View Full Version : 1st Gen 95-99
- performance intake manofold?
- 1999 dodge neon rough running at low speeds
- speedmeter DEAD!!!!
- Which wheels fit?
- 99 neon with SRT-4 suspension
- The "TAO" of the Neon...long post!
- Gauges don't light up
- 1996 Plymouth Neon
- 1995 Neon Quits After a couple hours driving
- 96 Dodge Neon
- 95 Plymouth Neon
- 95 neon hard to start
- 97 neon tech manual complete pdf
- 96 SOHC neon won't start!!!!
- Code 55
- 1995 neon sport car wont start
- 97 NEON DIES. Confused. Need help.
- 96 Neon Computer Pin-out Map?
- SRT-4 engin in my neon 95??
- rims and tires for my '95 neon???
- my 95 neon won't start
- 96 Neon Fuel Pump
- Coming hard off the clutch?
- 98 Neon Hook-Up Underway!!!
- 95 neon struts
- 97 Neon, I want to install a CD player...
- my 95 neon engine?
- 95 SOHC, alternator specs?
- 95 neon security issues
- 96 neon tranny pump!! help!!
- Electrical problem - any ideas?
- Cylinder head etc
- Power Window does not work!!
- 98 Neon Questions
- Loud noise from hood 96 neon
- "Button" stuck on 96 Neon shifter (auto)
- Considering buying a 97 Neon
- #3 cylinder missfire
- 97 Neon Harness
- 97 Neon 10 - 15 min runtime
- 1999 Neon R/T missing
- 3 speed auto
- 97 neon Auto top speed?
- 97 neon needs answers
- 95 neon
- 1995 neon fan probelms
- 95 Neon ignition issues, Please help!!!
- 95 Transmission Issues
- Dodge Neon 1995 SOHC problems
- Dodge Neon 1999 Oil Pan
- Dodge Neon 1999 how to change time belt
- Dodge Neon 1999 Oil leak
- 98 neon- weird stuff in spark plug tubes
- 95 Neon - code 25
- 96 Neon-Head Gasket still an issue?
- 4g63 swap or hahn turbo kit
- Dodge Neon 1999 hot temperature
- Just bought a 95 neon
- 4g63 swap
- Neon 1999 Oil Leakage
- Why does my 95 neon suck so much gas?
- 95 neon dies mysteriously
- 95 dodge neon tach wire location and color
- '97 neon - been through 3 batteries! help?!
- 96' Stereo Issues
- '98 Neon headgasket job, kind of off-topic question
- 1998 Neon Sport RPM??
- 95neon passing gear ajustment
- 95 sport vs. 95 regular
- 4g63 motor swap 2 1st gen dodge neon
- 96 Neon Instrument Cluster Problem
- 97 dodge neon random misfire
- 99 Weather strpping
- 414hp 1g
- 95 neon instrument interchange???
- srt-4 turbo and manifold on 1st gen dohc
- 1st Gen Neon Tach Install
- EGR?? what and where?
- 99 neon crankshaft damper
- 97 Neon, 90K, Having speedometer issues!
- Gauge installation question
- 1997 neon fan problem
- 95 neon need wiring diagrams
- 95 neon problems
- 95 Neon runs bad please help
- $$$ Engine Pricing
- 96 neon/electrical problem
- Replacing Clutch in 95 Neon
- If anyone knows about exhaust please read this!
- 95 Neon Clutch Problems
- My 95 Neon Is Running Horrible!
- 96 neon fuel gauge dosen't work
- My 96 neon's speedometer won't work!
- HELP! '96 Plymouth Neon - Hi O2, but PCM still sending rich command!
- 95 Dodge Neon Problems
- 97 dodge neon I need advise
- 95 plymoth neon computer
- '95 Neon Running poor
- hard start, engine bogs down
- 1995 eng code 37
- 95 Neon Having Problems
- 95 Neon Misfiring and Stalling
- Tachometer Problem
- My 1996 Dogde Neon Won't Start
- 1995 Neon gauges dead... help!
- flickering headlights in 95 Neon
- 1995 doodge neon hunting problem
- 96 SOHC ATX problem after flush/band adjustment
- 1995 SOHC Auto Dodge Neon Spec's?
- 95 engine problems
- 99 neon redline?
- Direct Interchangeability Of Fuel Injectors For 2.0 SOHC?
- 96 neon LH exterior mirror question
- Help changeing 95 neon head
- 95 neon wont start
- 98 Dodge neon wont start
- 98 temp gauge problems
- 98 neon leaking oil
- 95 dodge neon door problems
- 95-99 Dodge Neon Ralli Style Dual Halo Headlights
- 99 neon srt, fuel problem/humming noise
- Strange problem with my 95 neon
- 95 Neon Sport Died Anyone help me ?
- Horn Not working
- 1998 Trans will not shift
- tach is not reading correctly please help!?!?
- 98 neon speedometer problems
- 1996 Neon will not go in park
- speedometer
- 96 neon oil leak
- Harmonically stuck
- Help! broken speed sensor
- Is this a head gasket problem?
- 96 Neon code 72
- Head Gasket Replacement
- check engine light
- 98 neon... crank too long
- LOW IDLE then stalls, need HELP!!!
- 97 neon dohc problem!!
- '99 Neon Problems
- 98 neon runs great for 10 min
- timing on a 97 neon
- 95 neon. cooling fans run all the time
- 99 plymouth neon transmission problem
- 1999 plymouth neon fuel pump fuse problem
- 99 neon noises!?!??
- 95 Dodge Neon HELP!!
- 95 neon problem??
- 1996 Neon Computer Frys! 3rd in 6k miles!
- '95 Neon with codes 27 & 43
- Where is the fusable link from the alternator on a 1996 neon?
- My 96 Neon won't start
- 96neon new alternator not charging, why?
- A few small problems I need someone elses opinion on
- Wet Floorboards
- Who has put a Turbo on a 2L DOHC Neon?
- 99 Neon, warning lights
- Rear disc brake conversion....
- 97 Neon Runs In Reverse-dies In Drive
- parking brake 96 neon
- 97 neon gas mileage?
- 99 dodge neon r/t don't know whats wrong
- How hot is too hot? 99 Neon
- Stalling 1995 Neon
- 1996 Neon ATX HRC Turbo Stage 2 Sedan
- 95 Neon starter wiring
- 95 neon SOHC surges then stalls when hot
- 95 Neon Fuel pump fuse Blows
- Oil leak behind motor
- Head Gasket Replacement -How To
- 96 Dodge Neon won't start
- 98 Plymouth Neon - Setting Clock + Speedometer..?
- 96 Neon fuel filter & PCV valve
- 4g63 noen?
- 97 Neon and fuel pump
- 99' Dodge neon overheating
- 1995 plymouth neon---DEAD
- 1995 Neon that stalls at lights
- service engine soon light wont go out
- Steering
- 95 Neon opinion
- 95 Neon won't run for long
- 95 neon se 2.4 motor swap
- 1996 Neon problems - need help
- 95 sport V.S 97 Ex
- A Guide to Removing/Replacing EGR Valve
- 99 Neon missing at all speeds
- looking for rims
- 95 Neon engine surges at 50 mph
- i could use a few suggestions
- Transmission...
- Engine Question.....
- 95 neon/ignition -insert key into start car
- interchangeable parts?
- 1996 Neon CV Joint/Stalling prob
- 95 check engine light
- 95 Neon Brakes Problem
- 95 neon help please
- 95 neon ca. special edition
- 98 Neon-panel guages go to off then come on again
- A lot of probs with 95 need help
- 1999 neon
- 95 engine swap
- 1999 problems with the A/C
- airbags in a 95 neon
- 95 neon
- 98 Neon highline, transmission problems
- 97 Neon Headgasket
- 97 Neon
- Backseat
- 2.4 liter (srt-4) parts on 2.0?
- 1995 Neon Engine Dead?
- 95 Neon Frustrated
- 95 Neon Has Everyone Stumped!
- 95 neon, help!!!!!
- 96 neon
- 95 neon cranks but no fuel or spark
- 97 Starter How To?
- 1999 neon timing belt replace
- 98 Neon R/t - Need Opinions
- 95 Neon bogging down, poor acceleration
- 97 neon wont start
- Which exhaust would you pick?
- 1995 neon sohc question????
- 1998 Dodge Neon Won't Start Help!!1
- Rich mixture with header?
- one wiper
- 95 neon rattling...?
- Problems with 96 neon
- 96 SOHC Neon?
- 96 Neon coil problems?
- 98 neon shift knob...
- Skunk Stripes
- Wheel Hop
- dohc muffler on sohc neon
- Pacesetter header?
- Racing
- 1997 braking problems
- 96 Neon - Code 44
- Valve Cover Gasket
- 96 neon having problems starting
- Window stickers
- 97 Neon Timming
- 95 neon photos
- door panel removal
- 97 Neon Got problems....need help!!!
- 3.55 or 3.94
- 95 neon speed sensor
- 99 Neon code clearing??
- 97 neon
