View Full Version : Prelude
Pages :
[ 1]
2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
- 97 JDM Prelude SiR oil consumption
- Hard starting 2.3 Lude
- engine swap
- Fans not working 95 Prelude se
- Instrument Cluster
- SAE threads on VTEC?
- bumper beam 1991
- about mig welding
- Honda prelude misfiring pinging
- Disconnected cooling fan and car won't start
- Mode Buttons
- 96 Prelude h23a1 to h23a3 swap with tdc sensor problem...Help!!
- Souping up a Honda Prelude.
- I need a cheap 90-91 speedometer
- questions about drive the prelude 2001 in winter
- 1996 Honda Prelude Headlight
- Prelude Civic
- ??a 1996 prelude with 140K to buy or not to buy??
- 89 Prelude brake issue
- who can tell me
- how to tell,help me
- Prelude Mods
- hydraulic clutch
- 94 prelude
- Need help from you guys before purchasing
- 90 prelude dash lights/parking lights?
- Hi-RPM vibration
- Prelude's ride
- coolant leak underneath
- Prelude SI Add VTECH controller?
- change from auto to manual
- hydraulic clutch
- 00 Honda Prelude Starter Fix
- prelude help
- 1987 Honda Prelude 2.0si fuel injection engine... drive axel broke from tranny...
- Drive axle... 1987 Honda Prelude 2.0si Fuel injection engine
- Turbo SH and Emissions
- Prelude Muffler
- witch Prelude??
- Re: Unstable rpm idle same issue unsolve
- Unstable RPM Idle
- Unstable idle when it start and driving
- 1992 Honda Prelude SI 5 speeds RPM jumping up and down
- engine low miles or reman
- V-tec problems/engine bogs down before redline
- Prelude 97 VTI-R, possible gearbox issue?? HELP!!
- 89 Prelude Idle Problem
- '88 prelude with dead cooling fan.
- radio wont turn on after battery replacement
- Passenger Window on 89 Prelude
- 86 prelude fender trims
- Knock Sensor engine light problem
- 97 Prelude O2 Sensors (question) *newbie*
- Prelude B20A Metal Head Gasket
- Radiator Fans Are Not Turning on
- Blufusion 92 & Wyldfyre 96
- My 4WS Lives!
- h22a1 motor swap 91'prelude
- ac problems
- A/C Problem '92 Honda Prelude
- 91' prelude sr computer lights.
- selling 92' Prelude 2.3 Si
- 93 prelude si h23a1 (non vtec) to h22a1 vtec
- NEED HELP! Doing an engine swap between an h22a4 into a 94 h22a1 prelude
- Check Engine Hide-And-Go-Seek
- H22 build Turbo or n/a?
- Prelude 2.0s
- '90 Prelude cooling fan running after shutdown
- h22 tranny problems
- 92 prelude with F22b knocking.
- lots of stuff, help please
- prelude engine swapes? help please
- Retro E-55 phillips ballasts, ignitors, bulbs 4300k
- left hand vs right hand - HELP!
- Need help again
- Looking to buy 88' prelude.. questions.
- Potential high mileage problems with a gen 5
- wiring vtech
- Need help
- dashboard and idle lights wont turn on..
- 01 honda prelude base idle prob.
- i need help with finding rear quarter panels for 1992 prelude
- 94 prelude is smoking really bad
- 89 Prelude passenger side front/back turn signals not working?
- 90 Prelude transmission problem shifting
- rebuild prelude
- rebuilding a H23A1 prelude
- prelude on a track
- 87 Prelude Circle Track Car Exhaust
- 89 Prelude/Transmission Fluid and Overheating Questions
- To all prelude owners!!!!!!
- 92' 5peed problem
- Can i remove my a/c from my 88 Si?
- h22 swap
- Help with my 90 prelude
- 99 lude vtec with turbo?
- 94 Prelude SI headlamps
- 1986 honda prelude
- 94 Prelude digital fuel gauge and clock
- Radio Code needed for 92 prelude
- 89 Prelude CV Joint and Rear Brake Piston
- 96 prelude fuel problem!
- 1997 Prelude - Low idle problems
- 5th gen clutch problems
- Prelude won't move
- New here....PLEASE HELP
- error code 43 91 prelude
- New transmission whining, slippin
- Corner Lights >:(
- camshaft needs replaced ... where to buy?
- 87 prelude no fuel or spark PLEASE HELP
- Need help with trany for 97
- Prelude questions. help new guy
- 89 honda prelude check engine light troubles
- question a bout aftermarket/jdm parts
- 90 prelude clutch slave cylinder install
- Cams
- Check Engine light
- 1985 honda prelude si 5 speed 4 cylinder HELP!
- help...!!!
- O2 Sensor Istillation...replacement
- 90 prelude high idle
- got a 90 prelude
- 98 Tranny problem, maybe lawsuit??? help
- oil leak
- P301 and P1399 error codes help me
- 92 lude question
- 88 prelude si questions
- Coilover squeak
- what year prelude is this from ?
- what type of engine is in my prelude
- Need some help with my '94 Lude
- Anyone selling a PRELUDE?
- Vtec Problems
- Vtec Problems
- 92 Prelude
- brake pads
- 89 si FI Less than half the power
- h23 question
- how do u chip a h23a1?
- Terrible forum
- 1989 Honda Prelude Si question
- 97 prelude h22a swap
- i want to lower my prelude-what did you do???
- Looking for ECU 37820-P13-JXX for 4 socket
- Leak Down Questions?
- 97 Prelude randomly turns off on the freeway! HELP!!!
- Need help with new engine
- h22a oil pressure problem
- Old Honda S-600?
- buying a prelude
- check engine light with cylinder misfire
- 93 vtec engine light and bogging
- SeaFoam?
- what kinda of motors i can put in my 90 prelude??
- what engine is this, im confused
- new rims and tires
- blue prints
- Turbo
- more hp
- 91 prelude idle problem
- H23 manual tensioner worth doing
- Headlight switch?
- Need Advice
- 93 prelude idle problems
- any ideas?????
- Prebuilt H22 Motors?
- Tein S-Tech
- New member here (n00b)
- no power to fuel pump.
- vtec wires on my 2.3 vtec stroker
- my trans is slipping
- 89 prelude stereo not working
- 93 prelude
- 89 Prelude wont start.
- motor swap 92 prelude
- Battery light stays on
- honda,prelude
- Whats going on?
- Hows the mpg for a 97-01 Prelude?
- 95 prelude 4ws conversion?
- 93 Honda Prelude parking lights and dashboard lighting just went out
- Fixed (please Delete)
- 91 prelude si parts car
- suspension
- 99 Prelude SH Clutch Replacement
- Its smoking, Help
- Engine noise after timimg belt change ?
- just bought a 94 lude
- idle problem on a 88 prelude 2.0si
- unstable idle
- Electrical problem
- Question about aftemarket exhaust backpressure
- Newbe
- Death of a Prelude
- 5th gen prelude tranny swap?
- b20a5
- 92 prelude
- Broken Sway Bar
- 1982 Prelude 55A fuse?
- 91 lude SI b20a5
- 98 prelude rough start?
- 88 Prelude Rear Suspension Swap
- Tranny/electrical Problem???
- h22 swap on 91 prelude
- 1990 Prelude fan won't quit
- brake problem
- newly discoverd mitsuba engine: a keeper?
- Fuel System or Electrical Problem?
- Can anyone help me with a Carfax account and run my VIN number 4 me
- 91 Prelude Sr Alb Light On
- hey all bought a 89 prelude, bad start...
- Where to get h22's
- Del Sol seats + Prelude SI
- question on engine swap
- 93 prelude f22 cumputer chip upgrade
- 510 injectors for 94 prelude...
- I need help with my prelude !
- Best bet for a 91' Prelude Engine Swap??
- Accord R Lip
- Prelude Gauge Cluster
- COMPLETLEY stumped, please help!!!!
- Need some help here guys, FAST
- hi, im looking for something.
- anyone find a large 4th gen rear sway bar?
- 91 prelude
- crystal red tail lights
- JDM H22 full swap
- h22 head on a h23 - what am i getting myself into here?
- rpms
- performance chips
- altenator!
- All brake lights went out! Need help.
- h22 + h23 crank
- 1989 Prelude si swap
- How do I replace the Cabin Filter?
- P0700 and P0740
- Door is Stuck
- Pulsating brake pedal and ABS light
- 1981 prelude motor swap
- I'm looking for...
- 1985 prelude what motor is this
- Help
- can sum one tell me.....
- 91 Honda Prelude and ABS light
- Fng
