. Brake noise
  89. Water to clean carbon
  90. transmission stuck in Limp Mode (safe mode)
  91. broken fuel gauge??? please help me!!!
  92. Very poor acceleration
  93. cold start-up issues
  94. 96 Rodeo Noise
  95. drive by wire
  96. IS anyone having problems with oil burning in 2000 rodeo?
  97. TickingNoise tensioner or lifter
  98. rear axle limited slip????
  99. Spark Plug Tube - Oil Accumulation
  100. Check Enging Light
  101. 96 rodeo-no horn, no right turn signal
  102. Idle dropping really low
  103. Wanted - 3.2 Engine for 99 Rodeo
  104. Rodeo Overheating
  105. 120K maintinence
  106. spare tire cover ?
  107. Why is my Rodeo Holding back?
  108. Valet Keys?
  109. My Lift Gate Lock Doesn't lock...
  110. OBD Code P0304
  111. What am I hearing? Tensioner??
  112. Looking to jack up my Rodeo 4-6"! Any ideas at low cost?
  113. 97 Passport power loss
  114. Burning Oil like there's no tomorrow
  115. grinding sound
  116. Very high Idle 99 Passport
  117. Is it possible to fix the Window Switch???
  118. Poll: What oil filter are U running?
  119. Oil Pressure drops to Zero at idle
  120. OEM oil filter - who's it made by?
  121. Opinions: Puralator Premium oil filter?
  122. Passport oil pressure
  123. Battery & ABS Lights flashing-egines dies at times
  124. Suspension Lift 98 Rodeo
  125. Trailer Wiring Harness
  126. a/c on 92 rodeo
  127. factory door remotes
  128. What is the stock battery? '00 Rodeo
  129. More power
  130. 2000 Honda Passport Low Fuel Light - Idle Rough
  131. 2001 Rodeo Problem
  132. Shift interlock solenoid
  133. Oil Pressure Reads Low when truck is warm?
  134. thump during wheel spin
  135. second muffler and benefits
  136. 1995 Isuzu Rodeo Hesitation
  137. Tranny fluid with oil? How much?
  138. Swap a 3.2L V6 for a diesel?
  139. 97 3.2L auto transmission troubles
  140. 01rodeo-clock light out
  141. engine swap
  142. 95 Rodeo Steering Wheel Shimmy
  143. ticking noise... not timing belt
  144. red light on dash
  145. checking timing belt / campaign stickers
  146. tick tick tick
  147. Check engine light comes on when fuel gets low
  148. 94 Delta 88 /Electrical Problem Found
  149. 2000 Rodeo ( ISC ) Suspension module / HELP
  150. Rodeo 3.2L SOHC valve train noise
  151. pulling ac blower 97 passport
  152. Automatic Transmission Problem
  153. taillight/dashlight problems
  154. 97 3.2L Alternator/Electrical issues
  155. FOR SALE: 1998 Isuzu Rodeo - HOUSTON TX
  156. first oil analysis after 12K with synthetic
  157. New Exhaust
  158. 01 Rodeo Sport ABS problem
  159. 99 rodeo won't start, have power !
  160. 1994 passport manual transmission removal
  161. Any ideas why??
  162. how to check tranny fluid in a 97 3.2L auto?
  163. Setting Valve Timing
  164. 2000 Rodeo deterent alarm
  165. '97 Rodeo Questions
  166. 1993 Rodeo 3.2L ist it close interference?
  167. Can I put a radio from a 2000 rodeo into a 1999?
  168. fixing head gaskets - replacing engine (huh?!)
  169. 2000 Honda Passport Spark PLugs?
  170. CEL Code 402 EGR Flow Excessive ??
  171. transmission model # ???
  172. Hydraulic clutch wowes
  173. ebay: hidden subwoofer
  174. A/C Cold sometimes.....
  175. Transmission Issues
  176. Battery Tray
  177. Rear Axle
  178. changing water pump
  179. What range is the Power band?
  180. rodeo won't turn over
  181. fluid transfer pump?
  182. rodeo price
  183. Questions???????
  184. Rattle from passenger side dash
  185. 2001 Rodeo LS Brake Question
  186. 2002 Rodeo Sport leaking Tranny Fluid?
  187. 2001 blower motor
  188. isuzu rodeo wiper intermittent problem - delay module
  189. tranny issue...need help!!!
  190. Cam Shaft Sensor
  191. switch 3.2l to 4.3l gm
  192. Junk Yard Parts
  193. A/C Fan
  194. 97 Rodeo trailer wiring problems
  195. Multitude of issues (possibly engine, tranny, other?)
  196. Rear transmission seal
  197. Transmission Wooes.
  198. max tire size for 95 rodeo
  199. Brake Rotors???
  200. 2002 Rodeo Sport new shocks KYB
  201. cylinder numbers
  202. Automatic Transmission Flush- Safe for High Mileage?
  203. tow package
  204. Can't find the oil dip stick?
  205. 2000 Honda Passport Intermittent Wiper Problem
  206. Spare tire cover -I found one cheap
  207. Cargo ACC Outlet
  208. A/C intermittently not kicking in
  209. CEL solid and flashing
  210. 2001 Rodeo stalls when cold....Help!!!
  211. 2001 Rodeo V6 wants to stall when starting cold
  212. 01 Rodeo Deadly slow...
  213. FYI - Akebono ceramic brakes
  214. 4L30E loves a fresh drink!
  215. How much to replace cv joints
  216. '97 power steering fluid
  217. time and cost estimate for lash adjusters
  218. bad alternator
  219. Stick shift Question
  220. Keyless Remote for '01 Rodeo
  221. Another happy Isuzu Owner
  222. Spare Tire Rack Adjustment
  223. EGR How hard to move should pintle be?
  224. Intermittant loss of power problem
  225. 2002 Rodeo trany leak
  226. sport rear seat removal/question
  227. 99 Rodeo rough idle - IMG already replaced
  228. Altezza Lights for 2000 Rodeo
  229. Rodeo won't start
  230. Hard Starting
  231. Excessive cranking...then fumes when started..
  232. 94 EX 4x4, tranny code 61 ??
  233. Hard shifting 96
  234. tapping noise
  235. STP gas treatment
  236. the error 'Codes'
  237. Major Transmission Problems!
  238. no turn signals/4 ways
  239. 1999 rodeo engine stalling while stopping
  240. 1993 Rodeo LS 2wd FOR SALE
  241. I.M. Gasket Upper or Lower?
  242. always in limp mode... any suggestions?
  243. Shity spark plugs cause O2 sensor code??
  244. the '99 gave a loud bang
  245. Ooops- door panel removal
  246. What kind of tires are you running?
  247. shipped Replacement mirror- didnt fit
  248. 2002 Keyless Remote FCC ID#
  249. Excessive Cranking, Engine Failure
  250. Early Rodeo Electric Windows
