2000 Honda Passport Spark PLugs?
johnjsa
05-26-2005, 02:35 PM
I have noted the posts about using the Denso plugs in the Rodeos, does this also apply to Passports? What about using NGK plugs?
amigo-2k
05-26-2005, 03:03 PM
Yes a Passport is a Rodeo.
WHen the truck gets to the end of the line, they grab a Passport badge instead of a Rodeo badge.
rodeo02
05-26-2005, 11:23 PM
Yep, you want to stick with the denso's on the 2000+ 3.2/3.5L The darn things are expensive enough that I wouldn't hesitate to pull, inspect, anti-seize and put them back in if they look good! Those plugs should last a long time. If you cannot find denso plugs locally, try sparkplugs.com
G/luck
Joel
G/luck
Joel
