View Full Version : Trooper | SLX | Bighorn | Wizard
Pages : 1 2 3 4 [5] 6
  1. 89 trooper won't fire
  2. 1989 trooper won't start
  3. Adjusting clutch on '96 Trooper
  4. wheel speed sensors on 2001 trooper
  5. DIY Tranny
  6. isuzu tod transmission
  7. Engine light on after o2 sensor replacement
  8. 4ZE1 Problem... HELP!
  9. 2000 Trooper need help with a few Qs !....
  10. '91 trooper cranks, won't start
  11. Need parts for 88 isuzu trooper???
  12. heater blower motor????
  13. heater core leaking 93' 3.2
  14. Have You Replaced Your Own Tranny and Clutch
  15. need and egr
  16. Mpg
  17. 1993 Trooper Transmission grinding in 2WD
  18. Oil Usage Problem- 94 Isuzu Trooper
  19. Clutch Replacement
  20. '95 Trooper Lifters Knocking, Knocking at my door.
  21. 91 Trooper lacks power
  22. CEL Still on
  23. Source for used parts
  24. Answer's about my 1990 Trooper
  25. 91 Trooper possible new tranny and other minor stuff
  26. 1990 4 cylinder timing problem, need help.
  27. 2000 Trooper leaking coolant
  28. Repair Guide???
  29. electronic rust protectors
  30. Need help: codes p0171 and p0174
  31. 3.2 trooper
  32. body roll??? last question.......
  33. Huge help!
  34. headlights turn on by themselves
  35. '90 Trooper Temp Guage position
  36. PO446 code
  37. 2000 Trooper ( the jeep is another long story )
  38. Please Help........!
  39. oops got to rebuild my rear axle.....
  40. Thanks Alot For No Responses
  41. Emergency-brake light
  42. Loud Ticking throughout entire rpm range - 97 3.2L
  43. 92-97 No armrest? where to find one?
  44. 97 - Check Engine Light! Lean on Bank 2, O2 Sensor?
  45. '96 Trooper Window Regulator
  46. Transmission Problem
  47. Montero vs Trooper vs Explorer-buying used
  48. 1989 Trooper Transmission
  49. 89 trooper, fan works but no heat
  50. LOUD ticking 3.2 quiets at 2200RPM
  51. 86 trooper tranny help
  52. Changing out the differential fluid?
  53. No Dash lights, HELP!!!
  54. Engine removal 1999 Trooper
  55. '88 Trooper for sale/parts in FL (Check it out!)
  56. place your vote!
  57. large THUNK when stoping
  58. 92 trooper elec fan.
  59. 96' Trooper Dilemma
  60. Radio/ Int. Light Outage
  61. Low idle, stall, electrical surge
  62. power mods 1994 3.2 V6 trooper
  63. 1991 trooper starting problem
  64. After-market Headlamps
  65. 98 Trooper overheating after intake manifold gasket and Plenum gasket
  66. 91 Trooper Rim question
  67. 2.8-3.4 swap
  68. engine size
  69. 95 Trooper Rear Axle
  70. Repair Manual for a 2001?!
  71. '95 Trooper Light Guards
  72. 1990 isuzu trooper
  73. Strange problem with 87 Trooper
  74. 89 Trooper 180,000 O2 Light
  75. 97 Isuzu Trooper Transmission
  76. I now have two seperate clicks coming form engine, one is really loud.. Please help!
  77. NEED REVIEWS 1993 trooper!!
  78. 87 trooper tire reccomendations?
  79. Just bought a 2001 Trooper LS 2wd, what to mod?
  80. Need Engine
  81. 88 Trooper would lose power, now won't start
  82. 93 trooper trany light blinking
  83. '89 - Oil in coolant
  84. looking for : Weber!!! :)
  85. Clicking in engine 95 trooper
  86. 92 Trooper winter mode
  87. 97 Rodeo rear wheel wobble, losing the battle
  88. 1989 Isuzu Trooper 2.8 eng - Won't start
  89. Black smoke from exhaust
  90. Hello all, one more ignorant question.
  91. Tightening the antenna on a '98
  92. 4x4 Problem - 96 trooper
  93. Shocks
  94. '98 Trooper Keyless programming instructions . . .
  95. Just bought 2000 Trooper
  96. *cries and begs for help...*
  97. Bigger Tires
  98. WorkShop Manual
  99. Headlight problem
  100. 91 Trooper V6 serious hesitation
  101. windshield washer motor replacement
  102. How to check transmission fluid 98 trooper
  103. Need factory repair or repair manual
  104. 60K Service on 2001 Trooper
  105. O2 sensor light
  106. Blinking CEL in 2000 Trooper
  107. 1990 Trooper Headlight on warning chime
  108. 98 Trooper high idle
  109. Weird Idle, cutt off, missing problem 1990 Troopoer V6
  110. Spark Plug Removal
  111. Better Tranny Fill question
  112. 87 trooper II brake question
  113. Trooper starting hard when cold
  114. Time to Change Timing Belt 99 Trooper
  115. lsd passposrt/amigo/trooper/rodeo
  116. 2001 Trooper Transmission problem
  117. 88 Trooper won't start when hot
  118. 91 6cyl stalls
  119. body roll on my 96 trooper
  120. HELP! (Near) Dead Man Walking.
  121. 1987 Trooper II Q's
  122. Thinning Oil
  123. 89' Trooper Electrical Probs
  124. Removing door window molding
  125. 1989 T-2...fuel relay?
  126. New To Post
  127. Why automovieforums rocks
  128. 88 trooper starter short?
  129. Egr
  130. lowering a trooper
  131. When to change timing belt?
  132. P0300 Code on 2000 Trooper
  133. To Change or Not To Change? (Transmission Fluid)
  134. ignition switch r & r
  135. 95' trooper won't start
  136. 01 auto transmission fluid check/refill
  137. Cooling issue, new to troopers, please help!
  138. What are the biggest tires i can put on a stock 90?
  139. Keeping it kool
  140. things to look for in '91 Trooper
  141. '90 2.8TD Timing belt light
  142. 94 Isuzu Trooper Oil Pan
  143. Where can I get OEM Spark Plugs for 2000 Trooper?
  144. 2000 Trooper Blinking Check Engine Light
  145. Isuzu Trooper II Steering Wheel Lock?
  146. HELP!!! Oil Pump
  147. engine noise
  148. 93 Trooper/Anti-lock turning on/sponge
  149. Check Light
  150. Pouring Anti-freeze Somebody Help
  151. leaky injectors 88 trooper
  152. 92 Trooper (check tranny light)
  153. 2000 Trooper Going South
  154. Power Seat Problems! '96 Trooper
  155. What's with Trucky?
  156. 97 Trooper needs a replacement engine?
  157. Throttle Problem...
  158. 1998 Trooper Suspension Upgrades
  159. Reset Timing Belt Light
  160. Buying Trooper Advice
  161. 1992 Trooper 4WD Front Hub removal
  162. Trooper 88 Trouble.
  163. Engine Warning Light '96 Trooper
  164. 89 trooper keeps quitting
  165. 91 trooper transmission mistery...
  166. gas mileage - help!
  167. 88 isuzu trooper
  168. 1995 Trooper
  169. automatic transmissions
  170. HELP! Trans light on (back up mode?)
  171. 98 trooper transmission trouble
  172. Front Clip Parts
  173. 1989 Isuzu Trooper Belt replacement help needed
  174. Rust
  175. GOOD news??
  176. Let's make '98/'99 Isuzu Trooper Recall happen
  177. low gas mileage
  178. 98 Trooper "Check Engine"
  179. Whats wrong with my car? Help now!!!
  180. remote/power locak module/panel on door problem
  181. i need help with cooling.......
  182. 99 trooper motor shot
  183. PVC and ERG Valve Location 99 Trooper
  184. Is the 4L30E trany Self Learning?
  185. my trooper
  186. 2-3 harsh shift after rebuild in 4L30E Auto - Help!
  187. 1996 trooper fan belt help???
  188. power steering
  189. Need New Wipers. Please Help
  190. 91 trooper tranny woes... HELP!!!!!
  191. clubs
  192. Troubleshoot?
  193. A/C not working
  194. 89 trooper
  195. Changing Calipers
  196. 91 Trooper Parts
  197. 1991 Trooper Diesel
  198. Surges at Idle....
  199. 91' door panel removal
  200. 2001 Check engine reset
  201. Check transmission, check engine
  202. Spark Plugs & Check Engine
  203. A/C fan problems
  204. 88 trooper wiring problems
  205. Code P0300 "limp-Mode" Why?
  206. ignition switch stuck...86 trooper
  207. 90 trooper rebuild engine or swap?
  208. '96 Trooper won't start
  209. Transmission Or Spark Plugs
  210. just finished my project... SAS
  211. ticking noise on 96 trooper
  212. Custom Gauges
  213. Strange Engine Noise
  214. 91 starting issue
  215. Where's the Data Link Connector?
  216. Isuzu tranny
  217. Check out my '94 Troop
  218. Rebuilding '86
  219. Flasher/Signal Problem...
  220. 98 Starter removal
  221. 1989 Trooper Timing Issue
  222. 15k maintenance.
  223. 1995 Engine Swap..
  224. P1441 error code help?!
  225. SAS Button
  226. New Member needs HELP( 88 Trooper 2 )
  227. Clutch replacement '86
  228. Considering 1999 Trooper LS
  229. I need a tranny
  230. 1994 Trooper LS For Sale in Ohio
  231. FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
  232. replacement engine for 91 trooper
  233. Need wiring diagram 1996 Trooper
  234. Need new transmission????
  235. Blowing transmission fluid
  236. 88 Trooper starting problems
  237. Trooper pumping oil
  238. Larger Tires?
  239. 89 trooper transmission problems
  240. (3) Car Seats in a '98 Trooper???
  241. 1989 Trooper V6 - Idle adjustment?
  242. 88 Trooper II FOR SALE in Ohio
  243. 87 troooper engine rebuild--suggestions wanted
  244. hard to start when warm
  245. Front Rotor removal trouble...
  246. tropper running on 3 cylinders
  247. 89 Trooper II transmission problem
  248. transmission fluid
  249. 92 Trooper LS 3.2 Starter replacement?
  250. '96 3.2 Flywheel/Flexplate Problems
