1996 trooper fan belt help???
theiss2200
06-28-2004, 07:14 AM
I have a 1996 Trooper. The fan belt went on it i need to know how to replace them all and how to get the AC belt off. Can someone please help me
4thOfJuly
06-28-2004, 11:38 AM
If you plan to fiddle with it, you shall get the Chilton's Isuzu Rodeo/Trooper 1981-96 repair manual. This is PN 8686 and is usually a good reference for basic maintenance. The 3 belts are removed/replaced by:
Fan Belt = Loosening the Alternator (Pivot bolt, adjusting side lock bolt and adjusting bolt)
A/C Belt = Loosening the mid Tensioner (central lock bolt and adjusting bolt)
P/S Pump Belt = Loosening the Power Steering Pump (Pivot bolt, adjusting side lock bolt and adjusting bolt)
Hope this helps,
Cheers
Hope this helps,
Cheers
