View Full Version : Windstar
- Windstar Keyless Entry
- trailer wiring plug
- havign problems gettign fuel filter off...
- 2001 windstar wiring
- sweaking noise on fan belt or something else...
- 98 Windstar - 1st Time Transmission Trouble
- IMRC Install Question
- 2000 Windstar Stutter/Shudder Quirk
- Intake Manifold Woes
- 1994 Windstar..............OBDII ??????
- 98 Windstar electrical
- digital display mph and erratic tranny shifting
- Transmission won't go into park.Now won't atart.
- Transmission Removal
- headrest
- 95 Windstar Rear Air Suspension
- P0351
- Rear Parking light doesn't work
- Front Hub Caps Spinning
- IMRC ? on a 97 Windstar
- Brake Pedal noise inside van
- ABS light comes on after driving awhile
- Just purchased 2000 SEL
- turn signal, brake light stays on
- 2002 Ford Winstar Theft Deterrent
- Water pump life
- Tranny Sometimes Won't Shift! Please Help!
- 1999 power window problem
- obd2 interpretations
- abs and parking light on
- Electric door not closing completely
- 98 windstar front wiper fluid not working
- Man Oh Man!
- Rust problem?!?
- Front End noises
- bad Bearings
- carb cleaner for efi??
- 98 windstar air bag code
- 2001 Whindstar Fog/Driving lights
- 98 windstar rear brakes
- tune up specs for a 1995 windstar
- transmission whoas!
- 98 Ford Windstar IMRC
- 98 Windstar - windshield pump&brake lights
- 1996 Winstar GL - Alarm Went Off - Need Help
- 95 Wstar dome light & fuse panel problem
- Abs Light Stays On
- P0442
- Ford windstar dome lights problem
- brakes
- Steering Noise when turning
- Oil in throttle body '96 3.8L
- OK got the 171-174 codes any danger to just driving
- Looks like this is it?
- iding fast, new serpetine belt installed
- 99 Sales Brochure
- Help! '96 windstar oil in coolant
- Check Engine Light Code: P1744
- Help!!! 2002 brake lights screwed up
- running rough
- p1131 p1151 p0171 p0174
- 2000 Winstar Noises
- Coninued Brake problems after pad replacement
- Car from hell - Windstar 3.8. Help!!!
- Cruise control doesnt work
- 98 Ford Windstar Stalls
- Tail Light Assembly - Help
- 95 Windstar Transmission - Lock-up In and Out
- 1998 Ford Windstar Electrical Proble
- need help from the tune up experts
- 98 Windstar Rear Brakes
- Rad Sludge
- Steering issues 95 Windstar
- 2004 Freestar DVD Harness
- Another ABS question - ABS/Track turn on intermitently
- P0401 and EVAP
- cd changer and compatible headunit prices?
- windstar tranny and pcv
- 1998 Ford Windstar SUCKS!!!
- Code reader
- 1999 Ford Windstar "oil change required"
- Buzzing noise in dash
- PCV Valve replacement
- 2002 Windstar fuel filter location
- Adding a keyless entry to a 1999
- indash stereo recommendation
- ford diagnostic chart
- 1999-2003 split-port intake
- 99 Windstar Theft deterrent
- Noise, i think from the belt
- Ford Windstar Remote Programming
- camshaft position sensor
- tutorials and howto's...looking for some...
- 1997 3.8 intermittent breakdowns
- 1999-2000 Cruise control switches
- 96 3.8 windstart won't start
- ogr cleaning
- O2 sensor
- code access
- Downshifting
- blinking o/d light
- Wiper fluid light, ABS, Trac Off light
- Removing door panel
- Windshield cleaning
- 2000 SEL power door leaks during rain?
- 2001windstar factory keyless code
- Different Brake Light Problem
- Check engine light
- brake light problem
- 5w-20 motor oil
- Cabin air filter
- 96 windstar rear door
- 96 windstar door panel removal
- tranny constantly trying to shift
- 2004 Windstar Power Seat
- windstar-no start problem
- fuse panel assignment
- new (to me) '95 Windstar
- 98 windstar traction control
- Intermittent Speedometer
- '96-Door Ajar light on. chimes dependant on speed
- 98 windstar
- Help!!
- Alternator electrical connection burned
- camshaft position sensor problem!!
- 1999 Windstar lights bright and dim
- air bag activation switches - reusable?
- help about to go crazy
- Dome Lights and Door Sensors on a Ford Windstar
- Springs
- modded Windstar
- 2001 Air Filter
- ABS Noise
- Failed Air Care
- 96 Stalls on take off.....
- 99 Windstar Brake Noise
- 99 Windstar Tune Up
- Service manual
- Transmission cooler
- 2000 WindStar Rever Sensor always turned off
- 1999 Windstar Power steering fluid leak
- spoilers & "sport"
- timing belt
- Trailer Hitch Scrapes Street
- Two CDs stuck in player?!?!?
- Brake Pads
- Replaced engine and Tran Leaks!!!
- 1996 Winstar Power steering pulley
- 1996 LX Addon Slider Windows
- 99 running rough after replacing plug wires
- Rough Idle/Stall in cold weather
- Need help with my Windstar in Switzerland!
- What is cylinder miss fire
- No Heat
- PCV valve
- Windstar Options Codes
- 1998 Windstar 3.8l engine info
- turn signal suddenly stopped working
- Keyless Entry Code Reset 96 Windstar
- ABS Problem
- 1996 Windstar Transmission
- dome light won't go off
- 2000 Windstar Pulls Right Accelerating
- Oil filter blowing up
- URGENT help - speedo
- Windstar 3.8L Rough Idling
- Sliding door jams open
- 98 Windstar stalls when driving
- Blinking traction control Light
- howtoprogram 95 Windstar keyless remote
- Water Pump
- Power Steering Whine in 2002 Windstar
- Windstar 98 Code 1596
- Codes 171 & 174 too lean
- 1996 Windstar 3.8 Alternator
- Door Sensors on My Windstar.
- 98 windstar lx idle
- 1996 Windstar Cruise & Wind. Lft Mtr ?'s
- Auto Door Locks going nuts???
- 2002 Windstar Stalls
- Transmission
- Windstar front end noise.
- Instrument Panel Light Replacement, '95 Windstar
- Sliding Door Squeeking, Locks dont work
- A couple problems, I need cleared up by some of you guys
- clicking
- interior bulbs
- Camber, Caster Alignment?
- Blend Door Actuator – 2000 Windstar
- Ford Windstar -97
- CV joints on 98 Windstar
- Power Steering Fluid Flush
- 1996 Winstar Brakes
- leaking hose!
- need help with missing prob
- check engine light...
- Ford Windstar is killing me
- Engine Replacement 3.8L
- windstar door keypad code
- changed air filter, now stalling surging at idle
- need help finding something
- Front end clunking
- windstar o/d light blinking o/d off
- engine swap, need help
- tail lamp/light not working
- Adding Freon
- Power Steering fluid on cap?
- vibration on acceleration
- Sliding door open spontaneously
- need to locate keypad entry code
- How to prgraim 98 Windstar security system
- 3.8 miss-firing underload
- cleaning egr ports
- CD Changer
- cylinder 6 misfiring
- Sliding Headrest Repair?
- 2002 Windstar Brakes are garbage
- 96 Windstar Keyless remote
- egr flow insufficient
- 2000 Windstar LX - Intermittent “clunking” sound from left side after hitting a bump.
- Keyless entry
- Front End Vibration
- will synthetic oil extend the life of Windstars
- Video Wiring diagram
- Windstar from hell, brakes,transmission, bearings,noises
- wiring diagram 96 ford windstar
- Service Engine soon error Code
- 1998 Ford Windstar Blinking OverdriveLight
- 1998 Keyless Entry
- Possible Cause For C.E. light?
- 1996 Ford Windstar Spark Plugs Please Help
- Keyless Entry Windstar 2001
- 95 Windstar Shift problems
- vent control
- Problem solved (I hope)
- Mileage
- oil in throttle body on 96 windstar
- 97 Winstar Speedo Dies...
- Other Forums
- Windstar Leather Seats
- Wiring Harness Color Code
- Newly Bought 1997 Windstar
- spark plugs
- door open alarm
- front end noise on left side
