View Full Version : '97+
Pages : 1 2 3 [4]
  1. Passat 2003 ABS/ESP/battery problems
  2. Lock for wagon rear hatch won't open
  3. A Passat 1.8T 2002 noise when started
  4. Car Manual.
  5. Audi TT turbo
  6. 99 Passat-Water Leaking in from under dead pedal
  7. Boot / Trunk won't shut
  8. Dumb question - 2002 Passat headlight housing removal
  9. test driving 99 passat tommorrow... what to look for?
  10. Gas Cap?
  11. White Smoke?
  12. 2000 VW Passat code P1128
  13. TDI motor oil, does only the dealer have it
  14. 2004 Wheels
  15. Engine Movement
  16. Cat, PCV hose & differential
  17. wind noise
  18. Hp Racing Evo 18x8 of 18x9 Hypersilver LIght or Dark 5x112 Beautiful
  19. loss of power and a/c display flashes/blower fuse blows
  20. Check Engine light with P0421 ...???
  21. radio code???
  22. '05 Passat, Thinking about buying, asking for opinions
  23. Suspension Survey
  24. what to do if timing belt broke ???
  25. PASSAT 1.8 20v
  26. No wipers, brake or turn signal light
  27. Code P301-304
  28. Dead Interior Lights
  29. 02 Passat noise from wheel well
  30. Transmisson?
  31. Chronic overheating after turbo swap!
  32. 98 won't turn over :(
  33. Clock and trip odometer display
  34. rough start
  35. Possible Memory Seat malfunction?!
  36. 03 PASSAT; trunk lock alarm always on
  37. New Enthusiast
  38. 1998 Passat 1.8T No Start No Fire?
  39. 98 Passat 1.8T elec and engine issues
  40. 99 Passat Wagon 1.8T - running lean
  41. transmission locked out
  42. Brake Malfunction
  43. 2004 Passat potential remote starter problems
  44. Brake Pad light - intermittent
  45. Help! '03 Passat cold start problem
  46. 2003 Passat GLX will not start
  47. Rough idle/starts bad
  48. replaced battery in 97 Passat: won't start, alarm lights no horn going off
  49. passat only starts when it feels like it
  50. Multifunction Switch problem after major service
  51. How to change Passat 2002 Fog lights
  52. Temp Indicator and Oil press wire
  53. knocking sound in driver side wheel well
  54. Help with CLimate Control lights
  55. '99 Passat v6 won't start
  56. Glove Compartment lock not working
  57. Error Code P1423
  58. tire noise-tie-rod?
  59. 2000 V6 an interference motor?
  60. 2002 Passat - Dead Remote
  61. new passat q's
  62. so were ????
  63. slapping noise on start of 2000 V6
  64. Changing ECU on 2000 Passat
  65. Wipers, Turn Signals, Fan, Headlights OUT/ Brake light ON
  66. question for Boschmann
  67. Problem with Passat
  68. 1999 Passat won't start
  69. Help me diagnose this Passat please
  70. Follow up - PASSAT - No Turbo till 3000rpm then.... look out!
  71. Idle problem at stop
  72. DTC P0411 - What does it mean
  73. Faded skirt trim 2001 Passat
  74. 99 Passat Turbo 1.8 Ck Engine
  75. 1999 Passat Trunk Light
  76. passat 1.8t 1999
  77. New member concern list
  78. passat 1.8turbo
  79. 2001 Passat Engine Appears Flooded
  80. Passat Cambelt
  81. 1997 VW Passat Wagon GLX-NOISY ENGINE
  82. new stock stereo- different year
  83. 1997 passat V6
  84. 97 Passat heater core
  85. 99 passat autom trans shift problems, cold or hot
  86. O4 passat brakes shimmer
  87. 1998 Passat tie rod ends??
  88. 99 Passat - Should I replace both brake pads & rotors?
  89. 02 Passat error code P1296
  90. electric mirror switch replacement
  91. New Owner of '99 Passat 1.8T: Preventative Maintenance Suggestions??
  92. Idle & turbo problem?
  93. 97 Passat
  94. Failing Central locking and locked Fuel lid
  95. Check Engine light 99' Passat
  96. Spark plugs 99' Passat 1.8T
  97. 2004 Passat will not start
  98. 2000 1.8 whistle on cold start
  99. 2001 Passat 4motion - Intermitten Starting Trouble
  100. 2001 Passat CD changer
  101. 2000 passat door mechanism
  102. 2001 passat coolant loss
  103. parts for 99 passat
  104. where is the connector for the odometer for 99 passat
  105. 1999 Passat Thermostat Location
  106. 99 1.8T Spark Plugs
  107. 2002 Passat -Wont Start
  108. 2002 Passat Rear Brakes
  109. Headlamp Passenger Side/Passat 2000
  110. Replace heater core in a/c 99 1.8T
  111. 2004 1.8T Oil Pan and Drain Plug
  112. 1999 Passat battery/computer problem
  113. Needs Instructions On How To Change 2002 Outside Passenger Side Headlight?
  114. FS:1998 VW Passat 1.8T
  115. 99 Passat idles rough -- Please help
  116. Tiptronic "T" to a Top botton straight shifter?
  117. Parting out a 1991 VW Passat
  118. 2001 Passat - Rear Brakes
  119. 2002 passat allarm going off
  120. 1997 Passat GLX VR6 Woflsburg Window Motors
  121. 2002 Passat Oil Pressure Problem
  122. 98 1.8 Turbo Revving
  123. 2002 Fog-light Cracked
  124. 1997 Passat Glx Vr6 -thermo Housing Leak -07/28/04
  125. Passat 98 electrics cut out
  126. 2002 VW Passat 1.9 TDI with cold air draught around gearstick
  127. 2000 Passat Battery Change and Computer Reset
  128. 1999 Passat Interior Lights Broken!!
  129. 1999 Passat V6 -slight miss when idling.
  130. 2000 passat turbo tempature gage
  131. 98 passat gls for sale......
  132. REPAIR question, front end, 2003 Passat
  133. '98 1.8L Not Starting
  134. Turn signals not working....?
  135. 2003 Passat Fuel Filter/Brakes
  136. '00 Passat - loss of A/C, Fans, Wipers, Signals,
  137. problem with 2000 4motion electrics
  138. 04 passat tdi "whistling" noise
  139. 00_Passat Check Engine Light
  140. buy 2002 Passat? 95K
  141. 97 Passat Rear door not locking
  142. Location/Engine Coolant Sensor/Passat 2000
  143. 2002 Passat Rotors and Brakes
  144. Replacing flasher switch on 2001 Passat
  145. 98 VW Passat burning oil
  146. Should I Buy A Passat
  147. check engine light (98 Passat)
  148. popping while braking (98 Passat)
  149. 98 Passat Alarm
  150. 2002 V6 oil burning
  151. 98 Passat - Probs with Coolant Temp/Level Light
  152. Oil change in my '98 Passat?
  153. 98 passat 1.8t
  154. 2000 VW Passat failure!!!
  155. 99 Passat V6 strut/sway bar noise
  156. 2000 Passat won't start
  157. 2001 GLS 1.8t ABS light
  158. strange noise in 97 Passat GLX VR6 wagon
  159. 99 Passat Transmission issue
  160. 01 Passat Engine Light and Temp Gauge
  161. abs light on 97 passat wagon glx
  162. 99 Passat Items Needed
  163. '98 Passat spark plugs
  164. CD Stuck in '04 CD player -- anyone know how to unjam?
  165. 2001 passat
  166. 1998 passat shudder
  167. a/c recharge port on the '99 1.8T
  168. Emissions Workshop Tip for 2001 Passats with 1.8T engine
  169. 2000 Passat brake noise in reverse
  170. BMW headlights on 97 passat?
  171. timing belts 60000 mile and dealer mark up? (1999 wagon)
  172. Subwoofer in 2003 Passat Variant
  173. 2001 passat engine light
  174. Just Purchased Used V6 1997 Passat
  175. location of ignition module on 99 Passat 1.8?
  176. 97 B4 Passat day time running light concern?
  177. Urgent !! 2001 Passat Antitheft Alarm keeps going off
  178. 2000 Passat GLX 4 motion
  179. smell, fogged windows, in 2001 Passat V6
  180. Brakes Lock-up and will not Release - '99 Passat
  181. 97 Passat Temp Gauge Problem
  182. 97 Passat Power Window Problem
  183. Rattle in Trans or Wheel? 2002 Passat
  184. 2004 Passat Triptronic lurching
  185. 1997 Passat remote key
  186. 2000-2003 passat wagon rating
  187. 2001 VW Passat P0431/P0421 Catalyst problem
  188. im lookin for a 97 passat glx cup holder and a center cap
  189. 00 Passat Transmission Noise - Need Help
  190. 2001 Passat
  191. 99 Passat Battery and Remote Key
  192. 2002 VW Passat rear brakes
  193. 2002 Passat Specs
  194. 99 Passat 1.8 has anyone had this many probs???
  195. 1999 Passat V6 GLS For Sale
  196. 04 Passat Odometer Jump?
  197. 97 passat glx wagon tire size
  198. Car jerks when coasting
  199. looking for interior center air vents for a 2000 passat
  200. 1999 Passat Windshield Washer low light wont go off.
  201. Im looking to buy a 99+ Passat. What should I be looking for?
  202. Cold Weather Blues - 1999 Passat
  203. oil smell inside 2000 glx V-6
  204. Rear door probs 99 passat wagon
  205. '03 Wagon - Brake Noise, then Gone
  206. Pipe size for 1999 Passat
  207. 99 VR6 morning engine noise
  208. passat sport 03 throttle response
  209. 2001 passat warped rotors
  210. 1999 Passat 1.8T Timing Belt Maintenance Interval
  211. Creaking noise on 03 Passat
  212. APR 91 Octane chip for 2000 Passat
  213. bad smell from 1998 Passat V6
  214. Converting 2001 Petrol/Gas Passat to TDI engine?
  215. 99 1.8 turbo help
  216. Need TSB Text 99 Passat
  217. Need Advice on which car to buy; 1998 Passat v6 or 2000 Passat v4
  218. 1997 Passat Computer Chip?
  219. Passat 1.8T oil specifications
  220. 2003 Passat windsheild wiper blades
  221. 2000 Passat climate control problems
  222. '03 Passat GLX 4M Brakes coming on by themselves!
  223. Chipping a B5.5 2003 1.8T Passat
  224. 1999 Passat Brakes
  225. 2003 Passat GLX
  226. 2000 Passat Coolant Problem
  227. Tuning an 03 Passat 1.8T
  228. cruise control 97 Passat VR6
  229. Technical questions, troubleshooting etc.
  230. 2002 Passat V6 engine mods.
